查看: 4606|回复: 0
[LV工具模块] LabVIEW 2015 Advanced Signal Processing Toolkit Win64ENG LabVIEW2015高级信号处理工具包ASPT2015-64 64位Windows英语测试版
    昨天 10:57
  • 签到天数: 3732 天
    连续签到: 59 天
    发表于 2020-7-12 20:25:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ASPT工具包,在2009到2017年版本之间,有64位的测试版,但是NI官方一直到APST2018才正式发布64位版本。我方视觉论坛提供了ASPT2009-APST2017的64位版本下载。具体的可在本论坛搜索相应的版本。
    LabVIEW高级信号处理工具包是一组软件工具,可用于执行时频分析、时序分析和小波分析。
    LabVIEW高级信号处理工具包是LabVIEW的一个附加软件,提供有时频分析、时序分析和小波分析工具。该附加工具内含LabVIEW数字滤波器设计工具包,您可单独购买这一工具包。为了有效地提取信号隐藏的信息,应选择适当的分析工具。您可以将时频分析工具用于具有缓慢变化的光谱内容的进化信号,用于静止信号的时间序列分析工具,以及用于描述短时事件的进化信号和瞬态信号的小波分析工具。您还可以将分析代码部署到NI实时嵌入式硬件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    ASPT2015-64.txt (228 Bytes, 下载次数: 3, 售价: 10 圆)
    LabVIEW 2015 Advanced Signal Processing Toolkit (64-bit) Readme
    June 2015
    Note: The software technology available on NI Labs is experimental and has not yet been released for large-scale commercial use or fully tested by NI. Refer to ni.com/labs for more information about NI Labs products.
    The LabVIEW 2015 Advanced Signal Processing Toolkit (64-bit) is an NI Labs product. This file contains information to introduce you to the Advanced Signal Processing Toolkit (64-bit). This file also provides you with help resources you can use while working with the Advanced Signal Processing Toolkit (64-bit). The file contains the following information that you need to understand.
    Activation Notice
    The Advanced Signal Processing Toolkit (64-bit) provides VIs for time frequency analysis, time series analysis, and wavelet analysis.
    Use the Time Frequency Analysis VIs to transform a time domain signal to a linear or quadratic time-frequency domain representation. You can extract useful information from the time-frequency domain representation of a signal, or you can process a time-frequency domain representation and reconstruct a time domain signal.
    Use the Time Series Analysis VIs to perform preprocessing, statistical analysis, correlation analysis, spectrum estimation, and model estimation on a univariate or multivariate (vector) time series. You can extract useful information from the time series with different analysis methods for different applications.
    Use the Wavelet Analysis VIs to perform transforms and inverse transforms between a signal and the wavelet coefficients of the signal. You can use the Feature Extraction VIs to perform denoising, detrending, probability density function estimation, peak detection, edge detection, and ridge detection on a 1D or 2D signal.
    In addition to the system requirements for the LabVIEW Development System, the Advanced Signal Processing Toolkit (64-bit) has the following requirements:
    • LabVIEW 2015 Full or Professional Development System (64-bit)
    • At least 200 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015.
    You can install the Advanced Signal Processing Toolkit (64-bit) by downloading and running the LabVIEW 2015 (64-bit) Advanced Signal Processing Toolkit Installer from ni.com/labs.
    Activation Notice
    The Advanced Signal Processing Toolkit (64-bit) relies on licensing activation. You must activate a valid LabVIEW 2015 Advanced Signal Processing Toolkit (32-bit) license in order to activate your copy of the Advanced Signal Processing Toolkit (64-bit) after the evaluation period expires.
    Refer to the Activation Instructions for National Instruments Software, which are available in your LabVIEW software kit, for more information about licensing in LabVIEW.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help in LabVIEW, for information about the Advanced Signal Processing Toolkit (64-bit).
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. The following table lists the examples for the Advanced Signal Processing Toolkit (64-bit) and the directory which contains the examples.
    ExamplesDirectory
    Time Frequency Analysislabview\examples\Time Frequency Analysis
    Time Series Analysislabview\examples\Time Series Analysis
    Wavelet Analysislabview\examples\Wavelet Analysis
    You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You cannot run the following example VIs in the Advanced Signal Processing Toolkit (64-bit):
    • Online Pitch Shifting.vi
    • Voice Enhancement.vi
    • Group Delay.vi
    • Online Spectrogram Monitoring (Sound Card).vi
    • Beam Crack Detection.vi
    • Modal Analysis of a Plate.vi
    • Bispectrum Analysis.vi
    Using NI Launcher
    Finding All Programs
    LabVIEW Advanced Signal Processing Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    LabVIEW Advanced Signal Processing Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the Advanced Signal Processing Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    LabWindows™/CVI™cvi_lifecycle
    © 2010–2015 National Instruments. All rights reserved.
    GMT+8, 2025-12-5 06:56
