查看: 3157|回复: 0
[LV工具模块] LabVIEW 2011 Robotics Full Win32Eng LV2011机器人模块Robotics2011完整版下载
    昨天 09:14
  • 签到天数: 3825 天
    发表于 2020-8-6 23:36:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW机器人模块提供了用于设计机器人控制系统的硬件和软件开发工具。
    LabVIEW机器人模块是LabVIEW编程环境的一个附加软件。该模块包含了一个全面的机器人库,其中包括针对机器人传感器和执行器的内置连接、实现智能操作和鲁棒感知的基本算法,以及使机器人或车辆移动的运动功能。您可以将算法和控制代码部署到NI实时嵌入式硬件,LabVIEW机器人模块可帮助工程师和科学家设计和原型验证自动和半自动驾驶设备,包括农业和军事系统、机器人救援平台、水下和飞行器、个人和服务机器人、医疗机器人设备以及学术和科研机器人。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    链接: 请注册登录视觉论坛会员,购买附件查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    RBT2011.txt (377 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2011 Robotics Module Readme
    Version 11.0
    June 2011
    This file contains important information about the LabVIEW 2011 Robotics Module, including installation instructions, new features, and known issues.
    Purchasing Robotics Run-Time Licenses
    Accessing the Software and Help
    The LabVIEW Robotics Module is a software package that allows you to develop robotics applications using LabVIEW. The Robotics Module provides robotics-related algorithms, drivers that allow you to control certain sensors, hardware and software setup wizards, and example VIs that demonstrate robotics concepts.
    The Robotics Module has the following requirements:
    • LabVIEW 2011 Full or Professional Development System (32-bit)
    • At least 350 MB of disk space
      • Windows XP SP2 or later (32-bit)
    Note  Some Robotics Module features, such as the Robotics Project and Hardware Setup wizards and many examples, require additional National Instruments software, such as the LabVIEW Real-Time and FPGA Modules and the NI-RIO drivers. If you purchased the Robotics Starter Kit or Robotics Software Bundle, you have access to this software. If you purchased just the Robotics Module, select Start»All Programs»National Instruments»NI License Manager to launch the NI License Manager, which displays the software to which you have access.
    You can install all of your LabVIEW products—including the Robotics Module—using the LabVIEW Platform DVDs. You can find installation instructions for the module along with activation instructions in the following locations:
    • LabVIEW Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    Note  If you purchased this product with an NI Software Suite or NI Product Bundle, such as the LabVIEW Robotics Starter Kit or Software Bundle, use the installation media that shipped with your purchase to install this product.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments Web site.
    You must purchase a Robotics Module Run-Time License for each target machine not produced by National Instruments onto which you want to install a custom Robotics Module application. Refer to the National Instruments Web site for more information about Robotics run-time licensing. Contact a National Instruments sales representative or visit ni.com to purchase run-time licenses.
    Note  Other products you use to develop robotics applications also might require run-time licenses. Refer to the documentation for those products for information about purchasing run-time licenses.
    After you install the Robotics Module, select Start»All Programs»NI LabVIEW Robotics 2011 to launch the LabVIEW Robotics environment.
    Refer to the Robotics Module book on the Contents tab of the LabVIEW Help for more information about the Robotics Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Robotics Module are located in the Program Files (x86)\National Instruments\LabVIEW 2011\examples\robotics directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. Refer to the Robotics Module»Reusing Robotics Examples topic on the Contents tab of the LabVIEW Help for information about adapting LabVIEW project-based examples that include hardware targets to fit a different target you want to use.
    Some robotics examples require additional National Instruments software, such as the LabVIEW FPGA Module, Control Design and Simulation Module, or Vision Development Module. In the NI Example Finder, select an example and refer to the Information section for a list of software you must install to run the example.
    Note  (Windows 7/Vista) When you open an FPGA VI in some LabVIEW project-based examples, the VI appears to have unsaved changes because the default LabVIEW font on Windows 7 and Vista differs from the default font on Windows XP. LabVIEW prompts you to save these cosmetic changes to the VI, which requires you to recompile the FPGA VI. If the VI has no other changes, you can save and recompile the VI to avoid this unsaved state when you open the FPGA VI in the future.
    The LabVIEW 2011 Robotics Module introduces the following enhancements.
    Simulating Mobile Robots
    The LabVIEW Robotics Module provides a simulator and tools you can use to design and control a simulated environment with mobile robots. Use the Robotics Environment Simulator Wizard to design an environment and the robots you want to simulate. After you design the simulated components, write VIs to manipulate the components in the simulator. When you finish writing simulation VIs, run them to start the simulator and view the simulation. Finally, you can deploy the same VIs to a real hardware target after making a few changes to prepare the VIs for hardware.
    Refer to the Robotics Module»Simulating Mobile Robots book on the Contents tab of the LabVIEW Help for more information about simulating mobile robots in LabVIEW.
    Communicating with Simulated Sensors and Actuators
    Use the drivers on the Device I/O with Simulation palette to communicate with robotics sensors and actuators. These drivers are useful in robotics applications because you can use the same driver to communicate with both real and simulated sensors and actuators. Thus, you can create and simulate a robotics application that includes sensor and actuator drivers and then deploy the application to a real hardware target with minimal changes to your code.
    To access these drivers, browse to the Robotics»Sensors and Actuators»Device I/O with Simulation palette. If you need to communicate only with real devices, you can use the drivers on another palette, the Device I/O palette.
    Refer to the Robotics Module»Communicating with Sensors and Actuators book on the Contents tab of the LabVIEW Help for more information about using the Device I/O with Simulation drivers.
    Controlling the Starter Kit Robot without Writing an FPGA VI
    The Starter Kit palette contains VIs you can use to control real and simulated versions of the LabVIEW Robotics Starter Kit robot. To access the Starter Kit VIs, browse to the Robotics»Starter Kit palette. Use the VIs on the subpalette that corresponds to your robot to interface with your robot similarly to how you use device drivers to interface with a sensor or actuator. For example, the Starter Kit palette contains VIs to initialize the robot, read from and write to the distance sensor and motor controllers on the robot, and then close the communication session.
    Note  You must install all software on the LabVIEW Robotics Starter Kit DVD before you can use the Starter Kit VIs with a real Starter Kit robot.
    The Starter Kit VIs allow you to interact with the FPGA on the robot without writing an FPGA VI. These VIs also can operate with real or simulated versions of the Starter Kit robot just by using the appropriate initialization VI.
    Refer to the Robotics Module»LabVIEW Robotics Starter Kit book on the Contents tab of the LabVIEW Help for more information about working with the Robotics Starter Kit. Use the NI Example Finder, available by selecting Help»Find Examples from LabVIEW, to browse or search for examples of using the Starter Kit VIs to control real and simulated Starter Kit robots. You also can access the example VIs from the labview\examples\robotics directory.
    Robotics Environment Settings
    The Robotics Module defines its own LabVIEW environment settings that allow you to focus LabVIEW on robotics-related development. For example, the Robotics environment settings include access to wizards, customized palette views, and other resources. To change from one environment to another without restarting LabVIEW, select Tools»Choose Environment to display the Choose Environment Settings dialog box, which you can use to change environments.
    New VIs and Nodes
    The Robotics palette includes the following new VIs and nodes:
    • The new Simulator palette includes the following new VIs you can use with the robotics simulator:
      • Continue Simulator Service
      • Get Simulator Reference
      • Pause Simulator Service
      • Start Simulator Service
      • Stop Simulator Service
    • The Offline Configuration subpalette of the Simulator palette includes the following new VIs and nodes:
      • Load Simulation Instance
      • New Simulation Object
      • Property Node (Simulator Engine)
      • Save Simulation Instance
    • The Steering palette includes the following new VIs:
      • Apply Velocity to Motors
      • Draw Steering Frame Picture
      • Get Velocity from Motors
    • The Advanced palette of the Steering palette includes the new Reposition Wheels on Steering Frame VI.
    Refer to the Robotics Module»Robotics VIs book on the Contents tab of the LabVIEW Help for more information about these VIs.
    New Drivers
    The Device I/O palette includes the following new drivers:
    • The Electronic Compasses subpalette includes PNI Fieldforce TCM drivers.
    • The Motors subpalette includes Parallax Standard Servo drivers.
    • The new RFID subpalette includes APSX RW Series drivers.
    • The new Text to Speech Devices subpalette includes V-Stamp drivers.
    The new Device I/O with Simulation palette includes the following drivers that communicate with both real and simulated sensors and actuators:
    • The GPS subpalette includes u-blox 5 Series drivers.
    • The Infrared Range Finders subpalette includes Sharp IR GP2D12 drivers.
    • The Laser Range Finders subpalette includes Hokuyo URG Series drivers.
    • The Motors subpalette includes the following drivers:
      • DC Motor Controller
      • Hitec HS400 Series
      • Parallax Standard Servo
    • The Sonar subpalette includes Parallax PING))) drivers.
    New Examples
    The labview\examples\robotics directory includes the following new examples:
    • Robot Communications\Network Streams\Robot Communications using Network Streams.lvproj
    • Simulator\Goalkeeper\Goalkeeper.lvproj
    • Simulator\iRobot Create\Simulated iRobot.lvproj
    • Simulator\Robot Balance\Robot Balance.lvproj
    • Simulator\Robot Maze\Multiple Robots in Maze.lvproj
    • Simulator\Traffic\Traffic.lvproj
    • Starter Kit 1.0\Starter Kit 1.0.lvproj
    • Starter Kit 2.0\Starter Kit 2.0.lvproj
    • Starter Kit 2.0 Custom FPGA\Starter Kit 2.0 Custom FPGA.lvproj
    The LabVIEW 2011 Robotics Module introduces the following behavior changes.
    Certain VIs are deprecated or moved in the Robotics Module 2011. If you open a VI developed with the Robotics Module 2010 or earlier that contains one of these VIs, the VI is broken. Remove the missing VI or call it from the correct location on disk.
    The following VIs are deprecated or moved:
    • The Skilligent VIs are deprecated. Refer to the National Instruments Web site to access the Skilligent VIs.
    • The MobileRobots VIs, properties, and methods are deprecated.
    • Certain utility VIs that manipulate angles are rewritten in LabVIEW 2011. These VIs, located in the vi.lib\robotics\utility directory, did not appear on the Robotics palette. Replace instances of these utility VIs from previous versions of the Robotics Module with VIs from the Mathematics»Geometry»Angle palette.
    • Certain driver VIs for use in FPGA applications moved on disk. In the Robotics Module 2010 and earlier, the VIs are part of examples located at labview\instr.lib\device\FPGA Example, where device is the name of the sensor or actuator. In the Robotics Module 2011, the VIs moved to directories at labview\instr.lib\device\FPGA.
    Palette and VI Changes
    The Robotics Module 2011 includes the following changes to palettes and VIs:
    • The Apply Velocity to Wheels and Get Velocity from Wheels VIs include a wheel indexes input that allows you to specify specific wheels on which you want to operate.
    • The Sensing palette is renamed as the Sensors and Actuators palette. Subpalettes for traditional device drivers are located under a new Device I/O subpalette.
    • The Motion palette is renamed as the Motors palette.
    • In the Get Sentence Parts, Get Sentence Type, and Validity Check VIs on the NMEA Advanced palette, the valid sentence ? output is renamed valid sentence?.
    Changes to Third-Party Add-on Offerings
    In the Robotics Module 2010, the installation media you purchased contains the Cogmation Toolkit for LabVIEW and the TORC JAUS Toolkit for LabVIEW. In the Robotics Module 2011, you must obtain the toolkits separately. Refer to the LabVIEW Tools Network for more information about the Cogmation Toolkit. Refer to the TORC Web site for more information about the TORC JAUS Toolkit.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Robotics Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2011 Robotics Module. This is not an exhaustive list of issues fixed in the current version of the Robotics Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    233753The Hardware Setup Wizard installer upgrades incorrectly.
    235756Undo doesn't work with the attitude and compass indicators.
    236687Serial Arm visualization VIs incorrectly treat prismatic joints as revolute joints.
    238493An flash.ocx error occurs when exiting LabVIEW Robotics mode if Flash is not installed.
    238691Cannot deploy the Starter Kit roaming executable as a start-up application.
    241835The Starter Kit roaming example uses the wrong wheel separation value.
    244642In the Starter Kit roaming example, if the velocity setpoint goes beyond ±32 rad/s, the direction of the motor reverses.
    246660Apply Velocity to Wheels and Get Velocity from Wheels VIs do not allow selection of specific wheels.
    277023The no valid path exists output of the A* VI doesn't indicate when no path is found.
    279868Poor performance with the attitude and compass controls.
    292411Error –2318 on first run of the 3D Mecanum Robot example.
    Important Information
    I.     For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in LabVIEW, refer to the Copyright topic of the LabVIEW Help.
    II.     The Open_Dynamics_Engine_notice.pdf file contains a third-party copyright notice for third-party components used by certain Robotics Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    National Instruments\LabVIEW 2011\readme
    GMT+8, 2026-3-15 05:53
