查看: 3292|回复: 0
[NI软件产品] NI FlexLogger 2018R1EAR Win64Eng 美国国家仪器FlexLogger应用软件2018R1EAR版
    9 小时前
    发表于 2020-8-5 23:05:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    FlexLogger 2018R1EAR共有2个不同的版本。具体内容上的差别,我方未经验证。也许只是格式上的差别。从官方更新时间来看,两个版本均是2018年3月28号开放下载的,内部的修改时间ISO的是2017年12月16号,ZIP的是2017年12月19号,晚三天。感觉上内容没有太多差别,ZIP文档应该是ISO镜像压制成的。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    FLEXLGR2018R1EAR.iso
    FLEXLGR2018R1EAR.zip
    FL2018R1EAR.txt (500 Bytes, 下载次数: 0, 售价: 10 圆)
    FlexLogger Readme
    January 2018
    This file contains important information about FlexLogger, including system requirements, installation instructions, and supported hardware.
    Localization Considerations
    Use FlexLogger to configure a CompactDAQ measurement system to acquire, visualize, and log sensor-based data.
    FlexLogger has the following minimum system requirements:
    • Pentium 4 G1 equivalent (Intel i5 equivalent or higher recommended)
    • 64-bit version of Windows 10/8.11/7 SP12
    • 4 GB disk space
    • 4 GB RAM
    • .NET Framework 4.6.2
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Complete the following steps to install FlexLogger.
    • Log into Windows using an Administrator account. Contact your IT department if you do not have Administrator access.
    • Insert the FlexLogger installation media. Follow the installer prompts, enter any required information, and activate when prompted, if necessary. When prompted to reboot, log into the same Windows account you used to run the installer.
    The FlexLogger default user interface language is English, but additional language support is included for Chinese (Simplified), French, German, Japanese, and Korean.
    To change the language support, select File» Preferences and choose your language from the Language pull-down menu on the Editor tab.
    NOTE: Localization for FlexLogger is in beta. Full localization support for all features may not be available.
    The following lists detail the hardware models supported in FlexLogger.
    CompactDAQ Chassis
    • cDAQ-9171
    • cDAQ-9174
    • cDAQ-9178
    • cDAQ-9179
    • cDAQ-9181
    • cDAQ-9184
    • cDAQ-9185
    • cDAQ-9188
    • cDAQ-9189
      Note: FlexLogger does not support synchronization between TSN-enabled CompactDAQ chassis (cDAQ-9185 and cDAQ-9189)
    • cDAQ-9191
    C Series Voltage Input Modules
    • NI 9201
    • NI 9205
    • NI 9206
    • NI 9209
    • NI 9215
    • NI 9220
    • NI 9221
    • NI 9222
    • NI 9223
    • NI 9224
    • NI 9225
    • NI 9228
    • NI 9229
    • NI 9238
    • NI 9239
    • NI 9242
    • NI 9244
    • NI 9251
    C Series Current Input Modules
    • NI 9203
    • NI 9208
    • NI 9227
    • NI 9246
    • NI 9247
    C Series Voltage and Current Input Modules
    • NI 9207
    C Series Sound and Vibration Input Modules
    • NI 9230
    • NI 9232
    • NI 9234
    • NI 9250
    C Series Temperature Input Modules
    • NI 9210
    • NI 9211
    • NI 9212
    • NI 9213
    • NI 9214
    • NI 9216
    • NI 9217
    • NI 9226
    C Series Universal Analog Input Modules
    • NI 9218
      Note: FlexLogger only supports the NI 9218 with NI 9882D/NI 9882L and NI 9882F screw terminals.
    • NI 9219
    C Series Strain/Bridge Input Modules
    • NI 9235
    • NI 9236
    • NI 9237
    C Series CAN and Vehicle Multiprotocol Interface Modules
    • NI 9860
      Note: FlexLogger only supports the TRC-8542 and TRC-8543 transceiver cables.
    • NI 9861
    • NI 9862
    CAN Interface Devices
    • NI USB-8502
    Refer to the FlexLogger Manual, accessible from Help»Online manual, for more information about using FlexLogger.
    © 2017–2018 National Instruments. All rights reserved.
    377046A-01
    GMT+8, 2025-12-8 18:22
