查看: 4313|回复: 0
[NI软件产品] NI SystemLink Suite 18.2.1 Win32Eng NI系统连接套件18.2.1版百度网盘下载
    昨天 16:03
    发表于 2020-7-28 10:22:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SystemLink软件为测试和测量系统提供软件部署、系统配置、测试监控和数据管理工具。
    SystemLink软件提供了一个基于网络的解决方案来管理所连接系统、软件配置以及测试结果和测量数据,进而帮助企业提高运营效率和生产力。SystemLink可以与LabVIEW、NI TestStand、LabVIEW NXG(SystemLink19.6版以后支持)、DIAdem(SystemLink19.0版以后支持)等NI软件以及硬件之间完全互操作,包含了用于集成各种第三方软件和硬件技术的工具。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    SL18.2.1.txt (303 Bytes, 下载次数: 0, 售价: 20 圆)
    文件大小: 1762364281 字节 (1.64 GB)
    修改日期: 2018-10-24 14:04
    MD5: 67a7e31a4df557060e36272e52c79a10(官方正确)
    SHA1: 34ee37e00049eb49e557c1ae6e66a5188bc6d931
    SHA256: 6a4835f24c52a4be5905089b40ea9b1f24c3e4e1226ad7c09e355bfe17f9e138
    CRC32: 338c940f
    NI SystemLink 18.2 Readme
    October 2018
    This file contains important information about NI SystemLink, including system requirements and known issues.
    Licensing Information for SystemLink Clients
    Use NI SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage Skyline data services to visualize data, trigger alarms, monitor tests,and transfer files over a server.
    NI SystemLink has the following minimum system requirements:
    Server Requirements
    Windows, less than 50 nodes
    Windows, 50+ nodes
    OS
    Windows Server 2016
    Windows Server 2012 R2 (64-bit)
    Windows 7 SP1 (64-bit) or higher
    Windows Server 2016
    Processor
    2-core recommended or higher
    8-core recommended or higher
    RAM
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    Disk
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    Target Requirements (Managed Nodes)
    NI PXI (Windows) or Windows PC
    NI CompactRIO
    OS
    NI Linux Real-Time 2018
    Processor
    Pentium 4 G1 (or equivalent) or later
    All Intel and ARM models supported
    RAM
    2 GB minimum
    4 GB recommended
    512 MB minimum
    1+ GB recommended
    Note: NI SystemLink does not support targets with less than 512 MB of RAM.
    Disk
    1 GB minimum
    2+ GB recommended
    512 MB
    Note that VxWorks and Phar Lap OS are not supported.
    • .NET Framework 4.6.2
    • One of the following browsers:
      • Chrome
      • Firefox
      • Edge
      • Safari
    LabVIEW Requirements
    NI SystemLink 18.2 supports the following LabVIEW versions:
    • LabVIEW 2015, 2016, 2017, 2018
    • LabVIEW RT 2017, 2018
    SystemLink uses Volume License Manager to license clients. Download NI Volume License Manager from ni.com and refer to the NI Volume License Manager help for more information on licensing.
    If you evaluate NI SystemLink Server before activating, any clients you connect will initially appear as Not Activated in Systems Manager. Use NI SystemLink Web Application to activate the client after you activate the server.
    Installing SystemLink onto a machine with TDM Server 2017 already installed will break TDM Server 2017. NI recommends you install SystemLink on a different machine or uninstall TDM Server 2017 prior to installing SystemLink.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in SystemLink.
    The following items are the IDs and titles of a subset of issues fixed in SystemLink. This is not an exhaustive list of issues fixed in the current version of SystemLink. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    705179Message web service flush method call always responds with HTTP response 400
    704966Using the LabVIEW SystemLink API's Flush.vi causes future reads of an empty message queue to error out instead of timing out
    703514Targets or devices connected to a target with a dot or period in their names can't connect to the SystemLink Server
    702025The LabVIEW Tag HTTP API doesn't return partial success errors
    700857Systems Manager times out when retrieving the available packages for a Windows System
    Refer to the NI SystemLink Help, accessible from ni.com, for more information about NI SystemLink.
    Refer to the SystemLink GitHub repository for examples and HTTP API documentation.
    © 2017-2018 National Instruments. All rights reserved.
    377243E-01
    GMT+8, 2026-2-24 23:49
