查看: 3209|回复: 0
[LV工具模块] LabVIEW 2010 Unit Test Framework Toolkit Win32Eng LabVIEW单元测试框架工具包UTF2010
    前天 16:03
    发表于 2020-7-23 23:34:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW单元测试框架工具包可自动执行LabVIEW VI单元测试,帮助您轻松进行功能验证。
    LabVIEW单元测试框架工具包是一个LabVIEW附加软件,可帮助您自动完成功能验证,并验证应用程序是否正常运行。您可以生成单元测试或者导入使用Microsoft Excel等编辑器创建的文本文档里的测试参数。测试可包含多种测试用例,这些用例决定了各种数据类型(包括数组和簇) 的输入值和预期输出。您将可识别错误输出的来源、跟踪代码覆盖率,并生成HTML、ATML/XML或ASCII格式的验证文档。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版与ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期重新压制的版本。
    EXE版:
    ZIP版:
    EXE版:
    ZIP版:
    UTF2010.txt (524 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2010 Unit Test Framework Toolkit Readme
    Version 10.0.0
    June 2010
    This file contains information about the LabVIEW 2010 Unit Test Framework Toolkit. This file also provides you with help resources you can use while working with the Unit Test Framework Toolkit.
    New Features and Changes
    The LabVIEW 2010 Unit Test Framework Toolkit is the upgrade version of the LabVIEW 2009 Unit Test Framework Toolkit. The Unit Test Framework Toolkit provides interactive tools you use to create, configure, manage, and execute tests that check VIs for functional correctness.
    The following list contains the new features and changes of the Unit Test Framework Toolkit.
    • You can use test vectors to manage multiple input values. A test vector is an array of input values that you can assign to an input of the VI under test. Before you create a test vector, you must create a test vector file in a LabVIEW project. LabVIEW creates a .lvvect file in the Project Explorerwindow to save the test vector file. A .lvvect file can contain multiple test vectors.
    • You can generate the code coverage of a project. If you want to generate the project code coverage, the Unit Test Framework Toolkit opens all VIs that this project contains to count the subdiagrams and generate the code coverage.
    • This version changes the data type of test results in and test results out from array to cluster. This change affects the following VIs:
      • Create Report
      • Open Results Window
      • Run Tests from File
      • Run Tests from Project
    The computer you are using must meet the minimum system requirements to run the Unit Test Framework Toolkit:
    • Supported operating systems:
      • Windows XP (32-bit)
    • A minimum of 32 MB free disk space
    • LabVIEW 2010 Development System
    Note: The Unit Test Framework Toolkit does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    You can install all of your LabVIEW products—including the Unit Test Framework Toolkit—using the LabVIEW 2010 Platform DVDs. You can find installation instructions for the Unit Test Framework Toolkit along with activation instructions in the following locations:
    • LabVIEW 2010 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2010 Platform DVDs, refer to the National Instruments Web site.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about the Unit Test Framework Toolkit.
    LabVIEW examples for the Unit Test Framework Toolkit are located in the labview\examples\Unit Test Framework folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Unit Test Framework Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2010 Unit Test Framework Toolkit. If you have a bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the Unit Test Framework Toolkit.
    129739Code coverage for results include only those VIs that have tests defined
    136421Test configuration and test execution causes a dirty dot on the project
    138805Test cases do not have names
    152822Code coverage of dynamic dispatched VI does not reflect the real executed VI
    182783Some strings in the Unit Test Property dialog box are truncated on Korean OS
    220428.lvtest files have default unknown file type icons on Windows Desktop
    Important Information
    © 2010 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-25 02:41
