查看: 3372|回复: 0
[LV工具模块] LabVIEW 2017 Analytics and Machine Learning Toolkit Win32Eng LV分析和机器学习工具包AML2017
    前天 16:03
    发表于 2020-7-18 17:44:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW分析和机器学习工具包将预测分析和机器学习集成到LabVIEW中。
    LabVIEW分析和机器学习工具包(LabVIEW Analytics and Machine Learning Toolkit)包含用于训练机器学习模型的虚拟仪器,可通过异常检测和分类以及聚类算法,从大量数据中识别出模式(pattern)。这些模型可以识别NI Linux Real-Time和Microsoft Windows硬件上的新数据模式。该工具包适用于状态监测和预测性维护应用,并提供入门指南和真实示例。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    AML2017.txt (374 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2017 Analytics and Machine Learning Toolkit Readme
    June 2017
    This file contains important information about the LabVIEW Analytics and Machine Learning Toolkit, including system requirements and installation instructions.
    The LabVIEW Analytics and Machine Learning toolkit includes VIs for training machine learning models that discover patterns in large amounts of data. You can deploy trained machine learning models to recognize patterns in new data.
    In addition to the system requirements for the LabVIEW Development System, LabVIEW 2017 Analytics and Machine Learning Toolkit has the following requirements:
    • LabVIEW 2017 Full or Professional Development System (32-bit)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2017.
    LabVIEW Analytics and Machine Learning Toolkit supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2016 LabVIEW dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. LabVIEW Analytics and Machine Learning Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use LabVIEW 2017 Analytics and Machine Learning Toolkit to an unsupported OS. Additionally, after installing LabVIEW 2017 Analytics and Machine Learning Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Double-click the setup.exe file in the root directory of the Analytics and Machine Learning Toolkit installer and follow the instructions on the screen to install the Analytics and Machine Learning Toolkit.
    The LabVIEW Analytics and Machine Learning Toolkit supports all NI Linux Real-Time hardware models. For more information about NI Linux Real-Time hardware models, refer to KB 4LRA4IQ0, What Operating System Is My Real-Time Controller Running and Why?.
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help in LabVIEW, for information about the LabVIEW Analytics and Machine Learning Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Analytics and Machine Learning folder to access the examples.
    © 2017 National Instruments. All rights reserved.
    377061A-01
    GMT+8, 2026-2-25 01:42
