查看: 3223|回复: 0
[LV工具模块] LabVIEW 2013 Unit Test Framework Toolkit Win32Eng LabVIEW单元测试框架工具包UTF2013
    前天 16:03
    发表于 2020-7-23 23:46:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW单元测试框架工具包可自动执行LabVIEW VI单元测试,帮助您轻松进行功能验证。
    LabVIEW单元测试框架工具包是一个LabVIEW附加软件,可帮助您自动完成功能验证,并验证应用程序是否正常运行。您可以生成单元测试或者导入使用Microsoft Excel等编辑器创建的文本文档里的测试参数。测试可包含多种测试用例,这些用例决定了各种数据类型(包括数组和簇) 的输入值和预期输出。您将可识别错误输出的来源、跟踪代码覆盖率,并生成HTML、ATML/XML或ASCII格式的验证文档。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版与ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期重新压制的版本。
    EXE版:
    ZIP版:
    EXE版:
    ZIP版:
    UTF2013.txt (524 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2013 Unit Test Framework Toolkit Readme
    Version 13.0.0
    June 2013
    This file contains important information about the Unit Test Framework Toolkit, including installation instructions and new features.
    The LabVIEW 2013 Unit Test Framework Toolkit is the upgrade version of the LabVIEW 2012 Unit Test Framework Toolkit. The Unit Test Framework Toolkit provides interactive tools you use to create, configure, manage, and execute tests that check VIs for functional correctness.
    In addition to the system requirements for the LabVIEW Development System, the Unit Test Framework Toolkit has the following requirements:
    • LabVIEW 2013 Base, Full, or Professional Development System (32-bit)
    • At least 64 MB of disk space
    You can install all of your LabVIEW products—including the Unit Test Framework Toolkit—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Unit Test Framework Toolkit Updates and Notifications
    • You can assign test vectors to expected values of outputs. The Unit Test Framework Toolkit 2013 provides an example project Assign Vector to Expected Value.lvproj to demonstrate this feature.
    • In the Unit Test Framework Toolkit 2012 and previous versions, if you modify a VI after creating a test, you can click the Update button on the Test Cases page of the Test Properties dialog box to update input and output names of each test case, but you have to reconfigure input values, expected values, and comparison types. In the Unit Test Framework 2013, after you click the Update button, LabVIEW applies the original values in some cases.
    • Use the new Run button on the Test Cases page of the Test Properties dialog box to execute a single test case without closing this dialog box.
    • Use the new Rearrange button on the Test Cases page of the Test Properties dialog box to rearrange the order of test cases.
    • The Test Cases page of the Test Properties dialog box displays a new connector pane image. If you modify the VI under test after creating a test, you also can click the Update button to update the image on this page.
    • When you enter input values or expected values on the Test Cases page, you can press to enter the value in the next cell and press to switch to the value in the previous cell.
    • Use the new Disable breakpoints option on the Advanced page of the Test Properties dialog box to toggle test execution suspension at a breakpoint.
    • Use the new Automatic error handling option on the Advanced page of the Test Properties dialog box to disable automatic error handling and to continue to run the VI under test, setup VI, and teardown VI even when an error occurs during test execution.
    • When you enter values of test vectors in the Test Vector Properties - Edit dialog box, you can press to move to the value in the next cell and press to switch to the value in the previous cell.
    • You can find the User-Defined Test Template.vit template by selecting File»New to display the New dialog box and selecting VI»From Template»Unit Test Framework. You also can locate this template in the labview\templates\UnitTestFramework directory.
    • The Unit Test Framework Toolkit 2013 improves the HTML and ASCII test reports by adding input values, input vector values, expected vector values, and sequence number of permutations.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Unit Test Framework Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the Unit Test Framework Toolkit. This is not an exhaustive list of issues fixed in the current version of the Unit Test Framework Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    325122The comment field does not have a vertical scrollbar.
    335223There is a reference leak when creating a new test.
    339375The sum of the number of fail/pass/not VIs in the report summary does not equal the number of VIs in the project.
    364008Unit Test Framework cannot capture a run-time error of a VI under test if its error out terminal is not wired.
    365678There are spelling mistakes in the report header.
    367888Hang when creating new test from specific VIs.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Unit Test Framework Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Unit Test Framework folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Unit Test Framework Toolkit in the labview\examples\Unit Test Framework directory.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Unit Test Framework Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Unit Test Framework Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW Unit Test Framework Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2008–2013 National Instruments. All rights reserved.
    GMT+8, 2026-2-25 02:40
