查看: 3451|回复: 0
[LV工具模块] LabVIEW 2012 SP1 FPGA Module Win32Eng LabVIEW2012SP1FPGA模块LVFPGA2012SP1英文版
    前天 16:03
    发表于 2020-8-4 16:35:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    FPGA2012SP1.txt (264 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2012 SP1 FPGA Module Readme
    Version 12.0.1
    December 2012
    This file contains important information about the LabVIEW FPGA Module.
    The development computer is a PC or NI PXI/PXI Express system on which you install LabVIEW and the LabVIEW FPGA Module. You can use this computer to compile FPGA VIs, but if the FPGA design or target requires more than 2 GB of memory, National Instruments recommends installing the LabVIEW FPGA compilation tools on a separate computer. This computer is referred to as the remote compile server.
    Development Computer
    • LabVIEW 2012 Full or Professional Development Systems (32-bit)
    • 11 GB additional disk space
    • Memory1:
      • At least 4 GB of RAM for Virtex-6 and later2 FPGA targets
      Note: The LabVIEW 2012 SP1 FPGA Module does not support Windows 8.
      • Windows 7 (32-bit)3
      • Windows 7 (64-bit with 32-bit LabVIEW installed)
      • Windows Vista (32-bit)
      • Windows Vista (64-bit with 32-bit LabVIEW installed)
      • Windows XP Pro (Service Pack 3)
      • Windows Server 2003 R2 (32-bit)4
      • Windows Server 2008 R2 (64-bit with 32-bit LabVIEW installed)
    • FPGA device
    • Device driver software—To program most devices with the LabVIEW 2012 FPGA Module, install the NI-RIO 12.0 driver software. Refer to the hardware documentation for different requirements for a specific device.
    1Memory requirements vary according to both the FPGA target and the FPGA VI you create for that target. To determine your memory needs, monitor the memory usage of the xst.exe process in the Windows Task Manager.
    2You must use a 64-bit OS to address 4 GB of RAM.
    3The LabVIEW FPGA Module uses Xilinx compilation tools that do not officially support Windows 7. NI obtained permission from Xilinx to allow LabVIEW FPGA Module customers to use the tools on this platform, with the disclaimer that Xilinx is not able to fix any bugs found that are specific to this platform. NI tested the Xilinx tools that the LabVIEW FPGA Module uses and did not find any issues. If you encounter problems with the Xilinx tools and Windows 7, you might need to compile using Windows XP or Vista. In such cases, you might want to install the Xilinx compilation tools on a separate computer. Refer to the National Instruments website for information about installing the compilation tools on a separate computer. NI is not liable for any problems or issues related to the use of Xilinx tools with Windows 7.
    4The LabVIEW FPGA Module does not support the Windows Server non-R2 editions.
    Installation
    You can install all of your LabVIEW products—including the FPGA Module–using the LabVIEW 2012 Platform DVDs. You can find installation instructions for the FPGA Module along with activation instructions in the following locations:
    • LabVIEW FPGA Module Release and Upgrade Notes, which are available in your FPGA Module software kit or online at ni.com/manuals.
    • LabVIEW 2012 Installation Guide, which is available in your LabVIEW software kit.
    • LabVIEW 2012 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    • Activation Instructions for National Instruments Software, which are available on the LabVIEW intallation media.
    To request additional LabVIEW 2012 Platform DVDs, refer to the National Instruments website.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the FPGA Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2012 SP1 FPGA Module.
    351564ERROR:HDLCompiler:192 when using feedback nodes in for loop in subVIs.
    343721Diagram disable structures incorrectly affect polymorphic VI selection.
    334252LV FPGA 2011 places bitfile in wrong path after a project is overwritten.
    332811-61350 on FPGA intermediate file generation when using user controlled io.
    320103Wiring an error cluster to a boolean function in LabVIEW FPGA will crash LabVIEW when you compile.
    © 2003–2012 National Instruments Corporation. All rights reserved.
    I.     Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation.
    II.     Third-Party Copyright Notices
    \National Instruments\LabVIEW 2012\FPGA\Legal\
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    Xilinx® is a registered trademark of Xilinx, Inc.
    GMT+8, 2026-2-25 03:58
