查看: 3867|回复: 0
[LV工具模块] LabVIEW 2013 Control Design and Simulation Module Win32Eng LabVIEW控制设计和仿真模块CDSIM2013
    前天 16:03
    发表于 2020-7-18 23:37:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW控制设计与仿真模块可用于仿真动态系统、设计控制器,并将控制系统部署至实时硬件。
    LabVIEW控制设计与仿真模块是一款与LabVIEW平台相集成的附加软件,提供了内置并行机制、多核和多速率技术等编程能力以及用来部署至实时硬件的工具。您可将测量功能集成到用于系统识别、模型校准或模型验证的设计中。然后将算法部署至NI实时嵌入式硬件,实现快速控制原型和硬件在环(HIL)应用。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版与ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期重新压制的版本。
    EXE版:
    ZIP版:
    EXE版:
    ZIP版:
    CDSIM2013.txt (506 Bytes, 下载次数: 3, 售价: 10 圆)
    LabVIEW 2013 Control Design and Simulation Module Readme
    Version 13.0.0
    June 2013
    This file contains important information about the LabVIEW Control Design and Simulation Module, including installation instructions, new features, a partial list of bugs fixed for LabVIEW 2013 Control Design and Simulation Module, and known issues.
    The Control Design and Simulation Module provides tools with which you can analyze open-loop model behavior, design closed-loop controllers, simulate online and offline systems, and conduct physical implementations.
    In addition to the system requirements for the LabVIEW Development System, the Control Design and Simulation Module has the following requirements:
    • LabVIEW 2013 Full or Professional Development System (32-bit)
    • At least 500 MB additional disk space for Control Design and Simulation Module support
    • (Optional) LabVIEW MathScript RT Module—In LabVIEW 2009, LabVIEW MathScript became the LabVIEW MathScript RT Module. You cannot run VIs from previous versions of LabVIEW that contain MathScript Nodes until you install and activate the MathScript RT Module or remove the MathScript Nodes from the VIs. If you have already purchased the MathScript RT Module, select Help»Activate LabVIEW Components to activate the product.
    • (Optional) SignalExpress—If you plan to install the Control Design Assistant, you first must install SignalExpress.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    Limitations on OS X and Linux
    The Control Design and Simulation Module on OS X and Linux does not support the following features:
    • LabVIEW Control Design Assistant
    • Real-Time support
    (Windows) You can install all of your LabVIEW products—including the Control Design and Simulation Module—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    (OS X) Complete the following steps to install the Control Design and Simulation Module for OS X from the NI LabVIEW 2013 Control Design and Simulation Module installation CD:
    • Insert the NI LabVIEW 2013 Control Design and Simulation Module installation CD and open LabVIEW2013CDSim.mpkg located under the Mac OS X directory.
    • Follow the instructions that appear on the screen and continue to the Destination Select screen.
    • In the Destination Select screen, you must select the location where a compatible version of LabVIEW is installed. Otherwise, the installation will not complete.
    • After you select the destination directory, continue to follow the instructions that appear on the screen.
    (Linux) Complete the following steps to install the Control Design and Simulation Module for Linux from the NI LabVIEW 2013 Control Design and Simulation Module installation CD:
    • Insert the NI LabVIEW 2013 Control Design and Simulation Module installation CD. Use mount /mnt/cdrom to mount the CD. On some systems, the CD mounts automatically.
    • To change the current directory to the mounted CD, enter the following command:
      cd /mnt/cdrom
      sh ./INSTALL
      If you encounter the following message: "bad interpreter: Permission denied", the CD may not have mounted with executable permissions. To work around this, enter the following command:
      /bin/sh ./INSTALL
    Control Design and Simulation Module Updates and Notifications
    New FeaturesThe LabVIEW 2013 Control Design and Simulation Module incorporates the following new features:
    • The quality of the BDF solver has been improved. It is now an adaptation of the DASSL solver described in Numerical Solution of Initial Value Problems in Differential-Algebraic Equations, Petzold, Brenan and Campbell., North-Holland, New York, 1989.
    • The CD Continuous Algebraic Riccati Equation and Discrete Algebraic Riccati Equation VIs contain a new verify? parameter, which verifies the correctness of the solution before solving the equation. However, when used in the loop, this might not be necessary. By disabling the verify? parameter, you can increase the execution speed of these VIs.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Control Design and Simulation Module.
    The following items are the IDs and titles of a subset of issues fixed in the Control Design and Simulation Module. This is not an exhaustive list of issues fixed in the current version of the Control Design and Simulation Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    IDLegacy CAR IDFixed Issue
    408945Discrete PID used in Optimization does not match the Discrete PID in Control Design
    403931Opening the F14 Subsystem C Gen.vi generates an error
    399751Some solvers might halt in Mac/Linux platforms when integrating an external model
    398323Cursors change to indicate that custom controller is not working properly
    398316When copying and pasting the model for Kalman Filter to the Front Panel, the model copied in the Continuous mode contains a 1 but should instead be a 0
    398215Preview for Discrete filter is not displayed
    397658Empty path for user-defined call back in Optimization generates an unclear error
    389880Using Transfer Function.vi in a Simulation subsystem causes an access violation crash
    388904EMI node cannot locate and load the DLL when the node is inside an lvlib
    385822Error returned when trying to linearize a simulation subsystem created using LabVIEW 2012 Control Design and Simulation Module
    384240LabVIEW 2012 crashes during Control Design and Simulation PID loop deployment on cRIO
    383278Positive feedback does not work correctly in MathScript node
    377426Simulation Parameters cluster does not have the updated list of solvers in 2012
    376802Error in function lqe at line 33: Control Design and Simulation: The pair (C1, Ahat) is not detectable
    376789The Cruise Control example cannot be found using the NI Example Finder
    376180Even if an error is passed to the CD &Sim Generate Time Profiles for MPC Simulation.vi, the VI executes
    369987State-Space model with delay is not visualized correctly
    368583Editing a password-protected simulation subsystem can cause compilation of the subsystem to fail
    363868Selecting "Final Time" or "Initial Time" on the Simulation loop causes the node to generate errors
    360924Automotive examples are not available on Mac/Linux platforms
    358350Password-protected simulation subsystem icons are blank in simulation loops
    355886Subsystem VI with Time-Critical execution priority fails to compile
    353479Adding PID Synthesis Step during Control Design Assistant Help tutorial generates an error
    338170The order of polynomial for Discrete Filter VI is unclear
    3126923XLA9SIJState-Space version of Discrete to Continuous cannot handle multiple negative real poles
    485773U09HV00Estimation blocks are not included on Configuration page
    479713ONAPHCIConversion of delays to Z=0 in State-Space models is slow
    407971Password-protected simulation subsystem VIs do not compile when upgrading/recompiling code
    397656The interactive controller does not initialize the Variable property
    370731Distribute Delay VI has performance issues
    361682Solver for Discrete VIs appears to hang under certain conditions
    360065Read-Write Model parameters examples not found on OS X and Linux
    358348Cannot maintain icon style for simulation subsystem VI settings on insert/replace in a Simulation loop
    355300'SimEx Getting Model Signals at Runtime.vi' is missing from the Example Finder
    352312Signal generator preview/icon image is incorrect for Vector case
    361324Continuous Kalman Filter outside Control Design & Simulation Loop gives incorrect results
    5193749MDBC00Continuous TF/ZPK/SS/Filter parameters labeled k (discrete) instead of t (continuous)
    The LabVIEW Control Design User Manual contains conceptual information about using the control design functionality of the Control Design and Simulation Module. Open this manual by selecting Start»All Programs»National Instruments»LabVIEW 2013»LabVIEW Manuals and opening CD_User_Manual.pdf or by navigating to the labview\manuals directory and opening CD_User_Manual.pdf. (Windows 8) Click NI Launcher and select Control Design and Simulation Module in the window that appears.
    The LabVIEW Control Design and Simulation Module Help contains conceptual, how-to, and reference information about the Control Design and Simulation Module.
    (Windows) Complete the following steps to access this help file:
    • Launch LabVIEW.
    • Select Help»LabVIEW Help to launch the LabVIEW Help.
    • Click the Contents tab.
    • On the Contents tab, navigate to the Control Design and Simulation Module book.
    (OS X, Linux) Complete the following steps to access this help file:
    • Launch LabVIEW.
    • Select Help»Control Design and Simulation Module to launch the Control Design and Simulation Module Help.
    Refer to the LabVIEW Control Design and Simulation Module Algorithm References for information about algorithms implemented in the Control Design and Simulation Module and their corresponding references. Access the LabVIEW Control Design and Simulation Module Algorithm References by navigating to the labview\manuals directory and opening CDreference.pdf.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Control Design and Simulation Module are located in the labview\examples\Control and Simulation directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Control Design and Simulation Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Control Design and Simulation Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Control Design and Simulation Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2007–2013 National Instruments. All rights reserved.
    GMT+8, 2026-2-25 02:23
