查看: 3030|回复: 0
[LV工具模块] LabVIEW 2015 SP1 FPGA Module Win32Eng LabVIEW2015SP1FPGA模块LVFPGA2015SP1英文版
    13 小时前
  • 签到天数: 3605 天
    连续签到: 13 天
    发表于 2020-8-4 18:30:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,仅压缩格式不同。EXE为NI当年发行版,ZIP版为后期NI重新压制版。
    EXE版:
    ZIP版:
    EXE版:
    ZIP版:
    FPGA2015SP1.txt (537 Bytes, 下载次数: 2, 售价: 10 元)
    LabVIEW 2015 SP1 FPGA Module Readme
    December 2015
    This file contains important information about the LabVIEW FPGA Module, including installation instructions, known issues, and a partial list of bugs fixed for LabVIEW 2015 SP1 FPGA Module.
    FPGA Module System Requirements
    FPGA Compile Farm Server System Requirements
    With the LabVIEW FPGA Module, you can create VIs that run on NI FPGA targets, such as Reconfigurable I/O (RIO) devices. The FPGA Module helps you design complex systems by providing a highly-integrated development environment, a large ecosystem of IP libraries, a high-fidelity simulator, and debugging features. The FPGA Module also includes FPGA IP Builder and the FPGA Compile Farm Server. You can use FPGA IP Builder to efficiently implement your LabVIEW algorithms for FPGA targets and to generate FPGA code that meets specific performance requirements. FPGA IP Builder supports only a subset of FPGA targets. Visit ni.com/info and enter the Info Code exvxfe for a list of supported targets. You can use the FGPA Compile Farm Server to offload compiles to dedicated computers.
    The development computer is a PC or NI PXI/PXI Express system on which you install LabVIEW and the FPGA Module. You can also install the Xilinx compilation tools on your development computer to compile LabVIEW FPGA VIs locally. However, if the FPGA design or target requires more than 2 GB of memory, NI recommends you install the Xilinx compilation tools on a separate computer. This computer is referred to as the remote compile worker.
    Development Computer
    • LabVIEW 2015 SP1 Full or Professional Development Systems (32-bit)
    • 11 GB of additional disk space
    • Memory1:
      • At least 4 GB of RAM for Virtex-6 and later2 FPGA targets
      • Windows 7 Service Pack 1 (32-bit)
      • Windows 7 Service Pack 1 (64-bit with 32-bit LabVIEW installed)
      • Windows Vista (32-bit)
      • Windows Vista (64-bit with 32-bit LabVIEW installed)
      • Windows XP Service Pack 3
      • Windows Server 2008 R2 (64-bit with 32-bit LabVIEW installed)
      • The LabVIEW 2015 SP1 FPGA Module does not support the Windows Server non-R2 editions, Windows Server 2012 R2, Windows 8.1, and Windows 10.
      • NI recommends a 64-bit OS for the computer on which you install the Xilinx compilation tools.
    • FPGA device
    • Device driver software—To program most devices with the LabVIEW 2015 SP1 FPGA Module, install the device driver software. Refer to the hardware documentation for requirements for a specific device.
    1Memory requirements vary according to both the FPGA target and the FPGA VI you create for that target.
    2You must use a 64-bit OS to address 4 GB of RAM.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015 SP1.
    If you install the FPGA Compile Farm Server on a separate computer, you can configure that computer to be a remote compile server. If you install the Xilinx compilation tools on a separate computer, you can configure that computer to be a remote compile worker.
    Refer to the Remote Compile Server and Compile Worker section of the LabVIEW FPGA Module Release and Upgrade Notes for information about setting up and using a local or remote compile server or compile worker. Visit ni.com/info and enter the Info Code XilinxCompileTools for more information about the NI hardware supported by each Xilinx compilation tool.
    The remote compile server must meet the following minimum system requirements:
    • 35 MB of disk space
    • 1 GB RAM
      • Windows 7 Service Pack 1/Vista (32-bit and 64-bit)
    • Web browser for accessing compile job queues via the NI Web-based Configuration & Monitoring Service FPGA Compile Farm Console
    You can use either a Windows or Linux computer as a compile worker. Refer to the Xilinx Compilation Tools Readme for the operating system to obtain information about the minimum system requirements.
    You can install all of your LabVIEW products—including the FPGA Module, FPGA Compile Farm Server, and FPGA IP Builder—using the LabVIEW 2015 SP1 Platform media. You can find installation instructions for the FPGA Module along with activation instructions in the following locations:
    • LabVIEW FPGA Module Release and Upgrade Notes, which is available online at ni.com/manuals as well as on the LabVIEW Platform media.
    • LabVIEW Installation Guide, which is available in your FPGA Module software kit.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the FPGA Module.
    The following items are the IDs and titles of a subset of issues fixed in the FPGA Module. This is not an exhaustive list of issues fixed in the current version of the FPGA Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    557199Compilation failed being unable to parse a pulse width report.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the FPGA Module.
    NI LabVIEW FPGA Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI LabVIEW FPGA Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW FPGA Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    LabWindows™/CVI™cvi_lifecycle
    © 2003–2015 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \National Instruments\LabVIEW \FPGA\Legal\
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    374737D-01
    GMT+8, 2025-7-26 23:35
