查看: 2986|回复: 0
[LV工具模块] LabVIEW 2011 Desktop Execution Trace Toolkit Win32ENG LabVIEW2011桌面执行跟踪工具包DETT2011
    前天 16:03
    发表于 2020-7-13 23:36:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    DETT2015版本之前的版本,仅适用32位的LabVIEW,DETT2016版本之后的版本,则32位和64位同时适配,但是仅一个安装文件,不另外区分安装版本。
    LabVIEW桌面执行跟踪工具包可以帮助您执行高级调试所需的动态代码分析。
    LabVIEW桌面执行跟踪工具包可以在运行时跟踪LabVIEW VI在Windows系统中的执行情况,以检测和定位代码中可能会影响性能或导致意外行为的问题。该工具包提供了VI事件、队列操作、参考泄漏、内存分配、未处理的错误和子VI执行的时间顺序图。借助这个工具包,即可根据LabVIEW程序的框图,通过编程方式生成用户定义的事件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
    EXE版:
    ZIP版:
    EXE版:
    ZIP版:
    DETT2011.txt (529 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2011 Desktop Execution Trace Toolkit for Windows Readme
    Version 11.0.0
    June 2011
    This file contains important information about the LabVIEW Desktop Execution Trace Toolkit for Windows. This file also provides you with help resources you can use while working with the Desktop Execution Trace Toolkit.
    The LabVIEW Desktop Execution Trace Toolkit for Windows captures execution data from LabVIEW applications running on the desktop. The toolkit displays the data it captures, called trace data, as events in a table view that you can browse, save, or export to a text file. For each execution event, the table view displays the type of event, the time the event occurs, the VI in which the event occurs, and any additional details that are available. Use trace data to debug and optimize large LabVIEW applications, including those with multiple loops, client-server architectures, dynamically loaded VIs, and so on.
    To run the Desktop Execution Trace Toolkit, National Instruments recommends that your system meets the following requirements:
    • LabVIEW 8.6.1 Base, Full, or Professional Development System or later
      Note  LabVIEW SignalExpress does not support the 64-bit versions of LabVIEW.
    • 1 GB of memory
    • Pentium 4 processor or equivalent
      • Windows XP SP2 (32-bit) or later
    The LabVIEW Desktop Execution Trace Toolkit for Windows installer does not support Windows 2000/NT/Me/98/95 or the Windows Server non-R2 editions.
    You can install all of your LabVIEW products—including the Desktop Execution Trace Toolkit—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the Desktop Execution Trace Toolkit, along with activation instructions, in the following locations:
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Refer to the LabVIEW Desktop Execution Trace Toolkit for Windows Help by selecting Help»Launch Help in the Desktop Execution Trace Toolkit.
    Refer to the Getting Started with the LabVIEW Desktop Execution Trace Toolkit for Windows manual, by selecting Help»Getting Started Manual in the toolkit, for exercises that demonstrate how to open, configure, and execute trace sessions.
    You can find examples for the Desktop Execution Trace Toolkit in the labview\examples\Desktop Execution Trace directory.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2011 Desktop Execution Trace Toolkit.
    The following items are the IDs and titles of a subset of issues fixed for LabVIEW 2011 Desktop Execution Trace Toolkit for Windows. This table is not an exhaustive list of issues fixed in the current version of the Desktop Execution Trace Toolkit for Windows. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    280872Desktop Execution Trace Toolkit 2010 does not trace VI executions using LabVIEW 2010 when VI Server name is specified in local language
    214750Unable to find local application instances in new Trace Connection dialog box of Desktop Execution Trace Toolkit with LabVIEW 2009 on a dual byte foreign operating system
    © 2008–2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-25 02:41
