查看: 3373|回复: 0
[LV工具模块] LabVIEW SystemLink Toolkit 19.6.0 Win32/64Eng LabVIEW系统连接工具包SLT19.6.0下载
    9 小时前
    发表于 2020-7-28 23:49:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW SystemLink工具包提供了LabVIEW或LabVIEW NXG与SystemLink Server或SystemLink Cloud账户进行通信的工具。
    LabVIEW SystemLink工具包是一个软件附件,包含用于LabVIEW的SystemLink API。该附件可通过编程方式访问SystemLink数据服务,这样就可在SystemLink Web应用程序之外集成SystemLink和LabVIEW。您可以使用LabVIEW SystemLink工具包为测试和测量系统创建VI或WebVI。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    SL19.6.0.txt (312 Bytes, 下载次数: 0, 售价: 10 圆)
    NI SystemLink 19.6 Readme
    May 2020
    This file contains important information about NI SystemLink, including system requirements and known issues.
    Licensing Information for SystemLink Clients
    SystemLink Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Use NI SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage SystemLink data services to visualize data, trigger alarms, monitor tests, manage assets, and transfer files to a server. SystemLink TDM is a Big Analog Data™ solution for automated preparation and analysis of large amounts of data in various formats and structures from different geographic locations.
    NI SystemLink has the following minimum system requirements:
    Server Requirements
    Windows, less than 50 nodes
    Windows, 50+ nodes, SystemLink TDM
    OS
    Windows Server 2016
    Windows Server 2012 R2 (64-bit)1
    Windows 7 SP1 (64-bit) or higher
    Windows Server 2016
    Processor
    4-core recommended or higher
    8-core recommended or higher
    RAM
    16 GB minimum
    32+ GB recommended
    32 GB minimum
    64+ GB recommended
    Disk
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    1 NI software installs VC2015 runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2, which require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    Note  Refer to SystemLink Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  SystemLink TDM does not support server versions from the Microsoft Semi-Annual Channel. In addition, SystemLink TDM does not support Windows Server Core mode.
    Target Requirements (Managed Nodes)
    NI PXI (Windows) or Windows PC
    NI CompactRIO
    OS
    Windows 7 SP1 (32-bit) or higher
    NI Linux Real-Time 2019
    Processor
    Pentium 4 G1 (or equivalent) or later
    All Intel and ARM models supported
    RAM
    2 GB minimum
    4 GB recommended
    512 MB minimum
    1+ GB recommended
    Disk
    1 GB minimum
    2+ GB recommended
    512 MB
    Note: VxWorks and Phar Lap OS are not supported.
    • .NET Framework 4.6.2
    • One of the following browsers:
      • Chrome
      • Firefox
      • Edge
      • Safari
    Note: NI SystemLink 19.6 web applications do not support Internet Explorer.
    Supported Software
    NI SystemLink 19.6 supports the following LabVIEW versions:
    • LabVIEW 2016, 2017, 2018, 2019
    • LabVIEW RT 2017, 2018, 2019
    • LabVIEW NXG 4.0
    SystemLink TDM supports the following DIAdem versions as clients:
    • DIAdem 2015, 2017, 2018, 2019 (recommended)
    SystemLink uses Volume License Manager to license server modules and add-ons as well as clients. Download NI Volume License Manager from ni.com and refer to the NI Volume License Manager help for more information on licensing.
    If you evaluate NI SystemLink Server before activating, any clients you connect will initially appear as Not Activated in Systems Manager. Use NI SystemLink Web Application to activate the client after you activate the server.
    Known IssuesYou can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in SystemLink.Bug FixesBug Fixes in 19.6
    The following items are the IDs and titles of a subset of issues previously fixed in SystemLink. This is not an exhaustive list of issues fixed in the current version of SystemLink.
    ID
    Fixed Issue
    956208TestStand plugin crash during result processing due to invalid pointer.
    205481Asset Module allows users without create, modify, and delete permissions to modify assets since the action buttons are not disabled.
    206113Systems grid displays an icon for a system with an active custom alarm but it does not display the active alarms when you click it.
    206327Storing utilization data on a client is not limited to 30 days.
    209939Step names with HTML cause Chrome to render the HTML.
    217374All notebook reports break after upgrading the server if SystemLink Client is installed.
    218625OPC client fails to start after one year.
    315377Asset Management services tracks utilization data for assets not present in the system.
    466037Clicking full screen for the Asset Manager dashboard does nothing.
    579681Jobs History UI view crashes if some migrated jobs do not contain configuration information or metadata.
    897324When creating a Linux state, you must disable the Products Only filter.
    898076Create Test Result VI does not return an error for server connection issues.
    899707The Parametric Data view uniformly treats measurement data with mixed data types as strings.
    916387Service Manager fails to start on locked down machines due to its use of SHA1 hashing.
    Bug Fixes in 19.6.1The following items are the IDs and titles of issues fixed in SystemLink 19.6.1. If you have a bug ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    952821MessageBus does not properly wrap all exception types when creating RabbitMQ channels.
    955323Trend queries do not include the originally selected step.
    955822Selecting multiple step paths from the Parametric Data View results in incorrect step queries.
    956202Store and forward fallback logic for TestStand plugin allows errors through in some cases during execution start.
    959701MessageBus configuration returns an error after changing registration status between executions.
    Bug Fixes in 19.6.2The following items are the IDs and titles of issues fixed in SystemLink 19.6.2. If you have a bug ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    950454SystemLink OPC UA tags stop updating if network connections to server is reconnected.
    964383Parametric data viewer shows no data for steps updated with new measurements after step creation.
    Bug Fixes in 19.6.3The following items are the IDs and titles of issues fixed in SystemLink 19.6.3. If you have a bug ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    973762A malformed Dynamic Linq query of assets will always return 'An unknown error occurred' instead of a description of the error in the query.
    973764If the network connection between SystemLink and an OPC UA server is interrupted and then restored, monitored tags stop updating with new values.
    973765The trend view of a single selected step displays no data points. If a user selects a single result of a uniquely named step, the resulting graph will be blank.
    973772There is a memory leak in the Jupyter notebook execution service.
    973773Dynamic Linq queries for list properties that do not contain a specific value will also return values that have a null value for that property.
    973774When at least one Windows and one NI Linux Real-Time client are selected and the system images page is open, the page may hang and timeout before a list of images can be returned.
    1032217SaltStack security vulnerabilities CVE-2020-11651, CVE-2020-11652.
    Refer to the NI SystemLink Manual, accessible from ni.com, for more information about NI SystemLink and the services and APIs it offers.
    SystemLink will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2017-2020 National Instruments. All rights reserved.
    377243L-01
    GMT+8, 2025-12-8 19:08
