查看: 4327|回复: 0
[LV工具模块] LabVIEW 2018 VI Analyzer Toolkit Win64Eng LV2018VI分析仪工具包2018VIA-64Win
    前天 16:03
    发表于 2020-7-15 17:27:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    VIA分析仪工具包从2016版开始,区分32位和64位版本,在2015VIA之前的版本,则只有32位Windows版本。
    LabVIEW VI分析工具包用于进行静态代码分析,以提高LabVIEW代码的质量和可读性。
    LabVIEW VI分析仪工具包是一个LabVIEW附加软件,用于优化LabVIEW图形化代码。借助该工具,您可以配置超过90种内置测试,以便自动化审核代码和分析应用程序中所有VI的静态代码,或者您可以使用测试创建向导来自行创建测试程序。LabVIEW VI分析工具包提供的调试工具可帮助您避免使用可能会影响应用程序性能、功能和可维护性的编程技术。此外,您还可以要求开发团队采用高效的编程方法和代码风格,以确保代码的可读性和功能性。
    百度网盘下载(限速,请开会员或使用破解限速工具):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服提取码: 请注册登录视觉论坛会员,购买附件查看
    VIA2018-64.txt (266 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2018 VI Analyzer Toolkit Readme
    March 2018
    This file contains important information about the LabVIEW 2018 VI Analyzer Toolkit, including system requirements, installation instructions, and known issues.
    New Features and Changes
    Using the VI Analyzer Toolkit
    Using Spell Check Word List
    VI Analyzer Enthusiasts Community Group
    In addition to the system requirements for the LabVIEW Development System, the VI Analyzer Toolkit has the following requirements:
    • LabVIEW 2018 Base, Full, or Professional Development System
    • At least 50 MB of disk space
    Note  The LabVIEW 2018 Professional Development System license activates the LabVIEW 2018 VI Analyzer Toolkit.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2018.
    The VI Analyzer Toolkit supports the following operating systems:
    WindowsWindows 10 (version 1709)/8.1 Update 11/7 SP12
    Windows Server 2012 R21
    Windows Server 2008 R2 SP12
    Note  In 2016 the LabVIEW VI Analyzer Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2018 VI Analyzer Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2018 VI Analyzer Toolkit to an unsupported OS. Additionally, after installing the LabVIEW 2018 VI Analyzer Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    macOSmacOS 10.12 or 10.13
    LinuxopenSUSE LEAP 42.2
    openSUSE LEAP 42.3
    Red Hat Enterprise Linux Desktop + Workstation 6.x
    Red Hat Enterprise Linux Desktop + Workstation 7.x
    CentOS 7
    Note  The LabVIEW 2018 VI Analyzer Toolkit for Linux is available in 64-bit only.
    (Windows)
    You can install all of your LabVIEW products—including the VI Analyzer Toolkit—using the LabVIEW 2018 Platform media.
    (macOS, Linux)
    The VI Analyzer Toolkit installs with the LabVIEW Professional Development System. Refer to the LabVIEW Media Readme for macOS/Linux for instructions on how to install the LabVIEW Professional Development System.
    If you use the LabVIEW Full Development System, complete the following steps to install the VI Analyzer Toolkit.
    Note  You must have the LabVIEW 2018 Professional Development System license to activate the LabVIEW 2018 VI Analyzer Toolkit.
    (macOS)
    • Insert the LabVIEW VI Analyzer Toolkit media for macOS/Linux and open NI LabVIEW 2018 VI Analyzer Toolkit 64-bit.pkg located under the macOS subdirectory.
    • Select Continue to run a program to determine if the VI Analyzer Toolkit can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Installation Type screen.
    • In the Installation Type screen, select Change Install Location to select the location where a compatible version of LabVIEW is installed. Otherwise, the installation will not complete.
    • After you select the installation location, continue to follow the instructions that appear on the screen.
    (Linux)
    • Insert the LabVIEW VI Analyzer Toolkit media for macOS/Linux and mount the installation media. On some systems, the media mounts automatically.
    • On the mounted media, find the VI Analyzer Toolkit installer in the Linux directory.
      sh ./INSTALL
      To uninstall the VI Analyzer Toolkit on Linux, enter the following command:
      sh ./UNINSTALL
    The LabVIEW 2018 VI Analyzer Toolkit introduces the following new features and changes.
    VI Analyzer Toolkit Tests
    The VI Analyzer Toolkit includes the following new tests:
    Block Diagram Tests
    • For Loop Error Handling—Returns a failure for a For Loop that does not implement proper error handling to account for zero iterations.
    General Tests
    • Auto Error Handling Enabled—Returns a failure for any VI with Automatic Error Handling enabled.
    • Control VI Type—Returns a failure if the Control VI Type does not match the user-specified type.
    The VI Analyzer Toolkit no longer includes the following tests:
    Block Diagram Tests
    • Node Density
    • Typedef Cluster Constants
    General Tests
    • Connected Pane Terminals
    Ignoring Test Failures
    You can ignore test failures for VIs and block diagram objects. When you ignore one or more tests for a particular object or a VI, the VI Analyzer will not return a failure for that object or VI for the specified test(s).
    To ignore a failure for an entire VI, create a free label on the block diagram of the VI and add the hashtag #via_ignore [test] to create a bookmark. The VI Analyzer ignores results from the VI Analyzer test you specify in [test]. You can specify multiple test names in the free label to ignore multiple tests. To ignore a failure for a block diagram object, attach the free label with the #via_ignore bookmark to the object whose failure you want to ignore.
    Support for Human-Readable Configuration Files
    The VI Analyzer Toolkit supports human-readable, XML-based configuration files (.viancfg). You cannot password-protect .viancfg configuration files. The VI Analyzer Toolkit supports loading legacy .cfg files, but you cannot save files in the .cfg format.
    Enhancements to VI Analyzer VIs
    The VI Analyzer VIs have the following changes:
    • VIAn Get Analysis Status VI—This VI includes the Abort Analysis input, which specifies whether to abort the analysis process when it is in progress.
    • VIAn Save Configuration File VI—This VI no longer includes the Configuration File Password input.
    • VIAn Add Password VI—This VI is no longer available. The VI Analyzer Toolkit does not support adding passwords to the VI Analyzer task password cache for password-protected VIs.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2018 VI Analyzer Toolkit.
    After you install the VI Analyzer Toolkit, select Tools»VI Analyzer»Analyze VIs in LabVIEW to run the VI Analyzer. You also can use the VI Analyzer VIs, located on the Functions palette. Refer to the LabVIEW Help and the LabVIEW VI Analyzer Toolkit User Guide for more information about using the VI Analyzer Toolkit.
    For a list of the copyrights, conditions, and disclaimers regarding the word list used in the automatically generated inflection database, refer to the AGID_4.0_notice.pdf and AGID_4.0_license.pdf files in the Licenses directory on the VI Analyzer Toolkit installation media.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the VI Analyzer Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the VI Analyzer Toolkit are located in the labview\examples\VI Analyzer Toolkit directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Visit ni.com/info and enter the Info Code ex8j59 to discuss the VI Analyzer Toolkit with other users.
    © 2003–2018 National Instruments. All rights reserved.
    375339D-01
    GMT+8, 2026-2-25 02:28
