查看: 5382|回复: 0
[LV工具模块] LabVIEW 2014 Sound and Vibration Analysis LabVIEW声音和振动工具包NISV2014
    前天 16:03
    发表于 2020-7-19 17:03:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW声音和振动工具包提供了音频测试、声学测量和振动测量应用所需的函数和显示控件。
    LabVIEW声音和振动工具包是一个软件附加组件,包含易于使用的功率谱、正弦扫频和倍频程分析VI。它还可进行音频和失真测量、频率分析、频率响应测量和瞬态分析。该工具包还对分析解决方案进行了更新,以符合不断发展的IEC标准。LabVIEW声音和振动工具包提供了50多个可立即运行的LabVIEW示例,旨在帮助用户快速开始开发应用程序。
    在2019~2021版本,使用32位、64位分开安装文件的方式,在2018及之前的版本,2023Q3及之后版本则使用同一个安装文件,即同一安装文件可支持32位、64位LabVIEW,与VISION模块类似。具体的请查看下面的自述文件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版与ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期重新压制的版本。
    ZIP版:
    EXE版:
    ZIP版:
    SV2014.txt (499 Bytes, 下载次数: 12, 售价: 10 圆)
    LabVIEW 2014 Sound and Vibration Analysis VIs Readme
    Version 14.0.0
    June 2014
    This file contains information about LabVIEW support for the NI Sound and Vibration Toolkit 2014 and the NI Sound and Vibration Measurement Suite 2014. This file also provides you with help resources you can use while working with the software. Refer to the National Instruments Web site for a comparison between the Sound and Vibration Toolkit and the Sound and Vibration Measurement Suite.
    This file contains the following information:
    Redistributing Executable Sound and Vibration Applications
    Accessing Sample Projects
    The NI Sound and Vibration Measurement Suite and the NI Sound and Vibration Toolkit provide comprehensive measurement, analysis, and vizualization tools for all audio, noise and vibration, and machine condition monitoring applications. Based on an open-analysis capability and a flexible measurement library, the NI Sound and Vibration Measurement Suite and NI Sound and Vibration Toolkit present a unique software-based measurement approach to creating customized applications. Learn more about the sound and vibration software at ni.com/soundandvibration.
    The Sound and Vibration Toolkit/Sound and Vibration Measurement Suite has the following requirements:
    • At least 2 GB of available disk space
    • At least 1 GB of RAM
    • NI-DAQmx 14.0 or later installed for NI-DAQmx support
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2014.
    The following table lists the NI application software versions, including service packs, supported by the Sound and Vibration Measurement Suite. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    NI Application SoftwareVersions Supported by NI Sound and Vibration Measurement Suite 2014
    NI LabVIEW2014
    NI LabVIEW Real-Time Module2014
    You must be logged in with administrator privileges to install the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite.
    Note You cannot install the Sound and Vibration Toolkit 2014 on a computer that has the Order Analysis Toolkit 2.1 or earlier installed. You must purchase and install the Sound and Vibration Measurement Suite 2014 to use order analysis functionality with the Sound and Vibration Toolkit 2014.
    Installing from the LabVIEW 2014 Platform DVD
    You can install all of your LabVIEW products—including the Sound and Vibration Toolkit and the Sound and Vibration Measurement Suite—using the LabVIEW 2014 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    Note If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    Installing from the Sound and Vibration Measurement Suite DVD
    Complete the following steps to install the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite:
    • Disable any automatic virus detection programs before installation. Some virus detection programs interfere with the installation program.
    • Insert the Sound and Vibration Measurement Suite DVD and follow the instructions that appear on the screen.
    • After installation, enable any virus detection programs you disabled and run a virus scan.
    • Restart the computer.
    • Activate the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite using the NI License Manager.
    New Features: Sound and Vibration Measurement Suite
    The Sound and Vibration Measurement Suite includes the following new features:
    Support for LabVIEW 2014
    Support for LabVIEW 2014 does not remove previously installed support for LabVIEW 2013 and earlier.
    Updated Stimulus-Response and Audio Test Examples
    These udpated examples use the Stimulus-Response Test VIs to configure and generate test signals for stimulus-response measurements and use the Buffer VIs to access and parse data in parallel code. These examples serve as starting points for stimulus-response test applications with modular code segments for:
    • Test signal generation
    • Analog output
    • Analog input
    • Processing
    Full Spectrum VI
    Use these VIs to calculate the full spectrum of orbit data from a pair of vibration sensors.
    Spectrum with Cursors XControl
    Use this control to display spectrum data with header information and the following types of configurable cursors:
    • Harmonic
    • Sideband
    • Band
    • Arbitrary
    Waveform with Cursors XControl
    Use this control to display time waveforms with header information and the following types of configurable cursors:
    • Range
    • Arbitrary
    New Sample Projects
    The following new sound and vibration sample projects are available in the LabVIEW Sample Projects and Templates folder.
    • Dynamic Signal Analyzer (DSA Soft Front Panel source)
    • Dynamic Signal Generator (DSG Soft Front Panel source)
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Sound and Vibration Toolkit and the Sound and Vibration Measurement Suite.
    You can access a list of bug fixes online. Refer to the National Instruments Web site for a list of bug fixes in the Sound and Vibration Toolkit and Sound and Vibration Measurement Suite.
    If you want to redistribute executables built with the Sound and Vibration Measurement Suite or any of its components, you must purchase the appropriate NI Sound and Vibration Software Run-Time License. The part number for the NI Sound and Vibration Software Run-Time License is 779875-35. Contact National Instruments to purchase the NI Sound and Vibration Software Run-Time License.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help in LabVIEW, for information about the Sound and Vibration VIs.
    Accessing the Sample Projects
    To access the sample projects and templates from the New Project dialog, select Sample Projects in the left pane and navigate to the project that best matches your application requirements.
    You can find LabVIEW examples for the Sound and Vibration VIs using the NI Example Finder. Select Help»Find Examples to launch the NI Example Finder. On the Browse page, the Sound and Vibration example VIs are located in the Toolkits and Modules»Sound and Vibration folder.
    You also can find LabVIEW examples for the Sound and Vibration VIs in the labview\examples\Sound and Vibration and the labview\examples\Order Analysis directories.
    Using NI Launcher
    Finding All Programs
    NI Sound and Vibration Measurement Suite Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Sound and Vibration Measurement Suite will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Sound and Vibration Measurement Suite that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2007–2014 National Instruments. All rights reserved.
    GMT+8, 2026-2-25 01:40
