查看: 4392|回复: 0
[LV工具模块] LabVIEW 2009 FPGA Module Win32Eng LabVIEW2009FPGA模块LVFPGA2009
    前天 16:03
    发表于 2020-8-4 11:07:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    我方未找到独立安装的FPGA2009。从SPB2009中可以看到有FPGA2009版本,但是尝试独立提取,发现有经过加密,文件打不开或打开乱码的情况。只能从SPB中进行安装FPGA2009版本。NI官方虽然有一个下载地址写的是LVFPGA2009,但是下载完成后,查看其版本号是9.0.1,是FPGA2009SP1版本。故FPGA2009版,只能考虑安装SPB2009中的版本。
    NI Software Platform Bundle-X86-Eng_2009_suite NI SPB2009 32位英文版下载,即NI软件平台套件2009版
    http://visionbbs.com/thread-24684-1-1.html
    LabVIEW 2009 FPGA Module Readme
    June 2009
    This file contains important information about the LabVIEW FPGA Module.
    Installation
    You can install all of your LabVIEW products—including the FPGA Module–using the LabVIEW 2009 Platform DVDs. You can find installation instructions for the FPGA Module along with activation instructions in the following locations:
    • LabVIEW FPGA Module Release and Upgrade Notes, which are available in your FPGA Module software kit or online at ni.com/manuals.
    • LabVIEW 2009 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 Platform DVDs, refer to the National Instruments Web site.
    You must install TCP. Most computers have TCP installed. If TCP is not installed, LabVIEW returns the Error Contacting Server message when it attempts to contact the LabVIEW FPGA Compile Server.
    You must install LabVIEW 2009 and the FPGA Module 2009 before you mass compile existing VIs. If you mass compile existing VIs before you install the FPGA Module 2009, the following VIs might have mutation issues: Sine Wave Generator, Discrete Delay, Quantizer, Look-Up Table 1D, Analog Period Measurement, Butterworth Filter, FIFO Read, FIFO Write, HDL Interface Node, Open FPGA VI Reference, Read/Write Control, Call VI, Close FPGA VI Reference, Invoke Method, Up Cast, FPGA I/O Method Node, and FPGA I/O Property Node.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the FPGA Module.
    The following items are the IDs and titles of a subset of issues fixed in the FPGA Module 2009.
    Bug IDFixed Issue
    150489LabVIEW hangs when adding a CLIP declaration path that contains an ampersand (&).
    132674LabVIEW crashes when right-clicking on a VI under a networked computer target.
    124795Global variables not updating correctly on FPGA VI.
    123925Compilation error when using FIFO Clear in a different domain than FIFO Write and Read.
    53298FPGA emulation error when using NI-9853 and CompactRIO.
    99457Multiple FIFO accessors not allowed in a state machine architecture inside a single-cycle Timed Loop.
    47652Compilation time error with reentrant VIs in a single-cycle Timed Loop.
    © 2003–2009 National Instruments Corporation. All rights reserved.
    Xilinx® is a registered trademark of Xilinx, Inc.
    GMT+8, 2026-2-25 03:05
