查看: 2903|回复: 0
[LV工具模块] LabVIEW 2013 VI Analyzer Toolkit Win32Eng LV2013VI分析仪工具包2013VIA
    前天 16:03
    发表于 2020-7-15 16:54:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW VI分析工具包用于进行静态代码分析,以提高LabVIEW代码的质量和可读性。
    LabVIEW VI分析仪工具包是一个LabVIEW附加软件,用于优化LabVIEW图形化代码。借助该工具,您可以配置超过90种内置测试,以便自动化审核代码和分析应用程序中所有VI的静态代码,或者您可以使用测试创建向导来自行创建测试程序。LabVIEW VI分析工具包提供的调试工具可帮助您避免使用可能会影响应用程序性能、功能和可维护性的编程技术。此外,您还可以要求开发团队采用高效的编程方法和代码风格,以确保代码的可读性和功能性。
    百度网盘下载(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,EXE为NI当年发行版,ZIP为NI后期重新压制版本。
    EXE版:
    ZIP版:
    EXE版:
    ZIP版:
    VIA2013.txt (527 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2013 VI Analyzer Toolkit Readme
    Version 13.0.0
    June 2013
    This file contains important information about the LabVIEW VI Analyzer Toolkit, including installation instructions, new features, a partial list of bugs fixed for LabVIEW 2013 VI Analyzer Toolkit, and known issues.
    Using the VI Analyzer Toolkit
    Using Spell Check Word List
    In addition to the system requirements for the LabVIEW Development System, the VI Analyzer Toolkit has the following requirement:
    • LabVIEW 2013 Base, Full, or Professional Development System (32-bit)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    (Windows) You can install all of your LabVIEW products—including the VI Analyzer Toolkit—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    (OS X) Complete the following steps to install the VI Analyzer Toolkit on OS X:
    Note  Disable any automatic virus detection programs before you install because some virus detection programs may interfere with the installer. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • Insert and browse to the LabVIEW 2013 VI Analyzer Toolkit installation CD.
    • Open LabVIEW2013VIAnalyzer.mpkg, located in the LabVIEW_2013\Mac OS X directory.
    Complete the following steps to uninstall the VI Analyzer Toolkit on OS X:
    • During installation, the VI_Analyzer_2013_Uninstall.sh uninstallation script is created in the VI Analyzer directory. Drag the VI_Analyzer_2013_Uninstall.sh uninstallation script to the prompt in a Terminal window.
    • Press Return and follow the instructions provided by the script.
    • After uninstalling the VI Analyzer Toolkit, manually delete the uninstallation script.
    (Linux) Complete the following steps to install the VI Analyzer Toolkit on Linux:
    • Insert the LabVIEW 2013 VI Analyzer Toolkit installation CD.
    • From the Terminal window, navigate to the LabVIEW_2013/Linux directory on the installation CD.
      ./INSTALL
    Note  If you encounter a message of bad interpreter: Permission denied, the CD might not have mounted with executable permissions. To work around this issue, enter the following command:
    /bin/sh ./INSTALL
    VI Analyzer Toolkit Updates and Notifications
    The LabVIEW 2013 VI Analyzer Toolkit includes three new Block Diagram tests:
    TestDescriptionTest Category
    In Place Element Structure UsageChecks whether you can avoid unnecessary memory allocations by enclosing sections of code in an In Place Element Structure. You can use this structure to operate on a data element within an array, cluster, variant, or waveform without requiring the LabVIEW compiler to copy data values and maintain those values in memory.Performance
    Code SimplificationChecks for unnecessarily complex code and, if found, suggests simplified code that performs the same operation.Style
    Array Sum and Product OverflowChecks the size of the output data types of sum and product operations on arrays to determine if a risk of overflow exists and suggests a larger data type, if necessary.Warnings
    After you install the VI Analyzer Toolkit, select Tools»VI Analyzer»Analyze VIs in LabVIEW to run the VI Analyzer. You also can use the VI Analyzer VIs, located on the Functions palette. Refer to the LabVIEW Help and the LabVIEW VI Analyzer Toolkit User Guide for more information about using the VI Analyzer Toolkit.
    For a list of the copyrights, conditions, and disclaimers regarding the word list used in the automatically generated inflection database, refer to the AGID_4.0_notice.pdf and AGID_4.0_license.pdf files in the Licenses directory on the VI Analyzer Toolkit installation media.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the VI Analyzer Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the VI Analyzer Toolkit. This is not an exhaustive list of issues fixed in the current version of the VI Analyzer Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    364011Panel Size and Position test sometimes returns false failures with certain monitor configurations
    361578Overlapping Controls test should ignore controls inside typedef clusters
    350191Dialog Controls test should have an option to ignore VIs that do not have system-colored front panels
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the VI Analyzer Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the VI Analyzer Toolkit are located in the labview\examples\VIAnalyzer directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW VI Analyzer Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW VI Analyzer Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of VI Analyzer Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2005–2013 National Instruments. All rights reserved.
    GMT+8, 2026-2-25 02:28
