查看: 3913|回复: 0
[LV工具模块] LabVIEW 2020 Unit Test Framework Toolkit Win64Eng LabVIEW单元测试框架工具包UTF2020-64bit
    前天 16:03
    发表于 2020-7-24 00:26:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    UTF2016版开始,支持64位的LabVIEW,即有UTF2016-64bit的版本。
    LabVIEW单元测试框架工具包可自动执行LabVIEW VI单元测试,帮助您轻松进行功能验证。
    LabVIEW单元测试框架工具包是一个LabVIEW附加软件,可帮助您自动完成功能验证,并验证应用程序是否正常运行。您可以生成单元测试或者导入使用Microsoft Excel等编辑器创建的文本文档里的测试参数。测试可包含多种测试用例,这些用例决定了各种数据类型(包括数组和簇) 的输入值和预期输出。您将可识别错误输出的来源、跟踪代码覆盖率,并生成HTML、ATML/XML或ASCII格式的验证文档。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    UTF2020-64.txt (341 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2020 Unit Test Framework Toolkit Readme
    March 2020
    This file contains important information about the LabVIEW Unit Test Framework Toolkit, including system requirements, installation instructions, and known issue, and a partial list of bugs fixed for LabVIEW Unit Test Framework Toolkit.
    LabVIEW Unit Test Framework Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The Unit Test Framework Toolkit provides interactive tools to create, configure, manage, and execute tests that check VIs for functional correctness.
    In addition to the system requirements for the LabVIEW Development System, the Unit Test Framework Toolkit has the following requirements:
    • LabVIEW 2020 Base, Full, or Professional Development System
    • At least 64 MB of disk space
    Note  The LabVIEW 2020 Professional Development System license activates the LabVIEW 2020 Unit Test Framework Toolkit.
    The Unit Test Framework Toolkit supports the following operating systems:
    • Windows 10 (version 1909)/8.1 Update 11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    • In 2016 the Unit Test Framework Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW Unit Test Framework Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW Unit Test Framework Toolkit to an unsupported OS. Additionally, after installing the LabVIEW Unit Test Framework Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/r/PAESupport.
    • Refer to LabVIEW Unit Test Framework Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    NI installs the Unit Test Framework Toolkit using NI Package Manager. If you do not already have NI software installed, the Unit Test Framework Toolkit installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can also install LabVIEW and the Unit Test Framework Toolkit using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    Notes  If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    You can access the software and documentation known issues list online. Visit ni.com/r/lv2020toolkitski for an up-to-date list of known issues in LabVIEW Unit Test Framework Toolkit.
    The following item is the ID and title of a subset of issues fixed in LabVIEW 2020 Unit Test Framework Toolkit. This is not an exhaustive list of issues fixed in the current version of Unit Test Framework Toolkit. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    972907Unit Test Framework .lvtest file opens blank and reports that class cannot be loaded if there is unrelated class that is broken in project.
    972908JUnit XML report is not generated due to a VI Path error.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Unit Test Framework Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Unit Test Framework folder to access the example. You also can find the examples for the Unit Test Framework Toolkit Toolkit in the labview\examples\Unit Test Framework directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW Unit Test Framework Toolkit will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2008–2020 National Instruments. All rights reserved.
    375338G-01
    GMT+8, 2026-2-25 02:41
