查看: 3368|回复: 1
[NI软件产品] NI VeriStand 2015 Evaluation Win32Eng PC版完整版及运行版NIVS2015评估版包含驱动5.69GB
    昨天 11:03
  • 签到天数: 3581 天
    发表于 2020-7-26 00:19:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI VeriStand 2015 Evaluation和标准版的NI VeriStand 2015比较,多了如DAQ、VISA等驱动程序。因此体积也大了不少。请根据实际情况考虑是不是需要带驱动版的,如不需要,则下载标准版的即可。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    VS2015DRV.txt (263 Bytes, 下载次数: 0, 售价: 20 元)
    NI VeriStand 2015 Readme
    August 2015
    This file contains important information about NI VeriStand 2015, including system requirements and installation instructions.
    Evaluating NI DIAdem
    Important Information
    NI VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and your simulation models. The VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be easily customized and extended with LabVIEW, NI TestStand, and other software tools.
    VeriStand includes a run-time editable user interface as well as a test manager you can use to configure and implement triggered multi-file data logging, real-time test sequencing, stimulus generation and playback, and model calibration.
    The following sections describe support considerations for using VeriStand in various types of systems.
    Windows Systems1Real-Time Targets
    Operating System
    • Windows 8.1/8/7/Vista (32-bit and 64-bit)
    • Phar Lap ETS
    • VxWorks
    • NI Linux Real-Time
    RAM/Processor
    • 2 GB of RAM
    • Multi-core processor
    • PXI controller/desktop PC—At least 256 MB of RAM2
    • CompactRIO/Single-Board RIO—At least 128 MB of RAM2
    • (Required) NI-DAQmx software 15.0
    • (Required) NI-VISA software 15.0 or later
    • (Recommended) NI-RIO 15.0 or later driver software, used by NI FPGA targets
    • (Recommended) NI-XNET 15.0 or later driver software, used by NI-XNET vehicle bus interface cards
    VeriStand software (install from NI Measurement & Automation Explorer (MAX))
    1 The following considerations apply to using VeriStand on Windows:
    • VeriStand runs as a 32-bit application on all operating systems.
    • VeriStand does not support Windows 2000/NT/Me/98/95, Windows XP x64, Windows XP Service Pack 1 and 2, or the Windows Server non-R2 editions.
    • Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    2 You can achieve higher Primary Control Loop rates by using targets with higher-performance specifications.
    Note  The following sections describe system requirements that apply if you use models, LabVIEW functionality, and .NET APIs in your system.
    Simulation Models
    To configure and run a simulation using your existing compiled model, you need only VeriStand installed. You need additional software to perform other tasks with models, as the following list describes:
    • To develop a model using The MathWorks, Inc. Simulink® application software, you must be a licensed user of and have the following software installed on the host computer: The MathWorks, Inc. MATLAB® software (32-bit or 64-bit versions) and The MathWorks, Inc. Simulink software.
    • To compile a model developed using The MathWorks, Inc. Simulink software for use on a Microsoft Windows or LabVIEW real-time target, you must be a licensed user of and have the following software installed on the host computer: The MathWorks, Inc. Real-Time Workshop® (Simulink Coder®). Visit ni.com/info and enter the Info Code exxymi for a list of compilers that are tested and supported.
    • The VeriStand Model Framework only supports certain versions of The MathWorks, Inc. Simulink® software. If the VeriStand Model Framework is used with an unsupported version of The MathWorks, Inc. Simulink®, VeriStand cannot initialize it.
    If you use other modeling environments, contact your model vendor for requirements for developing a model and converting it into a compiled model.
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2015. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    • Microsoft .NET Framework 4.0, which uses Microsoft .NET Common Language Runtime (CLR) 4.0.
    • A .NET environment capable of interacting with .NET Framework 4.0 based assemblies, such as Microsoft Visual Studio 2010 or LabVIEW 2014.
    Complete the following steps to install VeriStand.
    • Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • (Optional) To use LabVIEW with VeriStand, install the like-numbered version of LabVIEW on the host computer.
    • Insert the VeriStand installation media and follow the instructions that appear on the screen.
    • Install the NI-DAQmx driver software from the NI Device Drivers DVD or any NI-DAQmx driver DVD.
      Note  The NI-DAQmx driver software is required to deploy a system definition to any platform, including the localhost running Windows.
    • (Optional) If using NI-XNET, insert the NI-XNET installation media and follow the instructions that appear on the screen.
    • (Optional) Activate VeriStand when prompted by the installer, or activate at a later time using the NI License Manager.
    The VeriStand 2015 media kit includes an evaluation version of NI DIAdem. NI DIAdem is a software tool you can use to locate, load, visualize, analyze, and report measurement data from real-time tests. You can use VeriStand with DIAdem to automate the post-processing of data collected in VeriStand, view trend data across multiple files and file types, and generate custom reports.
    For a list of new features in VeriStand 2015, refer to the following topic in the NI VeriStand 2015 Help posted on ni.com or installed on disk: What's New in NI VeriStand 2015.
    The following sections describe issues to be aware of when you upgrade to VeriStand 2015.
    Note  National Instruments recommends that you also review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2015. To access the documents, refer to the National Instruments website at ni.com/info and enter the Info Code for the appropriate VeriStand version from the following list:
    • VeriStand 2010 readme—NIVeriStand2010RM
    • VeriStand 2011 readme—NIVeriStand2011RM
    • VeriStand 2011 SP1 readme—NIVeriStand2011SP1RM
    • VeriStand 2012 readme—NIVeriStand2012RM
    • VeriStand 2013 readme—NIVeriStand2013RM
    • VeriStand 2013 SP1 readme—NIVeriStand2013SP1RM
    • VeriStand 2014 readme—NIVeriStand2014RM
    Uncompiled Models
    VeriStand 2015 does not support communication with uncompiled models.
    Models compiled from LabVIEW VIs (.lvmodel files) using LabVIEW 2014 or earlier must be recompiled using LabVIEW 2015. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    The VeriStand Model Framework contains changes to the files you use to develop and compile models in C/C++ and third-party modeling environments. If your system contains models compiled with previous versions of the Model Framework, choose from the following options for continuing to use the models in VeriStand 2015:
    • If you do not need to update your model or deploy it to Intel x64-based Linux targets that run NI Linux Real-Time, you can continue to use the model as-is.
    • If you need to update functionality of your model that does not require the changes in the latest version of the Model Framework, you can recompile the model against the deprecated Model Framework files. These files are installed at RootDrive:\VeriStand\version\ModelInterface\custom\src\obsolete. However, you cannot deploy the recompiled model to Intel x64-based targets that run NI Linux Real-Time.
    • To take advantage of the new features in the latest version of the Model Framework, or if you need to deploy the model to Intel x64-based targets that run NI Linux Real-Time, update and recompile the models using the 2015 version of the Model Framework. Update your models according to the following differences between new files in the Model Framework and the deprecated files they replace:
      • ni_modelframework.h contains the following differences from NIVERISTAND_API.h:
        • Implements fixed-width data types from the C99 standard, such as replacing int with int32_t where applicable.
        • Replaces use of the long data type with int32_t or uint32_t where applicable to achieve cross-platform compatibility.
      • ni_modelframework.c contains the following differences from codegen.c:
        • This file is installed on disk at \src\ni_modelframework.c rather than in the directory.
        • USER_TakeOneStep() now returns an int32_t value rather than void. If the function completes successfully, it returns NI_OK. If an error occurs, this function returns NI_ERROR.
        • The USER_ModelName global variable is a const char and replaces the ModelName variable.
        • The USER_Builder global variable is a const char and replaces the build variable.
        • The USER_BaseRate global variable is a const char and replaces the baserate variable.
    New Location for VeriStand Model Framework Examples
    The example models included with the Model Framework are located at RootDrive:\VeriStand\version\ModelInterface\custom\examples.
    Migrating Files from VeriStand 2009 and Earlier
    The mutation tool is not available in VeriStand 2015. All rig files and in4 files must be migrated using a previous version of VeriStand.
    Select Built-In Custom Devices Not Included
    In VeriStand 2015, you cannot add new instances of the Lambda Genesys and Pickering custom devices. Systems that already contain these custom devices can continue to use them.
    Visit ni.com/info and enter Info Code exjpt3 to access a page that details how to access the source code for the Lambda Genesys and Pickering custom devices.
    VeriStand Updates and Notifications
    ResourceContentsAccess Instructions
    NI Veristand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Search the NI VeriStand Help
    OR
    Windows Start menu: All Programs»National Instruments»NI VeriStand»VeriStand Help
    NI VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including NI LabVIEW™ and NI TestStand™.Windows Start menu: All Programs»National Instruments»NI VeriStand»VeriStand .NET API Help.
    NI VeriStand Model Framework IntroductionInformation about how to use the VeriStand Model Framework to compile your existing C and C++ model code so you can load your models in VeriStand.You can access this guide from the RootDrive:\VeriStand\xxxx\ModelInterface\custom directory, where RootDrive is the drive where NI software installs and xxxx is the VeriStand version number.
    Note  You must explicitly select NI VeriStand Model Framework when you run the VeriStand installer.
    Note  If you install VeriStand with the compatible version of LabVIEW, you also can access a subset of the NI VeriStand Help, including information about the VeriStand VIs and extending VeriStand functionality with LabVIEW, from the LabVIEW Help. From the pull-down menu in LabVIEW, select Help»LabVIEW Help.
    VeriStand includes several types of examples:
    • NI VeriStand Project—An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the <;Public Documents>\National Instruments\NI VeriStand\Projects\Example directory.
    • Stimulus Profile Editor—VeriStand Stimulus Profile Editor examples are located in the <;Public Documents>\National Instruments\NI VeriStand\Examples directory.
      Tip  On Windows 7/Vista, the default location of the <;Public Documents> directory is C:\Users\Public\Public Documents.
    • LabVIEW API—LabVIEW examples that use the VeriStand API are located in the <;Program Files>\National Instruments\LabVIEW 2015\examples\NI Veristand directory.
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code NIVeriStand2015KI for an up-to-date list of known issues in VeriStand 2015.
    The following items are the IDs and titles of a subset of issues fixed in VeriStand 2015. This is not an exhaustive list of issues fixed in the current version of VeriStand. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    519509Compilation of a The MathWorks, Inc. Simulink® model with Data Store Memory fails for NI Linux Real-Time targets
    514054Referencing the same system definition channel with variables of different data types in a real-time sequence can cause unexpected behavior
    514005DIO lines created with the System Definition API's DAQDevice constructor are assigned incorrect physical addresses
    513819VeriStand does not set the Convert Late Errors To Warnings DAQmx and only Warmup Iterations for the DAQ timing master's AI tasks
    507923Compilation of The MathWorks, Inc. Simulink® model fails when using alias or fixed-point types in bus objects
    505010Default values are hidden for large array variables in real-time sequences
    498982VeriStand becomes unresponsive when loading Fibex files with "Reverse Incoming/Outgoing frames from database" set to TRUE
    495142Real-time sequence return values are limited to the 32-bit int data type
    490670FPGA initialization prevents the correct loading of XNET ports, resulting in Error -307719
    486719Compilation of The MathWorks, Inc. Simulink® model fails when a referenced model uses tunable parameters
    481334Refreshing a model changes the default values back to zero
    481040Custom device tree operations within action VI on load fail with Error 1088
    463995A disabled CAN frame will send zero values when CRC is present in that frame
    460515Expanding and contracting collapsible groups in real-time sequences can change the order of operations of the sequence
    456532Resetting a target with the System Command Channel stops the VeriStand Workspace from updating
    414593Adding sections to a custom device can throw Error 1088
    408283An XNET Database cannot be refreshed using the System Definition API
    403806The System Definition API CreateMode method only creates one mode for a given multiplexer value
    403316The System Definition API creates unnecessary properties when adding XNET frames
    373810If a master DAQ device has both AI and AO out channels, disabling HWTSP for either AI or AO causes the device to lose its master timing status
    361241The System Definition API does not expose the model execution group property
    345604Adding frames to a disabled CAN port throws Error -307662
    339518XNET Device Driver fails to deploy after formatting controller
    329546If DAQmx driver is installed on target after VeriStand, Error -88717 may occur on reboot
    319988XNET Database Editor throws error if there is a " . " in the name of the .dbc file
    309168Double-clicking a stimulus file on disk with an editor already open opens a brand new editor window
    Using NI Launcher
    Finding All Programs
    VeriStand Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments VeriStand will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of VeriStand that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    LabWindows™/CVI™cvi_lifecycle
    © 2009-2015 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents.
  • 签到天数: 1 天
    发表于 2023-8-28 15:37:44 | 显示全部楼层 来自:江苏省无锡市 电信
    GMT+8, 2025-7-2 05:12
