查看: 3085|回复: 0
[LV工具模块] LabVIEW 2012 Unit Test Framework Toolkit Win32Eng LabVIEW单元测试框架工具包UTF2012
    前天 16:03
    发表于 2020-7-23 23:43:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW单元测试框架工具包可自动执行LabVIEW VI单元测试,帮助您轻松进行功能验证。
    LabVIEW单元测试框架工具包是一个LabVIEW附加软件,可帮助您自动完成功能验证,并验证应用程序是否正常运行。您可以生成单元测试或者导入使用Microsoft Excel等编辑器创建的文本文档里的测试参数。测试可包含多种测试用例,这些用例决定了各种数据类型(包括数组和簇) 的输入值和预期输出。您将可识别错误输出的来源、跟踪代码覆盖率,并生成HTML、ATML/XML或ASCII格式的验证文档。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版与ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期重新压制的版本。
    EXE版:
    ZIP版:
    EXE版:
    ZIP版:
    UTF2012.txt (524 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2012 Unit Test Framework Toolkit Readme
    Version 12.0.0
    June 2012
    This file contains important information about the LabVIEW Unit Test Framework Toolkit, including installation instructions, new features, a partial list of bugs fixed for the Unit Test Framework Toolkit 2012, and known issues.
    The LabVIEW 2012 Unit Test Framework Toolkit is the upgrade version of the LabVIEW 2011 Unit Test Framework Toolkit. The Unit Test Framework Toolkit provides interactive tools you use to create, configure, manage, and execute tests that check VIs for functional correctness.
    In addition to the system requirements for the LabVIEW Development System, the Unit Test Framework Toolkit has the following requirements:
    • LabVIEW 2012 Base, Full, or Professional Development System (32-bit)
    • At least 32 MB of disk space
    Refer to the LabVIEW readme for additional system requirements and supported operating systems for LabVIEW 2012.
    You can install all of your LabVIEW products—including the Unit Test Framework Toolkit—using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website at ni.com.
    Note:  If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    • The Unit Test Framework (UTF) type files available in the previous versions of the Unit Test Framework Toolkit now ship with NI Requirements Gateway 2012, along with the examples about integrating the Unit Test Framework Toolkit with Requirements Gateway. Requirements Gateway is an application that provides a requirements traceability solution. You can use Requirements Gateway to link development and verification documents with formal requirements stored in documents and databases.
      You can integrate the Unit Test Framework Toolkit with the following versions of Requirements Gateway:
      • Requirements Gateway 2012.
      • Requirements Gateway 1.1, after you download the UTF type files and examples that Requirements Gateway 2012 ships from the National Instruments website.
      Refer to the NI Requirements Gateway Help for more information about integrating Requirements Gateway with the Unit Test Framework Toolkit.
    • The Unit Test Framework Toolkit 2012 targets at reducing the time of loading and executing test files by around 30 percent, especially for test files that contain more than four test cases. The actual improvement may vary depending on the hardware you installed and the complexity of the projects.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Unit Test Framework Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the Unit Test Framework Toolkit. This is not an exhaustive list of issues fixed in the current version of the Unit Test Framework Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    300593LabVIEW Unit Test Framework cannot find base LabVIEW Class
    329370Test case values might be overwritten when you switch between test cases
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Unit Test Framework Toolkit.
    LabVIEW examples for the Unit Test Framework Toolkit are located in the labview\examples\Unit Test Framework folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Important Information
    © 2012 National Instruments. All rights reserved.
    GMT+8, 2026-2-25 02:40
