查看: 3560|回复: 0
[LV工具模块] LabVIEW 2019 FPGA Compile Farm Toolkit Win32/64Eng LabVIEW2019FPGA集群编译工具包FPGA-CFT2019
    昨天 16:03
    发表于 2020-8-3 00:13:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW FPGA Compile Farm工具包可帮助您创建现场服务器,轻松管理FPGA编译。
    LabVIEW FPGA Compile Farm工具包可帮助您创建现场服务器,轻松管理FPGA编译。用户可根据需要连接多台编译计算机;中央服务器软件负责管理并行编译和队列之外的集群部署(farming)。为了帮助用户缩短FPGA编译时间,该工具包还可支持Linux编译服务器计算机。
    FPGA CFT2019,官方说明可以支持英语、德语、法语、日语、韩语、中文等多国语言版本,但是在2020之后版本又仅支持英语了,所以大概该工具包只有英文版,并没有中文等多国语言版本。具体内部函数及帮助文档等是否有多国语言版本,得自己验证,我方不使用该工具包不提供验证服务。
    LabVIEW 2019 FPGA Compile Farm工具包
    发布日期:2019/5/13
    包含的版本:2019
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 10
    Windows 8.1
    语言:中文, 德语, 日语, 法语, 英文, 韩语
    程序位数:32/64位
    文件大小: 418351104 字节 (398.97 MB)
    修改日期: 2019-05-14 03:18
    MD5: 7e1e5095c1318540e712f41a2d6db5cc(官方正确)
    SHA1: 0470c4aac3e9ce29128c72884c40891137a1a07d
    SHA256: 09efdb02bb2304eded60fe7b3375511312311efcbf5c655ff090f11089ad6ea2
    CRC32: db9cd273
    百度网盘下载地址和NI官方下载地址:
    CFT2019.txt (290 Bytes, 下载次数: 1, 售价: 10 圆)
    CFT2019未提供自述文件,NI官方也仅提供了FPGA2019的自述文件:
    LabVIEW 2019 FPGA Module Readme
    March 2019
    This file contains important information about the LabVIEW FPGA Module, including system requirements, installation instructions, upgrade and compatibility issues, new features, and known issues, and a partial list of bugs fixed for this release.
    FPGA Module System Requirements
    FPGA Compile Farm Server System Requirements
    FPGA Module (64-Bit)
    FPGA Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    With the LabVIEW FPGA Module, you can create VIs that run on NI FPGA targets, such as Reconfigurable I/O (RIO) devices. The FPGA Module helps you design complex systems by providing a highly-integrated development environment, a large ecosystem of IP libraries, a high-fidelity simulator, and debugging features. The FPGA Module also includes FPGA IP Builder and the FPGA Compile Farm Server. You can use FPGA IP Builder to efficiently implement your LabVIEW algorithms for FPGA targets and to generate FPGA code that meets specific performance requirements. FPGA IP Builder supports only a subset of FPGA targets. Visit ni.com/info and enter the Info Code exvxfe for a list of supported targets. You can use the FPGA Compile Farm Server to offload compiles to dedicated computers.
    The development computer is a PC or NI PXI/PXI Express system on which you install LabVIEW and the FPGA Module. You can also install the Xilinx compilation tools on your development computer to compile LabVIEW FPGA VIs locally. However, if the FPGA design or target requires more than 2 GB of memory, NI recommends you install the Xilinx compilation tools on a separate computer. This computer is referred to as the remote compile worker.
    The development computer must meet the following system requirements:
    • LabVIEW 2019 Full or Professional Development Systems
    • 3 GB of additional disk space
    • Memory1:
      • At least 4 GB of RAM2 for Virtex-6 and later FPGA targets
      • Windows 10 (version 1809)/8.1 Update 13
      • Windows 7 SP14
      • Windows Server 2008 R2 SP14
      • In 2016 the FPGA Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2019 FPGA Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2019 FPGA Module to an unsupported OS. Additionally, after installing the LabVIEW 2019 FPGA Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
      • Refer to FPGA Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
      • Only the FPGA Interface functions are supported on Windows 8.1. FPGA development functionality is not fully supported as some of the features require the use of Xilinx compilation tools. These tools do not support Windows 8.1.
      • On 32-bit OSes, the FPGA Module does not support the following features on Xilinx Vivado targets:
        • FPGA IP builder
        • Third-party simulation
        • Configure Component-Level IP wizard
        • Configuring or regenerating IP using the IP Integration Node or Xilinx IP functions
        • Simulating FPGA VIs that use the IP Integration Node or Xilinx IP functions
    • FPGA device
    • Device driver software—To program most devices with the LabVIEW 2019 FPGA Module, install the device driver software. Refer to the hardware documentation for requirements for a specific device.
    1 Memory requirements vary according to both the FPGA target and the FPGA VI you create for that target.
    2 You must use a 64-bit OS to address 4 GB of RAM.
    3 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    4 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2019.
    If you install the FPGA Compile Farm Server on a separate computer, you can configure that computer to be a remote compile farm server. If you install the Xilinx compilation tools on a separate computer, you can configure that computer to be a remote compile worker.
    Refer to the Setting Up a Remote Compile Farm Server or Compile Worker section of this document for information about setting up and using a local or remote compile farm server or compile worker. Visit ni.com/info and enter the Info Code XilinxCompileTools for more information about the NI hardware supported by each Xilinx compilation tool.
    You can use either a Windows or Linux computer as a compile worker. Refer to the Xilinx Compilation Tools Readme for information about the minimum system requirements.
    The remote compile farm server must meet the following minimum system requirements:
    • 35 MB of disk space
    • 1 GB RAM
      • Windows 10 (version 1809)/8.1 Update 11
      • Windows 7 SP12
      • Windows Server 2008 R2 SP12
      Note  In 2016 the FPGA Compile Farm Server dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2019 FPGA Compile Farm Server will not install or run on an unsupported OS. Refer to FPGA Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    • Web browser that supports Microsoft Silverlight for accessing compile job queues via the NI Web-based Configuration & Monitoring Service FPGA Compile Farm Console
    Note  The FPGA Compile Farm Server supports the LabVIEW 2010 FPGA Module or later.
    This section provides information about installing the FPGA Module and related components.
    Note  If you are upgrading from a previous version of LabVIEW, you must install the LabVIEW 2019 FPGA Module before mass-compiling existing FPGA VIs. Otherwise, some FPGA-specific VIs might have mutation issues.
    Installing the FPGA Module on a Development Computer
    To install LabVIEW and the FPGA Module using the LabVIEW Platform media, complete the following steps:
    • Log in as an administrator or as a user with administrative privileges.
    • Insert the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website. If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchases to install this product.
    • Follow the instructions on the screen to install and activate the following software in this order:
      • LabVIEW
      • FPGA Module
      • Xilinx Compilation Tools—Install these compilation tools on the development computer if you want to compile your LabVIEW FPGA VIs locally. You must install these tools on your development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, use FPGA IP Builder, or use third-party simulation. Refer to your hardware documentation for information about the FPGA chip in your device and install the appropriate set of tools. Visit ni.com/info and enter the Info Code XilinxCompileTools for more information about the NI hardware supported by each Xilinx compilation tool.
        • Xilinx Compilation Tools for Windows—Install these compilation tools if you will compile your FPGA VIs on a Windows computer. The Xilinx compilation tools for Windows include Vivado 2017.2 and ISE 14.7.
        • Xilinx 10.1 Compilation Tools—Install the Xilinx 10.1 compilation tools if your FPGA device contains a Xilinx Virtex II chip. To download the Xilinx 10.1 compilation tools, refer to ni.com/info and enter the Info Code FPGATool101.
        Note  To configure the IP Integration Node, or use the Configure Component-Level IP wizard on Virtex-II devices, you also must install the Xilinx Compilation Tool for ISE 14.7. Xilinx IP and simulation exports are not supported on Virtex-II FPGA devices.
      • (Optional) FPGA Compile Farm Server—Use the FPGA Compile Farm Server to distribute FPGA VI compile jobs across multiple remote computers.
        Note  Use the LabVIEW FPGA Compile Cloud Service to increase the development efficiency by offloading compile jobs to multiple computers in a cloud environment.
      • (Optional) LabVIEW Real-Time Module—Use the LabVIEW Real-Time Module to program the real-time OS on NI PXI, NI PXI Express, NI CompactRIO, and NI Single-Board RIO devices. You have a temporary license for this product.
      • Device Driver—Device drivers contain driver software for most FPGA targets. Refer to your FPGA target hardware documentation for information about additional or different device drivers you need.
    In addition to installing program files and documentation in the LabVIEW directory, the installer also puts files from Xilinx in the x:\NIFPGA directory, where x is the drive on which you installed LabVIEW. The FPGA Module uses these files to compile FPGA VIs into code that runs on an FPGA target.
    You can use the LabVIEW Platform media to install the FPGA Compile Farm Server to offload compiles to dedicated computer. You must install the FPGA Compile Farm Server separately on any remote machine that you want to use to manage your compilations. Also, you must install the Xilinx compilation tools on any machine that you want to use as a remote compile worker. Visit ni.com/info and enter the Info Code XilinxCompileTools for more information about the NI hardware supported by each Xilinx compilation tool.
    • Windows—Visit ni.com/info and enter the Info Code FPGAkb1rcs for information about setting up the FPGA compile farm server on a remote computer.
    • Linux—Refer to the FPGA Module Xilinx Compilation Tools for Linux Readme for information about setting up a remote compile worker.
    NI also offers the LabVIEW FPGA Compile Cloud Service to increase the development efficiency by offloading compile jobs to multiple computers in a cloud environment. Visit ni.com/trycompilecloud for information about the LabVIEW FPGA Compile Cloud.
    The FPGA Module (64-bit) provides access to more memory than the FPGA Module (32-bit) can provide. The FPGA Module (64-bit) is available in English only.
    The FPGA Module (64-bit) supports the following NI hardware devices:
    • PCIe-576x/577x/5785/798x
    • PXIe-5163R/5164R/517xR/5745/576x/577x/5785/659xR/7902R/791x/797xR/798x
    • USRP-RIO devices
    You cannot use an unsupported device with the FPGA Module (64-bit) or run example VIs that require an unsupported device in the FPGA Module (64-bit). Refer to the specific hardware documentation for more information about compatibility with the FPGA Module (64-bit).
    The LabVIEW 2019 FPGA Module includes the new UltraRAM implementation option in the General page of the FIFO Properties dialog box. Use this option to configure a FIFO to store data in UltraRAM resources available on most Xilinx UltraScale+ targets.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the FPGA Module.
    The following items are the IDs and titles of a subset of issues fixed in the FPGA Module. This is not an exhaustive list of issues fixed in the current version of the FPGA Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    410670The LabVIEW Help descriptions of the Mean, Variance, and Standard Deviation Express VI are not explicit as to the VI behavior.
    693443The Linux OS support listed in the LabVIEW 2018 FPGA Module Xilinx Compilation Tool for Vivado 2017.2 installer is incorrect
    694049Uninstalling the LabVIEW 2018 FPGA Module Xilinx Compilation Tool for Vivado 2017.2 from NI Package Manager does not uninstall the LabVIEW 2018 FPGA Module Patch for Vivado 2017.2 on Windows 10 (version 1709)
    702359CLIP Clock properties incorrectly display "Compile for a single frequency" if the clock is defined as a variable frequency clock in the CLIP XML file
    705767Certain special characters (such as "<" or ">") in a remote compile password can cause the compilation to exit with error -61488.
    725737Digital Output timing outside of Single-Cycle Timed Loops has extra delay
    If you upgrade from the LabVIEW 2017 FPGA Module or earlier to the LabVIEW 2019 FPGA Module, refer to previous versions of the LabVIEW FPGA Module readme or LabVIEW FPGA Module Release and Upgrade Notes, available on ni.com/manuals, for additional changes in previous versions of the FPGA Module.
    Note  The LabVIEW FPGA Module Release and Upgrade Notes document was deprecated from the 2016 release.
    Upgrading the FPGA Module requires you to upgrade to a new version of the Xilinx compilation tools. This upgrade can change the timing or resource utilization characteristics of FPGA VIs you developed in previous versions or cause these VIs to fail to compile. NI recommends that you test all FPGA designs after upgrading.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the FPGA Module.
    The FPGA Module will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2003–2019 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \National Instruments\LabVIEW \FPGA\Legal\
    374737K-01
    GMT+8, 2026-2-24 23:25
