查看: 4115|回复: 0
[LV工具模块] LabVIEW 2016 Electrical Power Suite LV2016电力套件EPS2016电力工具包
    20 分钟前
  • 签到天数: 3792 天
    连续签到: 43 天
    发表于 2020-7-9 11:20:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2016 Electrical Power Suite Win32Eng LV2016电力套件EPS2016电力工具包
    文件大小: 111546888 字节 (106.38 MB)
    修改日期: 2016-07-28 02:35
    MD5: 29f28f82ef1b927299ff62d2a176911e(重复一致)
    SHA1: 8a3613a8f163edbb604415b89c08761c12d38498
    SHA256: 06a0b11ed6572830976fc1991b3ff55103c578ff5d898e008697bb7f209b1a90
    CRC32: 85d520d9
    LabVIEW电力工具包可帮助您开发应用程序来测量、分析、 监控和记录电力数据和现象。
    LabVIEW电力工具包是LabVIEW的一个附加软件,可帮助您自行开发单相或三相电力监控、计量或质量分析应用程序。LabVIEW电力工具包包含了功率测量和电能质量VI,可用于测量电力和质量参数以及在CompactRIO、CompactDAQ和PXI平台上执行谐波分析。该工具包还提供了同步相量测量VI以及保护VI(用于保护CompactRIO平台上的设备)。
    2016版本之前的电力模块叫Electrical Power Suite,简称EPS,2017之后的版本叫Electrical Power Toolkit,简称ETP。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EPS2016.txt (274 Bytes, 下载次数: 3, 售价: 10 圆)
    LabVIEW 2016 Electrical Power Suite Readme
    June 2016
    This file contains important information about the LabVIEW 2016 Electrical Power Suite, including system requirements, installation instructions, and new features.
    NI Software Support for Microsoft Windows 8.0, Windows 7, Windows Vista, Windows XP, and Windows Server 2003
    The LabVIEW Electrical Power Suite provides VIs that you can use to create applications that measure, analyze, monitor, and record electrical power data and phenomena. Use the Power Measurement VIs to measure electrical power parameters and to perform harmonic analysis on the CompactRIO platform, the CompactDAQ system, and the NI PXI platform. Use the Power Quality VIs to perform power quality measurement on the CompactRIO platform, the CompactDAQ system, and the NI PXI platform. Use the Synchrophasor VIs to perform synchrophasor measurement and use the Protection VIs to implement protection devices on the CompactRIO platform.
    The Electrical Power Suite complies with the following standards:
    • IEC 61000-4-7:2009, Electromagnetic Compatibility (EMC) - Part 4-7: Testing and Measurement Techniques - General Guide on Harmonics and Interharmonics Measurements and Instrumentation, for Power Supply Systems and Equipment Connected Thereto
    • IEC 61000-4-15:2010, Electromagnetic Compatibility (EMC) - Part 4-15: Testing and Measurement Techniques - Flickermeter - Functional and Design Specifications
    • IEC 61000-4-30:2008, Electromagnetic Compatibility (EMC) - Part 4-30: Testing and Measurement Techniques - Power Quality Measurement Methods
    • IEEE Std C37.111-1999, IEEE Standard Common Format for Transient Data Exchange (COMTRADE) for Power Systems
    • IEEE Std C37.118.1-2011, IEEE Standard for Synchrophasor Measurements for Power Systems
    • IEEE Std C37.118.1a-2014, IEEE Standard for Synchrophasor Measurements for Power Systems
      Amendment 1: Modification of Selected Performance Requirements
    • IEEE Std C37.118.2-2011, IEEE Standard for Synchrophasor Data Transfer for Power Systems
    • EN 50160:2007, Voltage Characteristics of Electricity Supplied by Public Distribution Networks
    • NEMA MG 1-2014, Motors and Generators
    In addition to the system requirements for the LabVIEW Development System, LabVIEW 2016 Electrical Power Suite has the following requirements:
    • LabVIEW 2016 Full or Professional Development System (32-bit)
    • LabVIEW 2016 FPGA Module
    • LabVIEW 2016 Real-Time Module
    • NI CompactRIO Device Drivers August 2016
    • NI-DAQmx 16.0 (required only if you use NI DAQ devices with the Electrical Power Suite)
    • At least 200 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2016.
    LabVIEW 2016 Electrical Power Suite supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Double-click the setup.exe file in the root directory of the Electrical Power Suite installer and follow the instructions on the screen to install the Electrical Power Suite.
    LabVIEW 2016 Electrical Power Suite Drops Support for Microsoft Windows 8.0, Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, the LabVIEW Electrical Power Suite drops support for Microsoft Windows 8.0, Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. LabVIEW 2016 Electrical Power Suite and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use LabVIEW 2016 Electrical Power Suite to an unsupported OS. Additionally, after installing LabVIEW 2016 Electrical Power Suite, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    LabVIEW 2016 Electrical Power Suite adds support for the following software:
    • LabVIEW 2016 (32-bit)
    • NI-DAQmx 16.0
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the Electrical Power Suite.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW Electrical Power Suite. This is not an exhaustive list of issues fixed in the current version of the LabVIEW Electrical Power Suite. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    538527Parse Command Frame VI did not function normally in error handling and could not parse certain user-defined command set
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help in LabVIEW, for information about the Electrical Power Suite.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Electrical Power folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Electrical Power Suite in the labview\examples\Electrical Power directory.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI Measurement & Automation Explorer (MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2011–2016 National Instruments. All rights reserved.
    374774C-01
    GMT+8, 2026-2-3 08:38
