查看: 4175|回复: 0
[LV工具模块] LabVIEW 2012 Desktop Execution Trace Toolkit Win32ENG LabVIEW2012桌面执行跟踪工具包DETT2012
    前天 16:03
    发表于 2020-7-13 23:39:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    DETT2015版本之前的版本,仅适用32位的LabVIEW,DETT2016版本之后的版本,则32位和64位同时适配,但是仅一个安装文件,不另外区分安装版本。
    LabVIEW桌面执行跟踪工具包可以帮助您执行高级调试所需的动态代码分析。
    LabVIEW桌面执行跟踪工具包可以在运行时跟踪LabVIEW VI在Windows系统中的执行情况,以检测和定位代码中可能会影响性能或导致意外行为的问题。该工具包提供了VI事件、队列操作、参考泄漏、内存分配、未处理的错误和子VI执行的时间顺序图。借助这个工具包,即可根据LabVIEW程序的框图,通过编程方式生成用户定义的事件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
    EXE版:
    ZIP版:
    EXE版:
    ZIP版:
    DETT2012.txt (529 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2012 Desktop Execution Trace Toolkit for Windows Readme
    Version 12.0.0
    June 2012
    This file contains important information about the LabVIEW Desktop Execution Trace Toolkit for Windows, including installation instructions and known issues. This file also provides you with help resources you can use while working with the Desktop Execution Trace Toolkit.
    The LabVIEW Desktop Execution Trace Toolkit for Windows captures execution data from LabVIEW applications running on the desktop. The toolkit displays the data it captures, called trace data, as events in a table view that you can browse, save, or export to a text file. For each execution event, the table view displays the type of event, the time the event occurs, the VI in which the event occurs, and any additional details that are available. Use trace data to debug and optimize large LabVIEW applications, including those with multiple loops, client-server architectures, dynamically loaded VIs, and so on.
    In addition to the system requirements for the LabVIEW Development System, the Desktop Execution Trace Toolkit has the following requirements:
    • LabVIEW 2009 Base, Full, or Professional Development System (32-bit) or later
    • At least 1 GB of disk space
    • Pentium 4 processor or equivalent
      • Windows XP SP3 (32-bit) or later
    The LabVIEW Desktop Execution Trace Toolkit for Windows installer does not support Windows 2000/NT/Me/98/95 or the Windows Server non-R2 editions.
    You can install all of your LabVIEW products—including the Desktop Execution Trace Toolkit—using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments Web site.
    You can now save and load filters, which can be useful if you want to run the same trace multiple times, or if you know you always want to filter out certain events.
    In the Configure Displayed Events dialog box that appears when you click the Configure Filter button at the top right corner of the table view, use the Save and Load buttons to save and load filter configurations.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2012 Desktop Execution Trace Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2012 Desktop Execution Trace Toolkit for Windows. This table is not an exhaustive list of issues fixed in the current version of the Desktop Execution Trace Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    161344Deselecting all filters in the Configure Displayed Events dialog box causes no events to appear, as though filters were still applied
    170427Event types are difficult to find in the Find window
    321800DETT error message about VI Server could be better
    337766Desktop Trace Execution Toolkit showing hidden controls on New Trace Connection dialog box
    Refer to the LabVIEW Desktop Execution Trace Toolkit for Windows Help by selecting Help»Launch Help in the Desktop Execution Trace Toolkit.
    Refer to the Getting Started with the LabVIEW Desktop Execution Trace Toolkit for Windows manual, by selecting Help»Getting Started Manual in the toolkit, for exercises that demonstrate how to open, configure, and execute trace sessions.
    You can find examples for the Desktop Execution Trace Toolkit in the labview\examples\Desktop Execution Trace directory.
    © 2008–2012 National Instruments. All rights reserved.
    GMT+8, 2026-2-25 02:40
