查看: 3469|回复: 0
[LV工具模块] LabVIEW 2015 DataFinder Win32Eng LV2015数据查找工具包DFTK2015下载
    前天 16:03
    发表于 2020-8-5 19:37:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW DataFinder工具包可帮助您使用LabVIEW中的DataFinder搜索引擎。
    LabVIEW DataFinder工具包是LabVIEW的一个软件附件,可连接至DataFinder来管理和搜索数据文件,而不论其格式或位置如何。该附件包含My DataFinder桌面应用程序,可创建描述性信息的索引,并与测试文件一起存储。借助该附件,您可创建应用程序来用于访问索引信息,通过简单关键词或高级条件查询的方式在测试数据中查找动态和相关关系。此外,LabVIEW DataFinder工具包可以连接到DataFinder Server,以实现大型集中式数据管理应用程序。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    DFTK2015.txt (261 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2015 DataFinder Toolkit Readme
    2015
    Version 15.0.0
    June 2015
    This file contains important information about LabVIEW 2015 DataFinder Toolkit, including installation instructions, new features, and known issues.
    Installing Instructions
    Redistributing and Activating Executable Applications
    LabVIEW 2015 DataFinder Toolkit enables you to connect to NI DataFinder in order to manage and search your data files regardless of format or location. The Desktop DataFinder ("My DataFinder"), installed with this toolkit, creates an index of the descriptive information stored with your test files. With LabVIEW 2015 DataFinder Toolkit you can build applications to access the indexed information using either a simple keyword search as well as an advanced query to find trends and correlations in your test data. LabVIEW 2015 DataFinder Toolkit can also connect to NI DataFinder Server Edition, the DataFinder server for larger, centralized data management applications.
    To create applications or shared libraries using LabVIEW 2015 DataFinder Toolkit, you must be a properly licensed user and have the following software installed on the host computer:
    • National Instruments LabVIEW 2015
    • National Instruments LabVIEW 2015 DataFinder Toolkit
    To deploy and use applications or shared libraries using LabVIEW 2015 DataFinder Toolkit, you must be a properly licensed user and have the following software installed on the host computer:
    • National Instruments LabVIEW 2015 DataFinder Toolkit Run-Time
    LabVIEW 2015 DataFinder Toolkit can connect to and work with the following versions of DataFinder Server Edition:
    • National Instruments DataFinder Server Edition 2.0 or higher
    • National Instruments DataFinder Server Edition 2014 or higher for connecting to DataFinder Federation Server
    LabVIEW 2015 DataFinder Toolkit can change the configuration settings of the following versions of DataFinder when installed on the same computer:
    • National Instruments DataFinder Server Edition 2.1 or higher
    • National Instruments Desktop DataFinder 2010 or higher
    LabVIEW 2015 DataFinder Toolkit supports the following platforms:
    • Windows XP Pro Service Pack 3 or later, excluding Windows XP x64
    • Windows Vista 32 bit
    • Windows Vista 64 bit (as 32 bit application)
    • Windows 7 32 bit
    • Windows 7 64 bit (as 32 bit application)
    (LabVIEW 64-bit) LabVIEW 2015 DataFinder Toolkit is not supported in LabVIEW (64 bit).
    Use Application Builder to create installers to distribute stand-alone applications and shared libraries built with LabVIEW 2015 DataFinder Toolkit. Include LabVIEW 2015 DataFinder Toolkit Run-Time installer. Activate LabVIEW 2015 DataFinder Toolkit Run-Time on the host computer using the NI License Manager.
    Known IssuesFirewall
      The firewall displays a warning while LabVIEW 2015 DataFinder Toolkit installs because the DataFinder, which you use for searching and navigating in files, then starts.
      If you want to be able to use all the functions offered by LabVIEW 2015 DataFinder Toolkit, National Instruments recommends that you select "Do not block" for all programs listed. This also applies when you want to evaluate LabVIEW 2015 DataFinder Toolkit. Refer to ni.com/info under the info code expm69.
    Installation
      LabVIEW 2015 DataFinder Toolkit and DIAdem Version 10.0, and later versions, install and use a shared software component (Desktop DataFinder - My DataFinder) that is updated when you install LabVIEW 2015 DataFinder Toolkit. When you uninstall LabVIEW 2015 DataFinder Toolkit, the current version of the shared component remains. This is intentional and has been tested extensively.
      LabVIEW 2015 DataFinder Toolkit, DIAdem Version 9.0, LabWindows/CVI Version 8.1, DataFinder Server Edition 1.0 and LabVIEW Version 7.1, and later versions, use a shared software component (USI) that is updated when you install LabVIEW 2015 DataFinder Toolkit. When you uninstall LabVIEW 2015 DataFinder Toolkit, the current version of the shared component remains. This is intentional and has been tested extensively.
    DataPlugins
      Use a DataPlugin built with LabVIEW DataPlugin SDK only with the same LabVIEW version with which you created this DataPlugin.
    You can install all of your LabVIEW products—including LabVIEW 2015 DataFinder Toolkit—using the LabVIEW 2015 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    New Features of LabVIEW 2015 DataFinder Toolkit
    LabVIEW 2015 DataFinder Toolkit will provide the following new features:
    • Connection to DataFinder Federation Server. DataFinder Server Edition 2014 or higher required.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2015 DataFinder Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the DataFinder Toolkit are located in the labview\examples\DataFinder directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Note  Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI DataFinder Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments DataFinder Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of DataFinder Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI LabWindows/CVIcvi_lifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2009–2015 National Instruments. All rights reserved.
    GMT+8, 2026-2-25 00:57
