查看: 3545|回复: 0
[NI软件产品] NI FlexLogger 2019R4(1.9.0) Win64Eng 美国国家仪器FlexLogger应用软件2019R4版即ni-flexlogger_1.9.0
    9 小时前
    发表于 2020-8-6 00:21:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    链接: 请注册登录视觉论坛会员,购买附件查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    (因为单个文件大于4GB,超出百度网盘文件上限,分割成两个压缩文档分包)
    请注册登录视觉论坛会员,购买附件查看校验和:
    SHA256:A8D4CC25469434008398C604B1FF403E6BA4DE87D12D003520ABD933092619D7
    FL2019R4.txt (350 Bytes, 下载次数: 0, 售价: 10 圆)
    FlexLogger 2019 R4 Readme
    September 2019
    This file contains important information about FlexLogger, including system requirements, installation instructions, and supported hardware.
    Extending FlexLogger I/O with the FlexLogger Plugin Development Kit
    Changes to Log File Metadata in FlexLogger 2019 R4
    FlexLogger Drops Support for Windows 7 64-bit in 2021
    FlexLogger is application software for quick sensor configuration and data logging of mixed signals to verify electromechanical systems, all without programming.
    Back to Top
    FlexLogger has the following minimum system requirements:
    Operating System
    RAM/Processor
    Required Software1
    • 64-bit version of Windows 10/8.12/7 SP13
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    • Pentium 4 G1 equivalent (Intel i5 equivalent or higher recommended)
    • 12 GB disk space
    • 4 GB RAM
    • NI-DAQmx software 19.1 or higher
    • NI-XNET software 19.1 or higher
    1 Required drivers are included with the FlexLogger installer.
    2 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    3 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Back to Top
    NI automates FlexLogger installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Back to Top
    Back to Top
    New Features2019 R4 (September 2019)
    • Added hardware support for:
      • NI 9252
      • NI 9253
    • Apply zero and null offset calibration to multiple channels simultaneously
    • Export alarm history to CSV file format
    • Save project as support for existing projects
    • Event triggered on test time elapsed
    • Toast notification support for channel alarms
    • Integrated system health metric reporting
    • Digital input support in arithmetic and boolean formulas
    • Calculation formula support for logarithm functions, ? : operator, and e, true, and false constants
    • Configurable sample rate for CAN/LIN
    • Support for custom analysis plugins created with the FlexLogger Plugin Development Kit 1.1
    2019 R3 (July 2019)
    • Added hardware support for the FD-11605
    • Alarms for input channels, including the following features:
      • Alarm history pane
      • Event triggering from alarms
    • Reset values on output channels
    • Additional measurement types for counter input modules:
      • Angular position
      • Linear position
      • Pulse
    • Hardware filter support for FieldDAQ
    • Support for custom I/O plugins created with the FlexLogger Plugin Development Kit 1.0
    • Boolean logic for analog channels
    • Digital input event triggering
    • Output support for LIN
    • LIN master support
    • Offline FlexLogger manual access
    2019 R2 (April 2019)
      • FD-11634
      • NI 9866
      • USB-8506
    • Output support for CAN
    • Input support for LIN
    • Capability to add timestamped notes during test
    • Lowpass and highpass Butterworth filter channels added to Channel Specification
    • TSN synchronization feedback
    • No limits on Slow/Medium/Fast/Digital sample rate configuration
    • System memory monitoring and dynamic visualization settings
    • Pull-up resistor support and threshold voltage support for the NI 9361
    • Powered sensor support for the FD-11601
    Back to Top
    The following lists detail the hardware models supported in FlexLogger.
    CompactDAQCompactDAQ Chassis
    • cDAQ-9171
    • cDAQ-9174
    • cDAQ-9178
    • cDAQ-9179
    • cDAQ-9181
    • cDAQ-9184
    • cDAQ-9185
    • cDAQ-9188
    • cDAQ-9188XT
    • cDAQ-9189
    • cDAQ-9191
      Note: FlexLogger supports network synchronization using IEEE 802.1AS protocol. Refer to your chassis documentation, available on ni.com/manuals, for more information.
    C Series Voltage Input Modules
    • NI 9201
    • NI 9202
    • NI 9205
    • NI 9206
    • NI 9209
    • NI 9215
    • NI 9220
    • NI 9221
    • NI 9222
    • NI 9223
    • NI 9224
    • NI 9225
    • NI 9228
    • NI 9229
    • NI 9238
    • NI 9239
    • NI 9242
    • NI 9244
    • NI 9251
    • NI 9252
      Note: The NI 9252 module supports hardware filtering. Refer to the Reducing Signal Noise topic in the FlexLogger Manual for more information.
    C Series Voltage Output Modules
    • NI 9263
    • NI 9264
    • NI 9269
    C Series Current Input Modules
    • NI 9203
    • NI 9208
    • NI 9227
    • NI 9246
    • NI 9247
    • NI 9253
      Note: The NI 9253 module supports hardware filtering. Refer to the Reducing Signal Noise topic in the FlexLogger Manual for more information.
    C Series Current Output Modules
    • NI 9265
    • NI 9266
    C Series Voltage and Current Input Modules
    • NI 9207
    C Series Sound and Vibration Input Modules
    • NI 9230
    • NI 9231
    • NI 9232
    • NI 9234
    • NI 9250
    C Series Temperature Input Modules
    • NI 9210
    • NI 9211
    • NI 9212
    • NI 9213
    • NI 9214
    • NI 9216
    • NI 9217
    • NI 9226
    C Series Universal Analog Input Modules
    • NI 9218
    • NI 9219
    C Series Strain/Bridge Input Modules
    • NI 9235
    • NI 9236
    • NI 9237
    C Series Counter Input Modules
    • NI 9361
    C Series Digital Modules
    • Serial Digital I/O Modules
      • NI 9375
        Note: The NI 9375 can only use one port (input or output) at a time in a project.
      • NI 9403
      • NI 9425
      • NI 9426
      • NI 9476
      • NI 9477
      • NI 9478
    • Parallel Digital I/O Modules
      • NI 9344
      • NI 9401
      • NI 9402
      • NI 9411
      • NI 9421
      • NI 9422
      • NI 9423
      • NI 9435
      • NI 9436
      • NI 9437
      • NI 9472
      • NI 9474
      • NI 9475
      • NI 9481
      • NI 9482
      • NI 9485
    Note: You cannot use parallel and serial modules together on the same FlexLogger project unless they are installed in separate cDAQ chassis.
    C Series CAN Interface Modules
    • NI 9861
    • NI 9862
    C Series Vehicle Multiprotocol Interface Modules
    • NI 9860
    CAN Interface Devices
    • NI USB-8502
    C Series LIN Interface Modules
    • NI 9866
    LIN Interface Devices
    • NI USB-8506
    FieldDAQVoltage Input Device for FieldDAQ
    • FD-11601
    • FD-11603
    • FD-11605
    Note  Revision B and later of the FD-11603 supports hardware filtering.
    Sound and Vibration Input Device for FieldDAQ
    • FD-11634
    Strain/Bridge Input Device for FieldDAQ
    • FD-11637
    Note  Revision B and later of the FD-11637 supports hardware filtering.
    Temperature Input Device for FieldDAQ
    • FD-11613
    • FD-11614
    Note: FlexLogger supports network synchronization using IEEE 802.1AS protocol. Refer to your device documentation, available on ni.com/manuals, for more information.
    Note: FieldDAQ supports hardware filtering. Refer to the FlexLogger Manual for more information.
    Back to Top
    Extending FlexLogger with the FlexLogger Plugin Development Kit
    You can extend the functionality of FlexLogger 2019 R4 by creating and importing a custom I/O plugin using the FlexLogger Plugin Development Kit (version 1.1). The FlexLogger Plugin Development Kit is available for download in NI Package Manager. Refer to the FlexLogger Plugin Development Kit 1.1 Readme for more information.
    Back to Top
    The online FlexLogger manual contains the most current help for your product version. Refer to the FlexLogger Manual, accessible from Help»FlexLogger manual, for more information about using FlexLogger.
    Users without online access can choose to use an offline version of the FlexLogger manual. To enable the use of the offline FlexLogger manual, go to File» Preferences»General and select Always use offline manual.
    Back to Top
    In FlexLogger 2019 R4, metadata properties organized as a hierarchy are defined by a tilde (~) character between properties. Previous FlexLogger versions used a double greater symbol (>>) to separate these metadata properties. Any data post-processing configured to use >> may produce unexpected results.
    Back to Top
    Back to Top
    Back to Top
    FlexLogger Drops Support for Windows 7 (64-Bit)
    FlexLogger will drop support for Windows 7 (64-bit) operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on this operating system. For detailed information about NI operating system support, visit ni.com/r/windows764bit.
    Back to Top
    © 2017–2019 National Instruments. All rights reserved.
    377046G-01
    GMT+8, 2025-12-8 18:21
