查看: 3316|回复: 0
[NI软件产品] NI FlexLogger 2017 Win64Eng 美国国家仪器FlexLogger应用软件2017版
    9 小时前
    发表于 2020-8-5 22:53:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    FlexLogger 2017共有4个不同的版本。具体内容上的差别,我方未经验证。也许只是格式上的差别。从官方更新时间来看,FlexLoggerEAR的两个版本,是2017年10月3号更新的,内部文件则是2017年9月26号修改的,从字面上EAR(early早期)可以理解为早期产品。而FLEXLGR2017和FLEXLGRQ32017则是2017年11月10号更新的,内部文件修改时间也是2017年11月10号。所以后面两个版本要略新一些。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    FlexLoggerEAR.iso
    FlexLoggerEAR.zip
    FLEXLGR2017.iso
    FLEXLGRQ32017.zip
    FlexLoggerEAR.iso
    FlexLoggerEAR.zip
    FLEXLGR2017.iso
    FLEXLGRQ32017.zip
    FL2017.txt (850 Bytes, 下载次数: 0, 售价: 10 圆)
    FlexLogger Early Access Release Readme
    May 2017
    This file contains important information about FlexLogger Early Access Release (EAR), including system requirements, installation instructions, and supported hardware.
    Use FlexLogger EAR to configure a CompactDAQ measurement system to acquire, visualize, and log sensor-based data.
    FlexLogger EAR has the following minimum system requirements:
    • Pentium 4 G1 equivalent (Intel i5 equivalent or higher recommended)
    • 64-bit version of Windows 10/8.11/7 SP12
    • 4 GB disk space
    • 4 GB RAM
    • .NET Framework 4.6.2
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Complete the following steps to install FlexLogger EAR.
    • Log into Windows using an Administrator account. Contact your IT department if you do not have Administrator access.
    • Insert the FlexLogger EAR installation media. Follow the installer prompts, enter any required information, and activate when prompted, if necessary. When prompted to reboot, log into the same Windows account you used to run the installer.
    The following lists detail the hardware models supported in FlexLogger EAR.
    CompactDAQ Chassis
    • NI cDAQ-9171
    • NI cDAQ-9174
    • NI cDAQ-9178
    • NI cDAQ-9179
    • NI cDAQ-9181
    • NI cDAQ-9184
    • NI cDAQ-9188
    • NI cDAQ-9191
    C Series Voltage Input Modules
    • NI-9201
    • NI-9205
    • NI-9206
    • NI-9209
    • NI-9215
    • NI-9220
    • NI-9221
    • NI-9222
    • NI-9223
    • NI-9225
    • NI-9229
    • NI-9238
    • NI-9239
    C Series Current Input Modules
    • NI-9203
    • NI-9208
    • NI-9227
    C Series Temperature Input Modules
    • NI-9211
    • NI-9213
    C Series Universal Analog Input Modules
    • NI-9218
    • NI-9219
    C Series Strain/Bridge Input Modules
    • NI-9235
    • NI-9236
    • NI-9237
    C Series CAN and Vehicle Multiprotocol Interface Modules
    • NI-9860
      Note: FlexLogger EAR only supports the TRC-8542 and TRC-8543 transceiver cables.
    • NI-9861
    • NI-9862
    CAN Interface Devices
    • NI USB-8502
    Refer to the FlexLogger EAR Getting Started Guide, shipped with your software and also accessible from \documentation\FlexLogger_GSG.pdf, for information about FlexLogger EAR.
    © 2017 National Instruments. All rights reserved.
    377046A-01
    GMT+8, 2025-12-8 18:22
