查看: 3020|回复: 0
[LV工具模块] LabVIEW 2009 VI Analyzer Toolkit Win32Eng LV2009VI分析仪工具包2009VIA
    前天 16:03
    发表于 2020-7-15 16:21:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW VI分析工具包用于进行静态代码分析,以提高LabVIEW代码的质量和可读性。
    LabVIEW VI分析仪工具包是一个LabVIEW附加软件,用于优化LabVIEW图形化代码。借助该工具,您可以配置超过90种内置测试,以便自动化审核代码和分析应用程序中所有VI的静态代码,或者您可以使用测试创建向导来自行创建测试程序。LabVIEW VI分析工具包提供的调试工具可帮助您避免使用可能会影响应用程序性能、功能和可维护性的编程技术。此外,您还可以要求开发团队采用高效的编程方法和代码风格,以确保代码的可读性和功能性。
    百度网盘下载(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
    EXE版:
    ZIP版:
    视觉论坛RAR版:
    EXE版:
    ZIP版:
    VIA2009.txt (600 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2009 VI Analyzer Toolkit Readme
    June 2009
    This file contains important last-minute information about the LabVIEW 2009 VI Analyzer Toolkit, including installation issues.
    Refer to the LabVIEW Module and Toolkit Compatibility Information page on ni.com for information about which version of the VI Analyzer Toolkit to install depending on your LabVIEW version and operating system. All versions of the toolkit are available on the installation CD.
    Contents
    Installation
       Version 2009
       Version 1.1.1 for LabVIEW 8.6 (Windows Vista/XP/2000)
       Version 1.1 for LabVIEW 8.x (Windows, Mac OS X, Linux)
       Version 1.0 for LabVIEW 7.x (Windows, Mac OS X, Linux)
    Using the VI Analyzer Toolkit
    Changes from Version 1.1 to 1.1.1 (Windows)
    Note about Spell Check
    InstallationVersion 2009
    (Windows Vista/XP/2000) You can install all of your LabVIEW products—including the VI Analyzer Toolkit—using the LabVIEW 2009 Platform DVDs. You can find installation instructions for the VI Analyzer Toolkit along with activation instructions in the following locations:
    • LabVIEW 2009 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 Platform DVDs, refer to the National Instruments Web site.
    (Mac OS X) Complete the following steps to install the LabVIEW 2009 VI Analyzer Toolkit for Mac OS X.
    Note  Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • Insert and browse to the LabVIEW 2009 VI Analyzer Toolkit installation CD and open LabVIEW2009VIAnalyzer.mpkg located under the LabVIEW_2009\Mac OS X directory.
    Complete the following steps to uninstall the LabVIEW 2009 VI Analyzer Toolkit for Mac OS X.
    • During installation, the VI_Analyzer_2009_Uninstall.sh uninstallation script is created in the same folder as your version of LabVIEW.
    • Drag the uninstall script to the prompt in a Terminal Window. Press Return and follow the instructions provided by the script.
    • After uninstalling the VI Analyzer Toolkit, you must manually delete the uninstallation script.
    (Linux) Complete the following steps to install the LabVIEW 2009 VI Analyzer Toolkit for Linux.
    • Insert the LabVIEW 2009 VI Analyzer Toolkit installation CD. Use mount /mnt/cdrom to mount the CD. On some systems, the CD mounts automatically.
    • To change the current directory to the mounted CD, enter the following command:
      cd /mnt/cdrom
      ./INSTALL
      If you encounter the following message: "bad interpreter: Permission denied", the CD may not have mounted with executable permissions. To work around this, enter the following command:
      /bin/sh ./INSTALL
    VI Analyzer Toolkit 1.1.1 is compatible with LabVIEW 8.6 on Windows. If you want to use the VI Analyzer Toolkit on Mac OS X or Linux, you must install VI Analyzer Toolkit 1.1. Refer to the Version 1.1 for LabVIEW 8.x section for information about installing VI Analyzer Toolkit 1.1.
    (Windows Vista/XP/2000) You can install all of your LabVIEW products—including LabVIEW and the VI Analyzer Toolkit—using the LabVIEW 8.6 Platform DVDs. Refer to the LabVIEW DVD Installation Instructions or the LabVIEW Release Notes, which are available in your LabVIEW box, for information about the LabVIEW Platform DVDs.
    Complete the following steps to install the VI Analyzer Toolkit 1.1.1 for Windows from the LabVIEW VI Analyzer Toolkit installation CD.
    • Insert the LabVIEW VI Analyzer Toolkit 1.1.1 installation CD and follow the instructions that appear on the screen.
    • Activate your LabVIEW products using the NI License Manager.
    You must install VI Analyzer Toolkit 1.1 to work with LabVIEW 8.0, 8.2, or 8.5 on Windows. You must install VI Analyzer Toolkit 1.1 to work with LabVIEW 8.0, 8.2, 8.5, or 8.6 on Mac OS X or Linux.
    (Windows Vista/XP/2000) Complete the following steps to install the VI Analyzer Toolkit 1.1 for Windows.
    • Insert the LabVIEW VI Analyzer Toolkit 1.1.1 installation CD and browse to the LabVIEW_8.0-8.5\Windows directory.
    • Double-click setup.exe and follow the instructions that appear on the screen.
    (Mac OS X) Complete the following steps to install the VI Analyzer Toolkit 1.1 for Mac OS X.
    • Insert and browse to the LabVIEW VI Analyzer Toolkit 1.1 installation CD and open VI_Analyzer1.1.pkg located under the LabVIEW_8.0-8.5\Mac OS X directory.
    • Select Continue to run a program to determine if the VI Analyzer Toolkit can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Select Destination dialog box.
    • In the Select Destination dialog box, click Choose and select the version of LabVIEW (8.0 or later) you want to install the VI Analyzer to.
    Note  You must select the Choose button for a proper installation. If you do not select a location where LabVIEW is installed or you select a non-compatible version of LabVIEW, the installation will not complete.
    • After you select the destination directory, click Continue to complete the installation.
    Complete the following steps to uninstall the VI Analyzer Toolkit 1.1 for Mac OS X.
    • During installation, the VI_Analyzer_Uninstall.sh uninstallation script is created in the same folder as your version of LabVIEW.
    (Linux) Complete the following steps to install the VI Analyzer Toolkit 1.1 for Linux.
    • Use mount /mnt/cdrom to mount the CD. On some systems, the CD is mounted automatically.
    • Enter the following command to navigate to the LabVIEW directory:
      cd /usr/local/natinst/LabVIEW-8.0
    Note  The preceding command assumes that you installed LabVIEW 8.0. Modify the version if you installed a different version of LabVIEW.
    • Enter the following command to extract the toolkit to the LabVIEW folder:
      tar xvf /mnt/cdrom/LabVIEW_8.0-8.5/Linux/VIAnalyzer1_1Linux.tar
    • Enter the following command to navigate to the Example Finder directory:
      cd "/usr/local/natinst/share/example finder/1.0"
    • Enter the following command to extract the Example Finder files:
      tar xvf /mnt/cdrom/LabVIEW_8.0-8.5/Linux/VIAn1_1ExFndrLinux.tar
    You must install VI Analyzer Toolkit 1.0 to work with LabVIEW 7.x. The installation process for version 1.0 is very similar to the process for version 1.1 except that you launch the installer from the appropriate OS directory under the LabVIEW_7.x directory of your CD.
    After you install the VI Analyzer Toolkit, select Tools»VI Analyzer»Analyze VIs to run the VI Analyzer. You also can use the VI Analyzer VIs located on the Functions palette. Refer to the LabVIEW Help and the LabVIEW VI Analyzer Toolkit User Guide for more information about using the VI Analyzer Toolkit.
    • The VI Analyzer functionality is now available in LabVIEW if you install and activate an add-on that contains VI Analyzer tests.
    • With the VI Analyzer Toolkit 1.1, you can make VIs you write with the VI Analyzer VIs easily accessible from two locations:
      • Accessible from the Tools»VI Analyzer»Quick Launch menu—Copy the VI to the labview\project\VI Analyzer\Quick Launch directory
      • Visible in the VI Analyzer user interface—Copy the VIs to the labview\project\VI Analyzer\_tests directory
      These paths have changed in version 1.1.1:
      • Accessible from the Tools»VI Analyzer»Quick Launch menu—Copy the VI to the labview\project\_VI Analyzer\Quick Launch directory
      • Visible in the VI Analyzer user interface—Copy the VIs to the labview\project\_VI Analyzer\_tests directory
    For a listing of the copyrights, conditions, and disclaimers regarding the automatically generated inflection database, refer to the agid-readme.txt file.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2009 VI Analyzer toolkit.
    IDLegacy IDFixed Issue
    894963QQBTRF2Error 7 when analyzing a VI with a missing typedef constant.
    893833PRDICF2Coercion Dots: Failure on Merge Signals Primitive.
    895913R2D33F2Spell Check: Failure when checking a list of URLs delimited by carriage returns.
    107854-VI Analyzer installer on a Mac does not create example finder directory.
    © 2005-2009 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-25 03:03
