查看: 3124|回复: 0
[LV工具模块] LabVIEW 2016 Advanced Signal Processing Toolkit Win32ENG LabVIEW2016高级信号处理工具包ASPT2016 32位Windows英语版
    前天 16:03
    发表于 2020-7-12 20:28:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ASPT工具包,在2009到2017年版本之间,有64位的测试版,但是NI官方一直到APST2018才正式发布64位版本。我方视觉论坛提供了ASPT2009-APST2017的64位版本下载。具体的可在本论坛搜索相应的版本。
    LabVIEW高级信号处理工具包是一组软件工具,可用于执行时频分析、时序分析和小波分析。
    LabVIEW高级信号处理工具包是LabVIEW的一个附加软件,提供有时频分析、时序分析和小波分析工具。该附加工具内含LabVIEW数字滤波器设计工具包,您可单独购买这一工具包。为了有效地提取信号隐藏的信息,应选择适当的分析工具。您可以将时频分析工具用于具有缓慢变化的光谱内容的进化信号,用于静止信号的时间序列分析工具,以及用于描述短时事件的进化信号和瞬态信号的小波分析工具。您还可以将分析代码部署到NI实时嵌入式硬件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
    EXE版:
    ZIP版:
    EXE版:
    ZIP版:
    ASPT2016.txt (527 Bytes, 下载次数: 5, 售价: 10 圆)
    LabVIEW 2016 Advanced Signal Processing Toolkit Readme
    June 2016
    This file contains important information about the LabVIEW 2016 Advanced Signal Processing Toolkit, including system requirements, installation instructions, and known issues.
    Activation Notice
    The Advanced Signal Processing Toolkit provides VIs for time frequency analysis, time series analysis, wavelet analysis, and system identification.
    Use the Time Frequency Analysis VIs to transform a time domain signal to a linear or quadratic time-frequency domain representation. You can extract useful information from the time-frequency domain representation of a signal, or you can process a time-frequency domain representation and reconstruct a time domain signal.
    Use the Time Series Analysis VIs to perform preprocessing, statistical analysis, correlation analysis, spectrum estimation, and model estimation on a univariate or multivariate (vector) time series. You can extract useful information from the time series with different analysis methods for different applications.
    Use the Wavelet Analysis VIs to perform transforms and inverse transforms between a signal and the wavelet coefficients of the signal. You can use the Feature Extraction VIs to perform denoising, detrending, probability density function estimation, peak detection, edge detection, and ridge detection on a 1D or 2D signal.
    Use the System Identification VIs to preprocess raw data from a dynamic system and develop a model that reflects the behavior of that system. You can analyze the response of a dynamic system to a certain stimulus.
    The Advanced Signal Processing Toolkit also provides the System Identification Assistant. Use the System Identification Assistant to identify the characteristics of a system through signal processing and mathematics. Refer to the System Identification Assistant Readme for important information about the System Identification Assistant, including system requirements, installation instructions, and known issues.
    In addition to the system requirements for the LabVIEW Development System, the Advanced Signal Processing Toolkit has the following requirements:
    • LabVIEW 2016 Full or Professional Development System (32-bit)
    • At least 600 MB of disk space
    • (System Identification Assistant) SignalExpress
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2016.
    The Advanced Signal Processing Toolkit supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Supported NI Real-Time Operating Systems
    The Advanced Signal Processing Toolkit supports most NI real-time operating systems (RTOSes).
    RTOSSupport
    Phar Lap ETS
    NI Linux Real-Time (ARM-based)
    NI Linux Real-Time (Intel x64-based)
    VxWorks
    For information about which RTOS your target uses, refer to the specific RT target hardware documentation or the NI website.
    You can install all of your LabVIEW products—including the Advanced Signal Processing Toolkit—using the LabVIEW 2016 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    Installation Instructions for the System Identification Assistant
    To install the System Identification Assistant, you must install SignalExpress before you install the Advanced Signal Processing Toolkit. Refer to the System Identification Assistant Readme for additional installation instructions for the System Identification Assistant.
    LabVIEW 2016 Advanced Signal Processing Toolkit Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, the Advanced Signal Processing Toolkit drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. LabVIEW 2016 Advanced Signal Processing Toolkit and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2016 Advanced Signal Processing Toolkit to an unsupported OS. Additionally, after installing the LabVIEW 2016 Advanced Signal Processing Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Activation Notice
    To activate the Advanced Signal Processing Toolkit, use the serial number you received with the software kit. You can find your serial number on the product packing slip or on the shipping label. The serial number activates the LabVIEW Advanced Signal Processing Toolkit, the LabVIEW System Identification Assistant, and the LabVIEW Digital Filter Design Toolkit.
    Your purchase of the Advanced Signal Processing Toolkit enables you to use the LabWindows™/CVI™ Advanced Signal Processing Toolkit. To request the installation media for the LabWindows/CVI Advanced Signal Processing Toolkit, contact NI.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2016 Advanced Signal Processing Toolkit.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Advanced Signal Processing Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. The following table lists the examples for the Advanced Signal Processing Toolkit and the directory which contains the examples.
    ExamplesDirectory
    Time Frequency Analysislabview\examples\Time Frequency Analysis
    Time Series Analysislabview\examples\Time Series Analysis
    Wavelet Analysislabview\examples\Wavelet Analysis
    System Identificationlabview\examples\System Identification
    You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2005–2016 National Instruments. All rights reserved.
    375335B-01
    GMT+8, 2026-2-25 02:40
