查看: 3909|回复: 0
[LV工具模块] LabVIEW 2011 Sound and Vibration Analysis LabVIEW声音和振动工具包NISV2011
    前天 16:03
    发表于 2020-7-19 16:53:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW声音和振动工具包提供了音频测试、声学测量和振动测量应用所需的函数和显示控件。
    LabVIEW声音和振动工具包是一个软件附加组件,包含易于使用的功率谱、正弦扫频和倍频程分析VI。它还可进行音频和失真测量、频率分析、频率响应测量和瞬态分析。该工具包还对分析解决方案进行了更新,以符合不断发展的IEC标准。LabVIEW声音和振动工具包提供了50多个可立即运行的LabVIEW示例,旨在帮助用户快速开始开发应用程序。
    在2019~2021版本,使用32位、64位分开安装文件的方式,在2018及之前的版本,2023Q3及之后版本则使用同一个安装文件,即同一安装文件可支持32位、64位LabVIEW,与VISION模块类似。具体的请查看下面的自述文件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版与ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期重新压制的版本。
    ZIP版:
    EXE版:
    ZIP版:
    SV2011.txt (495 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2011 Sound and Vibration Analysis VIs Readme
    Version 11.0.0
    June 2011
    This file contains information about LabVIEW support for the NI Sound and Vibration Toolkit 2011 and the NI Sound and Vibration Measurement Suite 2011. This file also provides you with help resources you can use while working with the software. Refer to the National Instruments Web site for a comparison between the Sound and Vibration Toolkit and the Sound and Vibration Measurement Suite.
    This file contains the following information:
    Redistributing Executable Sound and Vibration Applications
    New Features: Sound and Vibration Measurement Suite
    The Sound and Vibration Measurement Suite includes the following new features:
    Support for LabVIEW 2011
    Support for LabVIEW 2011 does not remove previously installed support for LabVIEW 2010 and earlier.
    Application Example: Machine Vibration Logger
    Use the new features to perform continuous acquisition, processing, and logging. This example features new views for dashboard status, trended values, and block processing. Use this example to configure:
    • NI-DAQmx hardware
    • Measurement analyses for level, FFT, and order tracking
    • TDMS logging
    Updates to the Application Example: Impact Test
    Use the new features to perform TDMS logging for time-domain impacts. This example features a delete button to manage stored impacts, context help for controls and indicators, and a resizeable view area.
    Updates to the DAQmx AI Config XControl
    Use the new features on the DAQmx AI Config XControl to configure DAQmx logging, save tasks in Measurement & Automation Explorer (MAX), and configure software triggers. The control adds the trigger configuration as waveform attributes to the reference channel. This control also features a resizeable channel table.
    To run the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite, your computer must meet the following minimum system requirements:
    • Supported Operating Systems
      • Windows XP Service Pack 3 or later (32-bit)
    • Minimum of 1 GB of RAM
    • Pentium 4/M or equivalent processor
    • LabVIEW 2011 Full Development System or Professional Development System installed and properly licensed
    • NI-DAQmx 9.3.5 or later installed for NI-DAQmx support
    You must be logged in with administrator privileges to install the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite. Note the following consideration when installing these products:
    • You cannot install the Sound and Vibration Toolkit 2011 on a computer that has the Order Analysis Toolkit 2.1 or earlier installed. You must purchase and install the Sound and Vibration Measurement Suite 2011 to use order analysis functionality with the Sound and Vibration Toolkit 2011.
    Installing from the LabVIEW 2011 Platform DVD
    You can install all of your LabVIEW products—including the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite—using the LabVIEW 2011 Platform DVDs. You can find installation and activation instructions in the LabVIEW Release Notes, which are available in your LabVIEW software kit.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Installing from the Sound and Vibration Measurement Suite DVD
    Complete the following steps to install the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite:
    • Disable any automatic virus detection programs before installation. Some virus detection programs interfere with the installation program.
    • Insert the Sound and Vibration Measurement Suite DVD and follow the instructions that appear on the screen.
    • After installation, enable any virus detection programs you disabled and run a virus scan.
    • Restart the computer.
    • Activate the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite using the NI License Manager.
    If you want to redistribute executables built with the Sound and Vibration Measurement Suite or any of its components, you must purchase the appropriate NI Sound and Vibration Software Run-Time License. The part number for the NI Sound and Vibration Software Run-Time License is 779875-35. Contact National Instruments to purchase the NI Sound and Vibration Software Run-Time License.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help in LabVIEW, for information about the Sound and Vibration VIs.
    You can find LabVIEW examples for the Sound and Vibration VIs using the NI Example Finder. Select Help»Find Examples to launch the NI Example Finder. On the Browse page, the Sound and Vibration example VIs are located in the Toolkits and Modules»Sound and Vibration folder.
    You also can find LabVIEW examples for the Sound and Vibration VIs in the labview\examples\Sound and Vibration and the labview\examples\Order Analysis directories.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Sound and Vibration Toolkit and the Sound and Vibration Measurement Suite.
    You can access a list of bug fixes online. Refer to the National Instruments Web site for a list of bug fixes in the Sound and Vibration Toolkit and Sound and Vibration Measurement Suite.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2026-2-25 01:40
