查看: 3522|回复: 0
[NI软件产品] NI FlexLogger 2019R2.1(1.7.1) Win64Eng 美国国家仪器FlexLogger应用软件2019R2.1版即ni-flexlogger_1.7.1
    9 小时前
    发表于 2020-8-6 00:09:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    (因为单个文件大于4GB,超出百度网盘文件上限,分割成两个压缩文档分包)
    (MD5) e4b2e11aa3d5a1781748818241833126
    (SHA256) fc1545e5af00676180b9684a5dedbe71b57ad01b7e0cb127ffad64ac074979ac
    FL2019R2.1.txt (350 Bytes, 下载次数: 0, 售价: 10 圆)
    FlexLogger 2019 R2 Readme
    April 2019
    This file contains important information about FlexLogger, including system requirements, installation instructions, and supported hardware.
    FlexLogger is application software for quick sensor configuration and data logging of mixed signals to verify electromechanical systems, all without programming.
    Back to Top
    FlexLogger has the following minimum system requirements:
    Operating System
    RAM/Processor
    Required Software1
    • 64-bit version of Windows 10/8.12/7 SP13
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    • Pentium 4 G1 equivalent (Intel i5 equivalent or higher recommended)
    • 4 GB disk space
    • 4 GB RAM
    • NI-DAQmx software 18.5 or higher
    • NI-XNET software 18.5 or higher
    1 Required drivers are included with the FlexLogger installer.
    2 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    3 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Back to Top
    NI automates FlexLogger installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Back to Top
    Back to Top
    New Features2019 R2 (April 2019)
    • Added hardware support for:
      • FD-11634
      • NI 9866
      • USB-8506
    • Output support for CAN
    • Input support for LIN
    • Capability to add timestamped notes during test
    • Lowpass and highpass Butterworth filter channels added to Channel Specification
    • TSN synchronization feedback
    • No limits on Slow/Medium/Fast/Digital sample rate configuration
    • System memory monitoring and dynamic visualization settings
    • Pull-up resistor support and threshold voltage support for the NI 9361
    • Powered sensor support for the FD-11601
    2019 R1 (December 2018)
      • NI 9231
      • FD-11601
      • FD-11614
      • TRC-8546 transceiver cable for the NI 9860
    • Enhanced system visualization in Channel Specification
    • Conditional events to automate outputs
    • RMS and Mean averaging of channels added to Channel Specification
    • Capture test metadata
    • Improved graph visualization
    • Analog input channel data filtering
    • Ability to reassign I/O or automotive channel configurations
    • Automatically log channel characteristics
    • Screen visualization shows minimum and maximum data values in visible range
    2018 R4 (September 2018)
    • Static-level output, including added hardware support for:
      • C Series Voltage Output Modules
      • C Series Current Output Modules
      • C Series Digital Modules
      • C Series User Interface Module
    • Add arbitrary metadata to a project
    • Import and export data using NI SystemLink
    • Support for control of output channel set points through NI SystemLink
    Back to Top
    The following lists detail the hardware models supported in FlexLogger.
    CompactDAQCompactDAQ Chassis
    • cDAQ-9171
    • cDAQ-9174
    • cDAQ-9178
    • cDAQ-9179
    • cDAQ-9181
    • cDAQ-9184
    • cDAQ-9185
    • cDAQ-9188
    • cDAQ-9188XT
    • cDAQ-9189
    • cDAQ-9191
      Note: FlexLogger supports synchronization between TSN-enabled CompactDAQ chassis (cDAQ-9185 and cDAQ-9189) provided they are a part of your local 802.1AS subnet. Refer to your chassis documentation, available on ni.com/manuals, for more information.
    C Series Voltage Input Modules
    • NI 9201
    • NI 9202
    • NI 9205
    • NI 9206
    • NI 9209
    • NI 9215
    • NI 9220
    • NI 9221
    • NI 9222
    • NI 9223
    • NI 9224
    • NI 9225
    • NI 9228
    • NI 9229
    • NI 9238
    • NI 9239
    • NI 9242
    • NI 9244
    • NI 9251
    • NI 9263
    • NI 9264
    • NI 9269
    C Series Current Input Modules
    • NI 9203
    • NI 9208
    • NI 9227
    • NI 9246
    • NI 9247
    • NI 9265
    • NI 9266
    C Series Voltage and Current Input Modules
    • NI 9207
    C Series Sound and Vibration Input Modules
    • NI 9230
    • NI 9231
    • NI 9232
    • NI 9234
    • NI 9250
    C Series Temperature Input Modules
    • NI 9210
    • NI 9211
    • NI 9212
    • NI 9213
    • NI 9214
    • NI 9216
    • NI 9217
    • NI 9226
    C Series Universal Analog Input Modules
    • NI 9218
    • NI 9219
    C Series Strain/Bridge Input Modules
    • NI 9235
    • NI 9236
    • NI 9237
    C Series Counter Input Modules
    • NI 9361
    • Serial Digital I/O Modules
      • NI 9375
        Note: The NI 9375 must have all lines set to input or to output in a project.
      • NI 9403
      • NI 9425
      • NI 9426
      • NI 9476
      • NI 9477
      • NI 9478
    • Parallel Digital I/O Modules
      • NI 9344
      • NI 9401
      • NI 9402
      • NI 9411
      • NI 9421
      • NI 9422
      • NI 9423
      • NI 9435
      • NI 9436
      • NI 9437
      • NI 9472
      • NI 9474
      • NI 9475
      • NI 9481
      • NI 9482
      • NI 9485
    Note: You cannot use parallel and serial modules together on the same FlexLogger project unless they are installed in separate cDAQ chassis.
    C Series CAN Interface Modules
    • NI 9861
    • NI 9862
    C Series Vehicle Multiprotocol Interface Modules
    • NI 9860
    CAN Interface Devices
    • NI USB-8502
    C Series LIN Interface Modules
    • NI 9866
    LIN Interface Devices
    • NI USB-8506
    FieldDAQVoltage Input Device for FieldDAQ
    • FD-11601
    • FD-11603
    Sound and Vibration Input Device for FieldDAQ
    • FD-11634
    Strain/Bridge Input Device for FieldDAQ
    • FD-11637
    Temperature Input Device for FieldDAQ
    • FD-11613
    • FD-11614
    Note: FlexLogger supports synchronization between TSN-enabled FieldDAQ devices provided they are a part of your local 802.1AS subnet. Refer to your device documentation, available on ni.com/manuals, for more information.
    Back to Top
    Refer to the FlexLogger Manual, accessible from Help»Online manual, for more information about using FlexLogger.
    Back to Top
    Back to Top
    Back to Top
    © 2017–2019 National Instruments. All rights reserved.
    377046E-01
    GMT+8, 2025-12-8 18:21
