查看: 3781|回复: 0
[LV工具模块] LabVIEW 2010 Sound and Vibration Analysis LabVIEW声音和振动工具包NISV2010/SVMS2010
    前天 16:03
    发表于 2020-7-19 16:46:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW声音和振动工具包提供了音频测试、声学测量和振动测量应用所需的函数和显示控件。
    LabVIEW声音和振动工具包是一个软件附加组件,包含易于使用的功率谱、正弦扫频和倍频程分析VI。它还可进行音频和失真测量、频率分析、频率响应测量和瞬态分析。该工具包还对分析解决方案进行了更新,以符合不断发展的IEC标准。LabVIEW声音和振动工具包提供了50多个可立即运行的LabVIEW示例,旨在帮助用户快速开始开发应用程序。
    在2019~2021版本,使用32位、64位分开安装文件的方式,在2018及之前的版本,2023Q3及之后版本则使用同一个安装文件,即同一安装文件可支持32位、64位LabVIEW,与VISION模块类似。具体的请查看下面的自述文件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    SV2010.txt (246 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2010 Sound and Vibration Analysis VIs Readme
    Version 10.0.0
    June 2010
    This file contains information about LabVIEW support for the NI Sound and Vibration Toolkit 2010 and the NI Sound and Vibration Measurement Suite 2010. This file also provides you with help resources you can use while working with the software. Refer to the National Instruments Web site for a comparison between the Sound and Vibration Toolkit and the Sound and Vibration Measurement Suite.
    This file contains the following information:
    Redistributing Executable Sound and Vibration Applications
    Documentation Corrections
    New Features: Sound and Vibration Toolkit
    The Sound and Vibration Toolkit 2010 includes the following new features in LabVIEW:
    DAQmx AI Config XControl
    Use the DAQmx AI Config XControl on your application front panel to provide interactive configuration for DAQmx analog input channels. The control provides support for quick configuration and compact display of multiple analog input channels and the configuration for measurement type, sensor sensitivity, input range, coupling, IEPE, location, and orientation as well as timing and tachometer configuration.
    Embedded Monitoring VIs
    Use these advanced, performance-optimized VIs in embedded monitoring applications or other applications that require maximum throughput and minimum memory footprint.
    Machine Characteristic VIs
    Use the Machine Characteristics VIs to calculate the common frequencies of interest for critical machine elements such as bearings, pulleys, gears, AC and DC motors, and pumps and fans.
    UFF58 ASCII VIs
    Use the UFF58 ASCII VIs to write time waveforms, frequency spectra, and real and imaginary components of frequency response to UFF58 files in ASCII format. The saved functions in these ASCII files can be read by the VIs in the UFF58b subpalette, DIAdem with the UFF58 plugin, or by external software applications.
    Application Example for Impact Test
    Use this advanced example to interactively configure your hammer and accelerometer(s) channels, continuously acquire and trigger on impacts, accumulate results, perform averaged frequency response measurements, and archive frequency responses to a UFF 58 file. The example uses a button-driven graphical user interface (GUI) to navigate through the steps of completing an impact test. Use the application example as is, or customize it to fit specific application requirements. Open this example by navigating to the examples\Sound and vibration\Application Examples directory.
    Spectrum Extended Measurements VIs
    Replaced the Extended Measurements palette under the Order Analysis palette with the Spectrum Extended Measurements palette. Also added the Spectrum Extended Measurements palette to the Frequency Analysis and Embedded Monitoring palettes. Also added the following VIs to the Spectrum Extended Measurements palette: SVFA Convert Frequency (CPM to CPS), SVFA Convert Frequency (CPS to CPM), and SVFA Convert Spectrum (Frequency to Order).
    To run the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite, your computer must meet the following minimum system requirements:
    • Supported Operating Systems
      • Windows XP (32-bit)
    • Minimum of 1 GB of RAM
    • Pentium 4/M or equivalent processor
    • LabVIEW 2010 Full Development System or Professional Development System installed and properly licensed
    • NI-DAQmx 9.1 or later installed for NI-DAQmx support
    Note: The Sound and Vibration Toolkit 2010 and the Sound and Vibration Measurement Suite 2010 do not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    You must be logged in with administrator privileges to install the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite. Note the following consideration when installing these products:
    • You cannot install the Sound and Vibration Toolkit 2010 on a computer that has the Order Analysis Toolkit 2.1 or earlier installed. You must purchase and install the Sound and Vibration Measurement Suite 2010 to use order analysis functionality with the Sound and Vibration Toolkit 2010.
    Installing from the LabVIEW 2010 Platform DVD
    You can install all of your LabVIEW products—including the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite—using the LabVIEW 2010 Platform DVDs. You can find installation instructions for the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite along with activation instructions in the following locations:
    • LabVIEW 2010 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2010 Platform DVDs, refer to the National Instruments Web site.
    Installing from the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite DVD
    Complete the following steps to install the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite on Windows 7/Vista/XP/Server 2008 (64-bit)/Server 2003 (32-bit):
    • Disable any automatic virus detection programs before installation. Some virus detection programs interfere with the installation program.
    • Insert the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite DVD and follow the instructions that appear on the screen.
    • After installation, enable any virus detection programs you disabled and run a virus scan.
    • Restart the computer.
    • Activate the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite using the NI License Manager.
    Redistributing Sound and Vibration Executables
    If you want to redistribute executables built with the Sound and Vibration Measurement Suite or any of its components, you must purchase the appropriate NI Sound and Vibration Software Run-Time License. The part number for the NI Sound and Vibration Software Run-Time License is 779875-01. Contact National Instruments to purchase the NI Sound and Vibration Software Run-Time License.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help in LabVIEW, for information about the Sound and Vibration VIs.
    You can find LabVIEW examples for the Sound and Vibration VIs in the labview\examples\Sound and Vibration directory.
    You also can find LabVIEW examples for the Sound and Vibration VIs using the NI Example Finder. Select Help»Find Examples to launch the NI Example Finder. On the Browse page, the Sound and Vibration example VIs are located in the Toolkits and Modules»Sound and Vibration folder.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite.
    The following items are the IDs and titles of a subset of issues fixed between the Sound and Vibration Measurement Suite 2009 and 2010. If you have a Bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the Sound and Vibration Measurement Suite.
    Bug IDFixed Issue
    175627Shaft Centerline Plot xControl updates direction arrow.
    176806Always returns full amplitude regardless of comparison result.
    181418Added UFF58 ASCII palette to write ASCII from LabVIEW datatypes and convert from binary to ASCII.
    • The equations for calculating ball spin frequency/order are not correct in the Calculating Characteristic Frequencies and Orders and SVT Bearings VI topics. Use the equation on the block diagram of the SVT Bearings VI to calculate ball spin frequency/order.
    © 2010 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2026-2-25 01:41
