查看: 3256|回复: 0
[LV工具模块] LabVIEW 2012 DataFinder Win32Eng LV2012数据查找工具包DFTK2012下载
    前天 16:03
    发表于 2020-8-5 16:39:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW DataFinder工具包可帮助您使用LabVIEW中的DataFinder搜索引擎。
    LabVIEW DataFinder工具包是LabVIEW的一个软件附件,可连接至DataFinder来管理和搜索数据文件,而不论其格式或位置如何。该附件包含My DataFinder桌面应用程序,可创建描述性信息的索引,并与测试文件一起存储。借助该附件,您可创建应用程序来用于访问索引信息,通过简单关键词或高级条件查询的方式在测试数据中查找动态和相关关系。此外,LabVIEW DataFinder工具包可以连接到DataFinder Server,以实现大型集中式数据管理应用程序。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    下载地址1:
    下载地址2:
    DFTK2012.txt (417 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2012 DataFinder Toolkit Readme
    July 2012
    This file contains information to introduce you to the LabVIEW 2012 DataFinder Toolkit. This file also provides you with help resources you can use while working with the LabVIEW 2012 DataFinder Toolkit. The file contains the following information:
    • Overview
    • System Requirements
    • Installing Instructions
    • Redistributing and Activating Executable Applications
    • Accessing the Help
    • Finding Examples
    • Important Information
    The LabVIEW 2012 DataFinder Toolkit enables you to connect to NI DataFinder in order to manage and search your data files regardless of format or location. The Desktop DataFinder ("My DataFinder"), installed with this toolkit, creates an index of the descriptive information stored with your test files. With the LabVIEW 2012 DataFinder Toolkit you can build applications to access the indexed information using either a simple keyword search as well as an advanced query to find trends and correlations in your test data. The LabVIEW 2012 DataFinder Toolkit can also connect to NI DataFinder Server Edition, the DataFinder server for larger, centralized data management applications.
    To create applications or shared libraries using the LabVIEW 2012 DataFinder Toolkit, you must be a properly licensed user and have the following software installed on the host computer:
    • National Instruments LabVIEW 2012
    • National Instruments LabVIEW 2012 DataFinder Toolkit
    To deploy and use applications or shared libraries using the LabVIEW 2012 DataFinder Toolkit, you must be a properly licensed user and have the following software installed on the host computer:
    • National Instruments LabVIEW 2012 DataFinder Toolkit Run-Time
    The LabVIEW 2012 DataFinder Toolkit can connect to and work with the following versions of DataFinder Server Edition:
    • National Instruments DataFinder Server Edition 2.0 (or higher)
    The LabVIEW 2012 DataFinder Toolkit can change the configuration settings of the following versions of DataFinder when installed on the same computer:
    • National Instruments DataFinder Server Edition 2.1 (or higher)
    • National Instruments Desktop DataFinder 2010 (or higher)
    The LabVIEW 2012 DataFinder Toolkit supports the following platforms:
    • Windows XP Pro Service Pack 3 or later, excluding Windows XP x64
    • Windows Vista 32 bit
    • Windows Vista 64 bit (as 32 bit application)
    • Windows 7 32 bit
    • Windows 7 64 bit (as 32 bit application)
    (LabVIEW 64-bit) The LabVIEW 2012 DataFinder Toolkit is not supported in LabVIEW (64 bit).
    You can install all of your LabVIEW products—including LabVIEW 2012 DataFinder Toolkit—by using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    You can evaluate the products for free for 30 days. After the evaluation period for the LabVIEW 2012 DataFinder Toolkit expires, you are no longer able to perform the following actions:
    • Run VIs from the LabVIEW 2012 DataFinder Toolkit.
    • Run VIs that use VIs from the LabVIEW 2012 DataFinder Toolkit.
    • Build VIs that use VIs from the LabVIEW 2012 DataFinder Toolkit into an executable or shared library.
    • Access palettes installed by the LabVIEW 2012 DataFinder Toolkit .
    To activate the LabVIEW 2012 DataFinder Toolkit license, use the serial number you received on the Certificate of Ownership. You can activate the LabVIEW 2012 DataFinder Toolkit license in any of the following ways:
    • After you launch LabVIEW in evaluation mode, click the Activate Products button in the LabVIEW dialog box.
    • Select Help»Activate LabVIEW Components while LabVIEW is running in evaluation mode or select Start»All Programs»National Instruments»NI License Manager to launch the NI License Manager. The license activation does not take effect until you restart LabVIEW.
    Use Application Builder to create installers to distribute stand-alone applications and shared libraries built with the LabVIEW 2012 DataFinder Toolkit. Include the LabVIEW 2012 DataFinder Toolkit Run-Time installer. Activate the LabVIEW 2012 DataFinder Toolkit Run-Time on the host computer using the NI License Manager.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the LabVIEW 2012 DataFinder Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the DataFinder Toolkit are located in the labview\examples\DataFinder directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Notes on DataFinder ToolkitFirewall
      The firewall displays a warning while the LabVIEW 2012 DataFinder Toolkit installs because the DataFinder, which you use for searching and navigating in files, then starts.
      If you want to be able to use all the functions offered by the LabVIEW 2012 DataFinder Toolkit, National Instruments recommends that you select "Do not block" for all programs listed. This also applies when you want to evaluate the LabVIEW 2012 DataFinder Toolkit. Refer to ni.com/info under the info code expm69.
    Installation
      The LabVIEW 2012 DataFinder Toolkit and DIAdem Version 10.0, and later versions, install and use a shared software component (Desktop DataFinder - My DataFinder) that is updated when you install the LabVIEW 2012 DataFinder Toolkit. When you uninstall the LabVIEW 2012 DataFinder Toolkit, the current version of the shared component remains. This is intentional and has been tested extensively.
      The LabVIEW 2012 DataFinder Toolkit, DIAdem Version 9.0, LabWindows/CVI Version 8.1, DataFinder Server Edition 1.0 and LabVIEW Version 7.1, and later versions, use a shared software component (USI) that is updated when you install the LabVIEW 2012 DataFinder Toolkit. When you uninstall the LabVIEW 2012 DataFinder Toolkit, the current version of the shared component remains. This is intentional and has been tested extensively.
    DataPlugins
      Use a DataPlugin built with the LabVIEW DataPlugin SDK only with the same LabVIEW version with which you created this DataPlugin.
    © 2012 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-25 02:40
