查看: 3252|回复: 0
[LV工具模块] LabVIEW 2013 Desktop Execution Trace Toolkit Win32ENG LabVIEW2013桌面执行跟踪工具包DETT2013
    前天 16:03
    发表于 2020-7-13 23:43:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    DETT2015版本之前的版本,仅适用32位的LabVIEW,DETT2016版本之后的版本,则32位和64位同时适配,但是仅一个安装文件,不另外区分安装版本。
    LabVIEW桌面执行跟踪工具包可以帮助您执行高级调试所需的动态代码分析。
    LabVIEW桌面执行跟踪工具包可以在运行时跟踪LabVIEW VI在Windows系统中的执行情况,以检测和定位代码中可能会影响性能或导致意外行为的问题。该工具包提供了VI事件、队列操作、参考泄漏、内存分配、未处理的错误和子VI执行的时间顺序图。借助这个工具包,即可根据LabVIEW程序的框图,通过编程方式生成用户定义的事件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
    EXE版:
    ZIP版:
    EXE版:
    ZIP版:
    DETT2013.txt (529 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2013 Desktop Execution Trace Toolkit for Windows Readme
    Version 13.0.0
    June 2013
    This file contains important information about the LabVIEW Desktop Execution Trace Toolkit for Windows, including installation instructions, new features, and a partial list of bugs fixed for the Desktop Execution Trace Toolkit 2013.
    Caution  After you upgrade the Desktop Execution Trace Toolkit from a previous version to version 2013, the previous version will be uninstalled automatically, but you can still open the trace files saved by the previous versions in the LabVIEW 2013 Desktop Execution Trace Toolkit for Windows.
    The LabVIEW Desktop Execution Trace Toolkit for Windows captures execution data from LabVIEW applications running on the desktop. The toolkit displays the data it captures, called trace data, as events in a table pane that you can browse, save, or export to a text file. For each execution event, the table pane displays the type of event, the time the event occurs, the VI in which the event occurs, and any additional details that are available. Use trace data to debug and optimize large LabVIEW applications, including those with multiple loops, client-server architectures, dynamically loaded VIs, and so on.
    In addition to the system requirements for the LabVIEW Development System, the Desktop Execution Trace Toolkit has the following requirements:
    • LabVIEW 2010 Base, Full, or Professional Development System (32-bit) or later
    • At least 1 GB of disk space
    • Pentium 4 processor or equivalent
    You can install all of your LabVIEW products—including the Desktop Execution Trace Toolkit—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Desktop Execution Trace Toolkit Updates and Notifications
    New FeaturesUser Interface Enhancements
    The Desktop Execution Trace Toolkit includes the following user interface enhancements.
    • Use the new Getting Started dialog box on startup to learn about how to trace application instances in the Desktop Execution Trace Toolkit.
    • The Trace Data view no longer exists.
    • The table view includes the following changes:
      • The Filter Settings button on the View tab replaces the Configure Filter button in the top right corner of the table view.
      • The Reset Filter button on the View tab replaces the Clear Filter button in the top right corner of the table view.
      • The Search button on the View tab replaces the Find button in the top right corner of the table view.
      • The Desktop Execution Trace Toolkit does not support multiple tabs on the table pane. You can trace only one application instance in one trace. If you need to trace another application instance, click the New Trace button on the Home tab to open a new trace.
      • The Float, Auto Hide, and Close items on the tab shortcut menu no longer exist.
      • The following items on the table view shortcut menu no longer exist:
        • Change Display
        • Split Display
        • Clear Display
        • Remove Display
        • Filter
        • Display Refresh Off
        • Export Trace
        • Save Trace
      • Use the new Navigate to Call Chain VIs item on the shortcut menu of the table pane to navigate to the specific VI that you select from the call chain related to an event. LabVIEW also highlights the object related to the event when available.
      • Use the new Filter this VI from Display item on the shortcut menu of the table pane to hide the events that occur in the VI you selected.
      • Use the new Do Not Capture Events for this VI item on the shortcut menu of the table pane to prevent the toolkit from capturing the events that occur in the VI you selected.
      • Use the new Columns item on the shortcut menu of the table view to specify which columns the table pane displays.
      • You can scroll the mouse wheel to review the trace data on the table pane.
      • The table pane displays the trace data of the trace sessions you execute for an application instance in one display instead of in different views. Every time you click Start to execute a trace session, the Desktop Execution Trace Toolkit appends the trace data of the trace session to the current trace data on the table pane.
      • The Desktop Execution Trace Toolkit displays a bookmark, a green icon on the vertical scroll bar of the table pane, once you start executing a trace session. You can click the bookmarks to navigate to the first event of each trace session.
      • You can double-click an event on the table pane to navigate to the VI where a specific event occurs. LabVIEW highlights the object related to the event when available.
      • The new Highlight column displays whether the Desktop Execution Trace Toolkit can navigate to the related object for a specific event.
    • The Help view no longer exists.
    • The File menu includes the following changes:
      • The following items no longer exist:
        • New Trace
        • Save All
      • The Open item replaces the Load Trace item.
      • The Save item replaces the Save Trace item.
      • The Export item replaces the Export Trace item.
      • Use the new Options item to display the Options dialog box.
      • Use the items on the submenu of the new Help item to launch the LabVIEW Desktop Execution Trace Toolkit for Windows Help, display the Getting Started topic of the help, launch the NI Update Service, and display the splash screen for the Desktop Execution Trace Toolkit.
      • Select from the new Recent Files list to open one of the latest five execution trace files you opened in the Desktop Execution Trace Toolkit.
    • The Edit and View menus no longer exist.
    • The Tools menu no longer exists, and the Options item on this menu moves to the File menu.
    • The Help menu no longer exists. The items on this menu contain the following changes:
      • The Context Help and Display Welcome Page items no longer exist.
      • The Launch Help, Check for Updates, and About items move to the submenu of the Help item on the File menu.
      • The Getting Started item on the submenu of the Help item on the File menu replaces the Getting Started Manual item.
    • The toolbar buttons include the following changes:
      • The Start and Stop buttons move to the Home tab.
      • The New Trace button to display the New Trace Connection dialog box no longer exists. You can open a trace connection by specifying configurations in the Target Configuration section on the Home tab.
        Note  Use the New Trace button on the Home tab in the Desktop Execution Trace Toolkit to open a new trace instead of a trace connection.
      • The Capture Settings button on the Home tab replaces the Configure button. Click the arrow below Capture Settings to display the Capture Settings pull-down menu, in which you can quickly select the event types you want to trace. Click the Capture Settings image to display the Capture Settings dialog box, in which you can select the detailed events for the types you select from the Capture Settings pull-down menu.
      • The Split button on the View tab replaces the Split Display button. The Desktop Execution Trace Toolkit allows splitting the table pane to only two displays.
    • The New Trace Connection dialog box no longer exists. In the Desktop Execution Trace Toolkit, you can open a trace connection to both local and remote application instances by specifying configurations in the Target Configuration section on the Home tab.
    • The Capture Settings dialog box replaces the Configure Trace Session dialog box. Use the new Capture Settings dialog box to select the specific events for the types you select from the Capture Settings pull-down menu so that you can reduce the number of events that this toolkit captures from LabVIEW. Click the Capture Settings image on the Home tab to display this dialog box.
    • The Options dialog box includes the following changes:
      • Open this dialog box by selecting Options from the File menu instead of the Tools menu.
      • Use the new Restore to Default button to undo the changes you made in this dialog box.
      • On the General page, you can use the new Confirmations section to specify whether prompts appear when you close an unsaved trace, when you click the Reset Filter button on the View tab, or when you launch the Desktop Execution Trace Toolkit. The Display split mode and the Name format for new traces options no longer exist in this dialog box.
    • The Configure Displayed Events dialog box includes the following changes:
      • Open this dialog box by clicking the Filter Settings button on the View tab instead of the Tools menu.
      • You cannot launch this dialog box when the table pane does not display any event to filter.
      • When you select all the events in this dialog box, the Select All Events button changes to Deselect All Events.
      • The User-Defined Trace Events type replaces the User Logged Strings type.
      • The Errors page lists all the error codes that the Desktop Execution Trace Toolkit captured from LabVIEW. You can place a checkmark in a checkbox for an error code to display the event for a specific error.
      • Use the new User Events page to filter programmatically generated user events.
      • You can resize this dialog box.
    • Use the new Home tab to open a new trace connection and to execute a trace for an application instance. This tab contains the following new buttons:
      • Use the Clear button to clear all the trace data on the table pane.
      • Use the New Trace button to open a new trace.
    • The Desktop Execution Trace Toolkit now includes a View tab, which contains the following new buttons:
      • Use the Navigate button to navigate to the VI that generates a specific event. LabVIEW highlights the object related to the event when available.
      • Use the Reset Pane button to display the trace data in a single display.
      • Use the Auto Scroll button to scroll the display automatically to show the latest trace data.
      • Use the Options button to display the Options dialog box.
      • Use the Compare Traces button to launch the Compare Traces window, in which you can use to compare the events of two sessions in one trace file or in two different trace files.
    • The Desktop Execution Trace Toolkit now includes a Data tab, which contains the following new options:
      • Use the Maximum Events control to specify the number of events you want to keep in the Desktop Execution Trace Toolkit in order to limit the amount of memory the toolkit uses and avoid the toolkit running out of memory.
      • Use the When Exceed Limit control to specify whether the toolkit stops executing a trace or removes the oldest events from memory when the number of events that the toolkit captured reaches the value that you specified in the Maximum Events control. The default option is Discard Oldest, which allows you to trace an application instance indefinitely
      • Use the Enable Logging option to log the trace data to a log file while executing a trace session. After you select Discard Oldest from the When Exceed Limit control and place a checkmark for Enable Logging, you can also trace an application instance indefinitely without losing any trace data.
    • You can use the Minimize Tabs in the top right corner of the table pane to hide the tabs and display a larger table pane.
    • The Desktop Execution Trace Toolkit now includes a status indicator in the top right corner of the table pane to indicate whether this toolkit captured all the specified events from LabVIEW.
    • You can use the new Help button in the top right corner of the table pane to launch the LabVIEW Desktop Execution Trace Toolkit Help.
    • The Desktop Execution Trace Toolkit changes the icons of all the buttons.
    Other Enhancements
    The Desktop Execution Trace Toolkit includes the following additional enhancements:
    • On the Search bar, you can enter any part of a VI name, event type, or the text in the other columns on the table pane to search for the events you need to review. Use the asterisk (*) wildcard to return events that contain a certain string. Use the caret (^) regular expression to return events that start with a certain string. You can click the Search button on the View tab or press to display the Search bar.
    • Select Save from the File menu to save traces to execution trace (.det) files instead of trace tool data (.ttd) files. The Desktop Execution Trace Toolkit can also open the trace tool data (.ttd) files you saved in the previous versions.
    • The Getting Started with the Desktop Execution Trace Toolkit for Windows manual previously available as a PDF no longer exists. The content now resides in the LabVIEW Desktop Execution Trace Toolkit for Windows Help.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Desktop Execution Trace Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the Desktop Execution Trace Toolkit. This is not an exhaustive list of issues fixed in the current version of the Desktop Execution Trace Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    161339Desktop Execution Trace Toolkit can sometimes use the majority of the CPU resources while performing a trace.
    163410Arrow keys do not consistently navigate traced data.
    177094Desktop Execution Trace Toolkit does not launch when installed to a custom file path containing a double-byte character.
    281507Desktop Execution Trace Toolkit does not highlight the traced items under LabVIEW 2010 Japanese.
    283411Desktop Execution Trace Toolkit application becomes unresponsive while LabVIEW builds a stand-alone application.
    334034Mouse scroll wheel does not scroll the traced events.
    344626Some reference leaks not reported when a LabVIEW built stand-alone application is traced.
    346461Loading invalid filter setting configuration file does not report an error.
    374422Desktop Execution Trace Toolkit palette in LabVIEW reports license error if licensed through NI Volume License Manager.
    397917Improve error message when VI Server is not enabled in LabVIEW.
    Refer to the LabVIEW Desktop Execution Trace Toolkit for Windows Help, accessible by selecting File»Help»Launch Help, for more information about the Desktop Execution Trace Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Desktop Execution Trace folder to access the example. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the example for the Desktop Execution Trace Toolkit in the labview\examples\Desktop Execution Trace directory.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Desktop Execution Trace Toolkit for Windows Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Desktop Execution Trace Toolkit for Windows will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Desktop Execution Trace Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2008–2013 National Instruments. All rights reserved.
    GMT+8, 2026-2-25 02:43
