查看: 3506|回复: 0
[NI软件产品] NI VeriStand 2012 Win32Eng PC版完整版及运行版NIVS2012
    昨天 08:40
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2020-7-25 00:04:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    VS2012.txt (343 Bytes, 下载次数: 2, 售价: 10 圆)
    NI VeriStand 2012 Readme
    March 2013
    This file contains important information about NI VeriStand 2012, including system requirements and installation instructions.
    NI VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and your simulation models. The NI VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be easily customized and extended with LabVIEW, NI TestStand, and other software tools.
    NI VeriStand includes a run-time editable user interface as well as a test manager you can use to configure and implement triggered multi-file data logging, real-time test sequencing, stimulus generation and playback, and model calibration.
    The following sections describe support considerations for using NI VeriStand in various types of systems.
    Windows Systems1Real-Time Targets
    Operating System
    • Phar Lap ETS
    • VxWorks
    RAM/Processor
    • 2 GB of RAM
    • Multi-core processor
    • PXI controller/desktop PC—At least 256 MB of RAM2
    • CompactRIO/Single-Board RIO—At least 128 MB of RAM2
    • (Required) NI-DAQmx driver software
    • (Required) NI-VISA software
    • (Recommended) NI-RIO driver software, used by NI FPGA targets
    • (Recommended) NI-XNET driver software, used by NI-XNET vehicle bus interface cards
    NI VeriStand software (install from MAX)
    1 The following considerations apply to using NI VeriStand on Windows:
    • NI VeriStand runs as a 32-bit application on all operating systems.
    • NI VeriStand does not support Windows 2000/NT/Me/98/95, Windows XP x64, Windows XP Service Pack 1 and 2, or the Windows Server non-R2 editions.
    • Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    2 You can achieve higher Primary Control Loop rates by using targets with higher-performance specifications.
    Note  The following sections describe system requirements that apply if you use models, LabVIEW functionality, and .NET APIs in your system.
    Simulation Models
    To configure and run a simulation using your existing compiled model, you need only NI VeriStand installed. You need additional software to perform other tasks with models, as the following list describes:
    • To develop a model using The MathWorks, Inc. Simulink® application software, you must be a licensed user of and have the following software installed on the host computer: The MathWorks, Inc. MATLAB® software (32-bit or 64-bit versions) and The MathWorks, Inc. Simulink software.
      Note  NI VeriStand supports only the 64-bit versions of the MATLAB or Simulink software starting in R2010b and continuing in the versions listed in the KnowledgeBase on ni.com.
    • To compile a model developed using The MathWorks, Inc. Simulink software for use on a Microsoft Windows or LabVIEW real-time target, you must be a licensed user of and have the following software installed on the host computer: The MathWorks, Inc. Real-Time Workshop® (Simulink Coder®).
    • For deploying a compiled model to a LabVIEW real-time target, refer to the KnowledgeBase on ni.com for a list of compilers that are tested and supported.
    If you use other modeling environments, contact your model vendor for requirements for developing a model and converting it into a compiled model.
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2012 or 2012 SP1 installed. The LabVIEW functionality in NI VeriStand always requires like-numbered versions.
    .NET
    The NI VeriStand .NET APIs require the following Microsoft software:
    • Microsoft .NET Framework 3.5 SP1, which uses Microsoft .NET Common Language Runtime (CLR) 2.0.
    • A .NET environment capable of interacting with .NET Framework 3.5 based assemblies, such as Microsoft Visual Studio 2008 SP1 or LabVIEW 2012.
    Complete the following steps to install NI VeriStand.
    • Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • (Optional) To use LabVIEW with NI VeriStand, install the like-numbered version of LabVIEW on the host computer.
    • Insert the NI VeriStand installation media and follow the instructions that appear on the screen.
    • Install the NI-DAQmx driver software from the NI Device Drivers DVD or any NI DAQmx driver DVD.
      Note  The NI-DAQmx driver software is required to deploy a system definition to any platform, including the localhost running Windows.
    • (Optional) If using NI-XNET, insert the NI-XNET installation media and follow the instructions that appear on the screen.
    • (Optional) Activate NI VeriStand when prompted by the installer, or activate at a later time using the NI License Manager.
    For a list of new features in NI VeriStand 2012, refer to the following topic in the NI VeriStand 2012 Help posted on ni.com or installed on disk: What's New in NI VeriStand 2012.
    The following sections describe issues to be aware of when you upgrade to NI VeriStand 2012.
    Models compiled from LabVIEW VIs (.lvmodel files) using LabVIEW 2011 SP1 or earlier must be recompiled using LabVIEW 2012. The LabVIEW functionality in NI VeriStand always requires like-numbered versions.
    Models Created with the NI VeriStand Model Framework
    In NI VeriStand 2012, if you recompile a model created with the NI VeriStand Model Framework from NI VeriStand 2011 SP1 or earlier and the model contains a signal(s) with a / character in its name, mappings to the signal(s) might be broken when you reload the model in a system definition file. You must correct the broken mappings before you can deploy and run the system definition file.
    PXI_Trig0 Configuration
    NI VeriStand 2012 automatically routes and reserves PXI_Trig0 lines on the backplanes of PXI chassis that contain a DAQ or FPGA chassis master hardware synchronization device. When you upgrade, complete the following steps to clear any existing manual routes or reservations of PXI_Trig0:
    • Open Measurement & Automation Explorer (MAX) and select the chassis.
    • On the Triggers pane for the chassis, clear any reservation for PXI_Trig0 on the appropriate bus and set routing for PXI_Trig0 to Dynamic.
    Note  If you use a Timing & Sync custom device as your chassis master hardware synchronization device, you do not need to reconfigure any settings.
    You also can minimize the delay that multiplexing causes by selecting Maximum in the Conversion Rate drop-down menu on the System Explorer configuration page for the DAQ device. Note that using the maximum possible Convert Clock rate reduces the accuracy of measurements.
    Updates and Notifications
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    NI VeriStand includes the following documentation resources:
    ResourceContentsAccess Instructions
    NI Veristand HelpConceptual, how-to, and reference information for using NI VeriStand.In software: Help»Search the NI VeriStand Help
    OR
    Windows Start menu: All Programs»National Instruments»NI VeriStand»VeriStand Help
    NI VeriStand .NET API HelpReference information for the .NET APIs included with NI VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including NI LabVIEW™ and NI TestStand™.Windows Start menu: All Programs»National Instruments»NI VeriStand»VeriStand .NET API Help.
    Using the NI VeriStand Model FrameworkInformation about how to use the NI VeriStand Model Framework to compile your existing C and C++ model code so you can load your models in NI VeriStand.You can access this guide from the \xxx\ModelInterface\custom directory, where xxx is the directory you specified when you installed the NI VeriStand Model Framework.
    Note  You must explicitly select NI VeriStand Model Framework when you run the NI VeriStand installer. By default, it does not install.
    Note  If you install NI VeriStand with the compatible version of LabVIEW, you also can access a subset of the NI VeriStand Help, including information about the NI VeriStand VIs and extending NI VeriStand functionality with LabVIEW, from the LabVIEW Help. From the pull-down menu in LabVIEW, select Help»LabVIEW Help.
    NI VeriStand includes several types of examples:
    • NI VeriStand Project—An example NI VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the <;Public Documents>\National Instruments\NI VeriStand\Projects\Example directory.
    • Stimulus Profile Editor—NI VeriStand Stimulus Profile Editor examples are located in the <;Public Documents>\National Instruments\NI VeriStand\Examples directory.
      Tip  On Windows 7/Vista, the default location of the <;Public Documents> directory is C:\Users\Public\Public Documents.
    • LabVIEW API—LabVIEW examples that use the NI VeriStand API are located in the <;Program Files>\National Instruments\LabVIEW 2012\examples\NI Veristand directory.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in NI VeriStand 2012.
    The following items are the IDs and titles of a subset of issues fixed in NI VeriStand 2012. This is not an exhaustive list of issues fixed in the current version of NI VeriStand. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    189658MAX custom scales cannot be used in NI VeriStand
    197250Model Count system channel does not tell you which model is late
    289947VeriStand does not reserve RTSI0 in FPGA timing mode to prevent others from using it
    311161.NET Model API incorrectly creates the .NET tree structure if the named signal has forward slashes
    316421A system using a SMIO X Series board will hang when during undeployment
    318323Opening a VI with a .NET indicator or control in a newer version of LabVIEW picks the old assembly from GAC
    318644Cannot choose from more than 16 ports for NI-XNET devices
    326902CJC readings from SCXI thermocouples are incorrect with multiple SCXI modules
    331299NI VeriStand transmits triggered XNET frames on deployment despite the lack of a trigger
    337662Decimated host-side logs can have phase change if list of channels being streamed changes
    338321The fault function in a real-time sequence doesn't completely fault the channel
    338837TDMS logs have nonstandard and inconsistent unit definitions
    343926NI VeriStand does not set up PXI_Trig0 routing for multiple PXI bus segments
    351622FPGA and DAQ devices don't slave to RTSI 0 when timing and sync device is specified as master timing device
    353025Changing the XNET database for one port deletes frames on all ports that reference the same database
    357744Workspace stops updating if one target throws an error
    360883NI VeriStand experiences significant delay when loading under a network connection without Internet access
    361329Embedded Data Logger: Operation 1 (close & open new file) doesn't flush buffer correctly
    363424Excluded/included frames do not save for Data Replay files
    364013Running .csv file as real-time sequence in NI VeriStand stimulus profile causes memory leak
    368357NI VeriStand Model Framework fails to register with MATLAB R2010a software and later
    381942Units in TDMS log files of alias channels are not set correctly
    371918XNET automatic frame processing does not allow single bit offsets
    372900CSV playback does not load files as read-only
    373564Stimulus Profile Editor ribbon drop-down menu does not contain icons
    373610Clicking white space in the channel browse dialog in Stimulus Profile Editor closes the dialog
    373807Creating DAQ analog input output channels in specific order causes deployment hang
    373896Streaming more than 1021 channels to the Stimulus Profile Editor results in bad data
    379042Information channels added to XNET frame can cause frame data to be incorrect
    381942Units in TDMS log files for alias channels are not set correctly
    382674NI VeriStand can hang when undeploying from Project Explorer
    384169Data logging does not report if data was lost
    385802CAN data replay feature replays excluded frames
    386870TDMS logs created by Embedded Data Logger have nonstandard and inconsistent unit definitions
    When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW and Measurement & Automation Explorer (MAX).
    Finding All Programs
    Important Information
    © 2009-2013 National Instruments. All rights reserved.
    GMT+8, 2026-1-8 00:51
