查看: 3177|回复: 0
[LV工具模块] LabVIEW 2010 Advanced Signal Processing Toolkit Win32ENG LabVIEW2010高级信号处理工具包ASPT2010 32位Windows英语版
    昨天 07:57
  • 签到天数: 3837 天
    连续签到: 30 天
    发表于 2020-7-12 18:36:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ASPT工具包,在2009到2017年版本之间,有64位的测试版,但是NI官方一直到APST2018才正式发布64位版本。我方视觉论坛提供了ASPT2009-APST2017的64位版本下载。具体的可在本论坛搜索相应的版本。
    LabVIEW高级信号处理工具包是一组软件工具,可用于执行时频分析、时序分析和小波分析。
    LabVIEW高级信号处理工具包是LabVIEW的一个附加软件,提供有时频分析、时序分析和小波分析工具。该附加工具内含LabVIEW数字滤波器设计工具包,您可单独购买这一工具包。为了有效地提取信号隐藏的信息,应选择适当的分析工具。您可以将时频分析工具用于具有缓慢变化的光谱内容的进化信号,用于静止信号的时间序列分析工具,以及用于描述短时事件的进化信号和瞬态信号的小波分析工具。您还可以将分析代码部署到NI实时嵌入式硬件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
    EXE版:
    链接: 请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服提取码: 请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    EXE版:
    ZIP版:
    ASPT2010.txt (533 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2010 Advanced Signal Processing Toolkit Readme
    Version 10.0.0
    June 2010
    This file contains information to introduce you to the LabVIEW Advanced Signal Processing Toolkit. This file also provides you with help resources you can use while working with the Advanced Signal Processing Toolkit. The file contains the following information that you need to understand.
    New Features and Changes
    Activation Notice
    The LabVIEW 2010 Advanced Signal Processing Toolkit is the upgrade version of the LabVIEW 2009 Advanced Signal Processing Toolkit. The Advanced Signal Processing Toolkit provides VIs for time frequency analysis, time series analysis, and wavelet analysis.
    Use the Time Frequency Analysis VIs to transform a time domain signal to a linear or quadratic time-frequency domain representation. You can extract useful information from the time-frequency domain representation of a signal, or you can process a time-frequency domain representation and reconstruct a time domain signal.
    Use the Time Series Analysis VIs to perform preprocessing, statistical analysis, correlation analysis, spectrum estimation, and model estimation on a univariate or multivariate (vector) time series. You can extract useful information from the time series with different analysis methods for different applications.
    Use the Wavelet Analysis VIs to perform transforms and inverse transforms between a signal and the wavelet coefficients of the signal. You can use the Feature Extraction VIs to perform denoising, detrending, probability density function estimation, peak detection, edge detection, and ridge detection on a 1D or 2D signal.
    • This version includes the following new VIs:
      • TSA Bicoherence—Use this VI to compute the bicoherence of a univariate time series.
      • WA Set Coefficients of Discrete Wavelet Transform—Use this VI to set specific coefficients that you compute from the discrete wavelet transform.
      • WA Set Coefficients of Integer Wavelet Transform—Use this VI to set specific coefficients that you compute from the integer wavelet transform.
      • WA Set Coefficients of Undecimated Wavelet Transform—Use this VI to set specific coefficients that you compute from the undecimated wavelet transform.
      • WA Online Detrend—Use this VI to remove the trend from 1D streaming signals by setting the approximation coefficients to zeros.
      • WA Online Multiscale Peak Detection—Use this VI to detect peaks or valleys in a streaming signal.
    • This version includes the following changed VIs:
      • TSA Bispectrum—This VI includes the following new or changed parameters that enable this VI to examine whether the phase components at specific frequencies are coupled.
        • initialize? (F) specifies whether the input block of data is the first block.
        • averaging parameters specifies how this VI computes the averaging.
        • averaging done? returns whether the averaging process is complete.
        • length specifies the length of the sliding window that divides the time series into subsequences.
        • frequency bins specifies the number of frequency bins for which this VI computes the bispectrum.
      • TSA MUSIC—The default value for noise subspace is –1, which means this VI calculates an appropriate value for noise subspace.
      • WA Multiscale Peak Detection—Use this VI to detect peaks or valleys in an offline signal.
      • TFA Dual Window—In previous versions, this VI contains the transform info and expansion info outputs. In this version, these outputs are replaced by the analysis info and synthesis info outputs.
      • Dual Window—In previous versions, this Express VI contains the transform info and expansion info outputs. In this version, these outputs are replaced by the analysis info and synthesis info outputs.
      • TFA Read from File, TSA Read from File, and WA Read from File—These VIs contain the number of rows, start of read offset, and delimiters inputs. Use the number of rows input to specify the maximum number of rows in a spreadsheet text file. Use the start of read offset input to specify the position in the file, measured in rows, to begin reading. Use the delimiters input to specify an array of strings used to separate fields in a spreadsheet text file.
      • WA Arbitrary Path Reconstruction—In previous versions, this VI contains the source input. In this version, this input is replaced by the source coefficients input. Use the source coefficients input to specify the coefficients for reconstructing a time waveform.
    Refer to the LabVIEW Help for more information about using these VIs.
    The computer you are using must meet the following minimum system requirements to run the Advanced Signal Processing Toolkit:
    • 200 MB free disk space
    • LabVIEW 2010 Full or Professional Development System
    You can run the Advanced Signal Processing Toolkit on the following operating systems:
    • Windows XP (32-bit)
    Note: The Advanced Signal Processing Toolkit runs as a 32-bit application on all operating systems. This toolkit does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    You can install all of your LabVIEW products—including the Advanced Signal Processing Toolkit—using the LabVIEW 2010 Platform DVDs. You can find installation instructions for the Advanced Signal Processing Toolkit along with activation instructions in the following locations:
    • LabVIEW 2010 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2010 Platform DVDs, refer to the National Instruments Web site.
    Note: If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.Activation Notice
    To activate the Advanced Signal Processing Toolkit, use the serial number you received with the software kit. You can find your serial number on the product packing slip or on the shipping label. The serial number activates the LabVIEW Advanced Signal Processing Toolkit and the LabVIEW Digital Filter Design Toolkit.
    Your purchase of the Advanced Signal Processing Toolkit enables you to use the LabWindows™/CVI™ Advanced Signal Processing Toolkit. To request the installation media for the LabWindows/CVI Advanced Signal Processing Toolkit, contact NI.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about using the Advanced Signal Processing Toolkit.
    You can access the examples for the Time Frequency Analysis Tools, the Time Series Analysis Tools, and the Wavelet Analysis Tools by selecting Help»Find Examples to display the NI Example Finder and then navigating to the Toolkits and Modules»Time Frequency Analysis, Toolkits and Modules»Time Series Analysis, and Toolkits and Modules»Wavelet Analysis folders, respectively. You also can click the Find Examples link in the Examples section of the Getting Started window to display the NI Example Finder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Time Frequency Analysis Tools, the Time Series Analysis Tools, and the Wavelet Analysis Tools in the labview\examples\time frequency analysis, labview\examples\time series analysis, and labview\examples\wavelet analysis folders, respectively.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Advanced Signal Processing Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2010 Advanced Signal Processing Toolkit. If you have a bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the Advanced Signal Processing Toolkit.
    Bug IDFixed Issue
    148996The TSA MUSIC Spectrum VI returns incorrect results for a multiple-tone pure signal
    215043WA WP Best Tree VI does not return the best tree in some corner cases
    215835Control values in ASPT Express VIs are not shown with Contrast Black OS color scheme
    Important Information
    © 2010 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-3-27 09:28
