查看: 4256|回复: 0
[LV工具模块] LabVIEW 2009 Datalogging and Supervisory Control Module Win32Eng LV2009数据记录和监控模块DSC2009
    4 小时前
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2020-7-27 18:34:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请注册登录视觉论坛会员,购买附件下载查看
    DSC2009.txt (677 Bytes, 下载次数: 1, 售价: 50 圆)
    LabVIEW 2009 Datalogging and Supervisory Control Module Readme
    June 2009
    This file contains important information about the LabVIEW 2009 Datalogging and Supervisory Control (DSC) Module, including installation issues and changes from the DSC Module 8.6.1. Refer to the LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes, which are available in your DSC Module software kit, for upgrade and compatibility issues of the DSC Module.
    Supported Platforms
    DSC Module 2009 Features and Changes
    Additions to the DSC Module Help
    Supported Platforms
    The DSC Module supports Windows Vista/XP/2000. The DSC Module does not support Windows Server 2003/NT/Me/98/95. Refer to the LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes for a complete list of system requirements.
    You can install all of your LabVIEW products—including the DSC Module—using the LabVIEW 2009 Platform DVDs. You can find installation instructions for the DSC Module along with activation instructions in the following locations:
    • LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes, which are available in your DSC Module software kit.
    • LabVIEW 2009 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 Platform DVDs, refer to the National Instruments Web site.
    The following list contains the new features and changes of the DSC Module. Refer to the LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes for a complete list of the new features and changes.
    • You can create EPICS Server I/O servers in the DSC Module to publish local and remote shared variables and I/O data to an EPICS network.
    • Use the navigation controls located on the System and Modern palettes to navigate through multiple front panels in an application. Navigation controls include the Previous Button, Next Button, and Jump Button controls.
    • The DSC Module includes enhancements to the NI Distributed System Manager. You can use the System Manager to monitor historical trends for shared variables, register remote computers, and enable logging for processes.
    • The DSC Module includes enhancements to custom I/O servers. When you build an application that includes custom I/O servers, LabVIEW detects and copies all dependent custom I/O servers to the build. When you deploy the built application to the target computer, LabVIEW distributes and upgrades the custom I/O servers to the target computer automatically. You can use the System Manager to monitor and debug custom I/O servers.
    • The DSC Module provides Run-Time System support for Touch Panel devices. You can distribute a built application to a Touch Panel target by installing the DSC Module Run-Time System on the Touch Panel device.
    • The DSC Module includes a list of new VIs.
    • The DSC Module includes the following new examples:
      • Citadel Web Services—This example demonstrates how to export the DSC Module database functionality into Web services and request historical data from remote computers. Refer to the readme.html file in the labview\examples\lvdsc\Applications\Citadel Web Service\Citadel Web Services.lvproj for information about using this example.
      • Navigation Controls—This example demonstrates how to use the navigation controls and integrate the navigation controls into DSC Module applications. Access this example by double-clicking the Main VI in the labview\examples\TouchPanel\Navigation Controls\Navigation Controls.lvproj.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the DSC Module.
    Use the DSC Settings: Process page of the Project Library Properties dialog box to save the states of shared variables in a process periodically.
    This page includes the following components:
    • Save State Periodically—Specifies whether the Shared Variable Engine (SVE) saves the states of shared variables periodically.
    • Period—Specifies the time interval, in seconds, that the SVE uses to save the states of shared variables.
    The following items are the IDs and titles of a subset of issues fixed in the DSC Module. If you have a bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the DSC Module.
    Bug IDFixed Issue
    48349Network-published shared variables might not function properly if multiple network adapters are enabled on the same computer. If you have multiple network adapters enabled, you can force the Shared Variable Engine to use a specific adapter by adding the following lines to the C:\Windows\logos.ini file:
    [LOGOS]
    ServiceBindTo=xx:xx:xx:xx:xx:xx
    where xx:xx:xx:xx:xx:xx represents the MAC address of the network adapter.
    51638Importing an EPICS record with a "." in the record name causes LabVIEW to crash.
    54461Front panel binding mass configuration changes default binding mode of read-only shared variables to write-only.
    105656The Create Database VI creates an invalid Windows directory if you specify a path that has a space in the end for this VI.
    122032The Real-Time Trend Express VI within a loop forces the loop to wait for at least the "time interval" time of the Express VI.
    129725The cursor dialog box in the NI HyperTrend control does not display and cannot be restored.
    137799Detaching a database makes the .ldf and .mdl files lose permission information.
    138321The Create Process VI does not support creating a sub-process.
    139409The decimal delimiter does not apply to localized format when you export traces to text on a localized OS.
    141707LabVIEW hangs if you register multiple variable value change notifications in parallel.
    153435The Batch Variable Creation dialog box replaces existing variables if the specified base name in this dialog box matches the existing variable names.
    159602Programmatic creation of I/O servers does not accept sub-processes in the path.
    166356The Run-Time Engine replaces IP addresses with localhost in variable alias bindings when you programmatically deploy libraries in the Run-Time Engine.
    Important Information
    In regards to components that use Citadel 5, the following copyright applies. Copyright © 1994 Hewlett-Packard Company. Permission to use, copy, modify, distribute and sell this software and its documentation for any purpose is hereby granted without fee, provided that the above copyright notice appears in all copies and that both that copyright notice and this permission notice appear in supporting documentation. Hewlett-Packard Company makes no representations about the suitability of this software for any purpose. It is provided "as is" without express or implied warranty.
    GMT+8, 2025-12-5 13:11
