查看: 5070|回复: 0
[LV工具模块] LabVIEW 2020 Sound and Vibration Analysis Win32ENG LabVIEW声音和振动工具包NISV2020-32
    前天 16:03
    发表于 2020-7-19 20:19:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW声音和振动工具包提供了音频测试、声学测量和振动测量应用所需的函数和显示控件。
    LabVIEW声音和振动工具包是一个软件附加组件,包含易于使用的功率谱、正弦扫频和倍频程分析VI。它还可进行音频和失真测量、频率分析、频率响应测量和瞬态分析。该工具包还对分析解决方案进行了更新,以符合不断发展的IEC标准。LabVIEW声音和振动工具包提供了50多个可立即运行的LabVIEW示例,旨在帮助用户快速开始开发应用程序。
    在2019~2021版本,使用32位、64位分开安装文件的方式,在2018及之前的版本,2023Q3及之后版本则使用同一个安装文件,即同一安装文件可支持32位、64位LabVIEW,与VISION模块类似。具体的请查看下面的自述文件。
    SV2016版的安装包比SV2015版的安装小了近1GB,从自述文件中看到,主要是少了SV快速VI和SVA的助手工具,如果要安装SV快速VI和SVA助手,则需要使用2015及以前的版本:
    Note: Sound and Vibration Express VIs and the Sound and Vibration Assistant are not instalLED by NI Sound and Vibration Measurement Suite 2016. Side-by-side installation is supported; therefore you may install the Sound and Vibration Assistant from NI Sound and Vibration Toolkit or NI Sound and Vibration Measurement Suite 2015 or earlier.
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    SV2020.txt (299 Bytes, 下载次数: 33, 售价: 10 圆)
    LabVIEW 2020 Sound and Vibration Toolkit Readme
    Version 20.0.0
    March 2020
    This file contains information about LabVIEW support for the NI Sound and Vibration Toolkit (Base and Full). This file also provides you with help resources you can use while working with the software. Refer to the National Instruments Web site for a comparison between Sound and Vibration Toolkit (Base) and Sound and Vibration Toolkit (Full).
    This file contains the following information:
    Redistributing Executable Sound and Vibration Applications
    Accessing Sample Projects
    LabVIEW Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The NI Sound and Vibration Toolkit provides comprehensive configuration, measurement-analysis, and visualization tools for audio, noise-vibration-harshness (NVH), and machine condition monitoring (MCM) applications. Based on an open-analysis capability and a flexible measurement library, the NI Sound and Vibration Toolkit presents a unique capability to create software-defined automated test and measurement applications. Learn more about the sound and vibration software at ni.com/soundandvibration.
    Back to Top
    The Sound and Vibration Toolkit Base/Full have the following requirements:
    • At least 1 GB of available disk space
    • At least 1 GB of RAM
    • NI-DAQmx 20.0 or later installed for NI-DAQmx measurement hardware support
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2020.
    Back to Top
    The following table lists the NI application software versions, including service packs, supported by the Sound and Vibration Toolkit.
    Versions Supported by NI Sound and Vibration Toolkit 2020
    NI LabVIEW (32- and 64-bit) Full or Professional Development System2020
    NI LabVIEW Real-Time Module2020
    Note: Sound and Vibration Express VIs and the Sound and Vibration Assistant are not installed by NI Sound and Vibration Toolkit 2020. Side-by-side installation is supported; therefore you may install the Sound and Vibration Assistant from NI Sound and Vibration Toolkit or NI Sound and Vibration Measurement Suite 2015 or earlier.
    Back to Top
    NI installs software using NI Package Manager. If you do not already have NI software installed, LabVIEW installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate the Sound and Vibration Toolkit. For more information on software activation, refer to National Instruments Software Activation.
    Installing from the LabVIEW 2020 Platform media
    You can install all of your LabVIEW products—including the Sound and Vibration Toolkit—using the LabVIEW Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    Note If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    Back to Top
    Back to Top
    New Features: Sound and Vibration Toolkit
    The Sound and Vibration Toolkit includes the following new features:
    Support for LabVIEW 2020
    Support for LabVIEW 2020 does not remove previously installed support for LabVIEW 2019 and earlier.
    Support for different sample rates between input and output during stimulus-response measurements
    Fully synchronized stimulus-response measurements can now be performed while running analog input and analog output at different rates. DAQmx AI devices such as the 4464 can be run at full rate of 204.8 kHz while DAQmx AO device such as the 4463 can be run at full rate of 51.2 kHz. This allows for the measurement of harmonic components outside the bandwidth of the AO device.
    Enhanced Examples and Sample Projects
    • Simplified examples to improve function and readability.
    • Refactored Impact Test sample project to modularize functionality and improve readability. Use the new LabVIEW TDMS File Viewer to review saved impacts.
    • Simplified DSA and DSG sample projects to improve readability and performance.
    Back to Top
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Sound and Vibration Toolkit.
    Back to Top
    You can access a list of bug fixes online. Refer to the National Instruments Web site for a list of bug fixes in the Sound and Vibration Toolkit.
    Back to Top
    If you want to redistribute executables built with the Sound and Vibration Toolkit or any of its components, you must purchase the appropriate NI Sound and Vibration Software Run-Time License. The part number for the NI Sound and Vibration Software Run-Time License is 779875-35. Contact National Instruments to purchase the NI Sound and Vibration Software Run-Time License.
    Back to Top
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help in LabVIEW, for information about the Sound and Vibration VIs. Sound and Vibration Toolkit documentation is located in the LabVIEW Help in the following location: LabVIEW Help»Toolkits»Sound and Vibration Toolkit.
    Back to Top
    Accessing the Sample Projects
    To access the sample projects and templates from the New Project dialog, select Sample Projects in the left pane and navigate to the project that best matches your application requirements.
    Back to Top
    You can find LabVIEW examples for the Sound and Vibration VIs using the NI Example Finder. Select Help»Find Examples to launch the NI Example Finder. On the Browse page, the Sound and Vibration example VIs are located in the Toolkits and Modules»Sound and Vibration and the Toolkits and Modules»Order Analysis folders.
    You also can find LabVIEW examples for the Sound and Vibration VIs in the labview\examples\Sound and Vibration and the labview\examples\Order Analysis directories.
    Back to Top
    Back to Top
    Back to Top
    Back to Top
    LabVIEW will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Back to Top
    375332F-01
    GMT+8, 2026-2-25 01:42
