查看: 3184|回复: 0
[LV工具模块] LabVIEW 2011 SP1 FPGA Module Win32Eng LabVIEW2011SP1FPGA模块LVFPGA2011SP1英文版
    前天 16:03
    发表于 2020-8-4 16:18:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    FPGA2011SP1.txt (253 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2011 SP1 FPGA Module Readme
    Version 11.0.1
    December 2011
    This file contains important information about the LabVIEW FPGA Module.
    Installation
    You can install all of your LabVIEW products—including the FPGA Module–using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the FPGA Module along with activation instructions in the following locations:
    • LabVIEW FPGA Module Release and Upgrade Notes, which are available in your FPGA Module software kit or online at ni.com/manuals.
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the FPGA Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2011 SP1 FPGA Module.
    321818FPGA VI causes "ngdbuild.exe has stopped working" error.
    318512Compile Worker fails to start when using the older of two versions of installed LabVIEW FPGA.
    315613Simulation export build fails on localized European OSes.
    313939Statistics Function can have results that overflow.
    311252Xilinx compiler runs out of memory.
    308756Potential data corruption when using FlexRIO DRAM primitive or cRIO XNET Module.
    305700Mutation of controls connected to terminals of DSP48E is incorrect from 2010 to 2011.
    © 2003–2011 National Instruments Corporation. All rights reserved.
    I.     Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation.
    II.     Third-Party Copyright Notices
    \National Instruments\LabVIEW 2011\FPGA\Legal\
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    Xilinx® is a registered trademark of Xilinx, Inc.
    GMT+8, 2026-2-25 00:57
