查看: 2925|回复: 0
[LV工具模块] LabVIEW 2011 VI Analyzer Toolkit Win32Eng LV2011VI分析仪工具包2011VIA
    前天 16:03
    发表于 2020-7-15 16:44:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW VI分析工具包用于进行静态代码分析,以提高LabVIEW代码的质量和可读性。
    LabVIEW VI分析仪工具包是一个LabVIEW附加软件,用于优化LabVIEW图形化代码。借助该工具,您可以配置超过90种内置测试,以便自动化审核代码和分析应用程序中所有VI的静态代码,或者您可以使用测试创建向导来自行创建测试程序。LabVIEW VI分析工具包提供的调试工具可帮助您避免使用可能会影响应用程序性能、功能和可维护性的编程技术。此外,您还可以要求开发团队采用高效的编程方法和代码风格,以确保代码的可读性和功能性。
    百度网盘下载(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
    EXE版:
    ZIP版:
    EXE版:
    ZIP版:
    VIA2011.txt (527 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2011 VI Analyzer Toolkit Readme
    Version 11.0.0
    June 2011
    This file contains important information about the LabVIEW 2011 VI Analyzer Toolkit, including installation instructions and known issues. This file also provides you with help resources you can use while working with the VI Analyzer Toolkit.
       Mac OS X
       Linux
    Using the VI Analyzer Toolkit
    Additions to the LabVIEW Help
    Using Spell Check Word List
    The VI Analyzer Toolkit has the following requirement:
    • LabVIEW 2011 Base, Full, or Professional Development System (32-bit)
    Refer to the National Instruments Web site for more information about which version of the VI Analyzer Toolkit to install depending on your LabVIEW version and operating system.
    Installation InstructionsWindows
    You can install all of your LabVIEW products—including the VI Analyzer Toolkit—using the LabVIEW 2011 Platform DVDs. Find the installation instructions for the VI Analyzer Toolkit, along with activation instructions, in the following locations:
    • LabVIEW Release Notes, which is available in your LabVIEW software kit.
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Mac OS X
    Complete the following steps to install the LabVIEW 2011 VI Analyzer Toolkit on Mac OS X.
    Note  Disable any automatic virus detection programs before you install because some virus detection programs may interfere with the installer. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • Insert and browse to the LabVIEW 2011 VI Analyzer Toolkit installation CD.
    • Open LabVIEW2011VIAnalyzer.mpkg, located in the LabVIEW_2011\Mac OS X directory.
    Complete the following steps to uninstall the LabVIEW 2011 VI Analyzer Toolkit on Mac OS X.
    • During installation, the VI_Analyzer_2011_Uninstall.sh uninstallation script is created in the VI Analyzer directory. Drag the VI_Analyzer_2011_Uninstall.sh uninstallation script to the prompt in a Terminal window.
    • Press Return and follow the instructions provided by the script.
    • After uninstalling the VI Analyzer Toolkit, manually delete the uninstallation script.
    Linux
    Complete the following steps to install the LabVIEW 2011 VI Analyzer Toolkit on Linux.
    • Insert the LabVIEW 2011 VI Analyzer Toolkit installation CD.
    • From the Terminal window, navigate to the LabVIEW_2011/Linux directory on the installation CD.
      ./INSTALL
    Note  If you encounter a message of bad interpreter: Permission denied, the CD might not have mounted with executable permissions. To work around this issue, enter the following command:
    /bin/sh ./INSTALL
    After you install the VI Analyzer Toolkit, select Tools»VI Analyzer»Analyze VIs in LabVIEW to run the VI Analyzer. You also can use the VI Analyzer VIs, located on the Functions palette. Refer to the LabVIEW Help and the LabVIEW VI Analyzer Toolkit User Guide for more information about using the VI Analyzer Toolkit.
    The VIAn Get Tests VI includes a Test Descriptions output that returns an array of the test descriptions, which correspond to the names in Test Names.
    For a list of the copyrights, conditions, and disclaimers regarding the word list used in the automatically generated inflection database, refer to the AGID_4.0_notice.pdf and AGID_4.0_license.pdf files in the Licenses directory on your VI Analyzer Toolkit installation media.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2011 VI Analyzer toolkit.
    The following table contains the IDs and titles of a subset of issues fixed in the LabVIEW 2011 VI Analyzer Toolkit. This table is not an exhaustive list of issues fixed in the current version of the VI Analyzer Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    213588Updates to Icon Size and Border test
    218503VIAnTest - Parallelizable Loops Tests Should Include an Option to Ignore Nested Loops for "Safe to Parallelize" Check
    239902VI Saved Version Test Appears to Be Failing VIs Saved in Released LabVIEW 2010
    242787Improve Context Help of Spell Check Test Configuration Checkboxes
    293177Add SCC Exclusion Folder Check to VI Analyzer
    © 2005-2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-25 02:28
