查看: 3384|回复: 0
[NI软件产品] NI Switch Executive 2015 Full Win32/64Eng 美国国家仪器开关管理软件NISE15.1.0完整版下载
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-8-8 00:26:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Switch Executive是一款开关管理与路由应用软件,能够加速开发过程、简化对复杂开关系统的维护。
    Switch Executive提供交互式配置和自动路由功能,使开关系统的设计变得更加容易。您可以为开关模块、外部连接和信号路由分配别名,从而简化系统的文档,以便未来进行修改。使用Switch Executive开发的测试代码可以复用于LabVIEW、LabWindows/CVI、Measurement Studio和TestStand环境。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    SE15.1.0.txt (246 Bytes, 下载次数: 1, 售价: 10 圆)
    NI Switch Executive 2015 Readme
    August 2015
    Thank you for using NI Switch Executive. This file contains important information about NI Switch Executive and is organized into the following sections:
    Release Notes
    Uninstalling/Modifying NI Switch Executive
    NI Switch Executive 2015 includes the following new features:
    • Addition of Get NI-SWITCH Session VI and Release NI-SWITCH Session VI. These VIs allow the user to programmatically control or modify attributes of NI-SWITCH devices during the NI Switch Executive session.
    • NI-SWITCH CA4 support
    • LabVIEW 2015 support
    • 64-bit support
    NI Switch Executive 3.6 includes the following new features:
    • MAX Import and Export wizard support
    • TestStand deployment integration
    • NI Configuration Export (nce) file format added for niSE_ImportSpecific() and niSE_ExportSpecific() functions in LabVIEW, CVI, and VB APIs
    • niSE_IsConnected(), niSE_GetAllConnections(), and niSE_ExpandConnectionSpec() functions added to LabVIEW, CVI, and VB APIs
    • niSE_ExportPrevious() function added to LabVIEW, CVI, and VB APIs which enables export of previous NI Switch Executive configurations
    • Miscellaneous performance improvements
    NI Switch Executive 3.5 includes the following new features:
    • NI SwitchBlock Configuration Wizard
    • Debug Panel
    • Support for Debug Deployment license
    • NI switch modules can now be used without IVI logical name and driver sessions
    • Support for Windows 7
    NI Switch Executive 3.0 includes the following new features:
    • Support for schematic configuration
    • Support for Microsoft Excel spreadsheet import and export
    • Support for sharing of route legs
    • Performance improvements
      • Find route is 36% faster for multi-device routes
      • Sorting and endpoint selection are faster in MAX
    Release Notes
    Please take note of the following before installing NI Switch Executive 2015:
    • NI Switch Executive 2015 properly upgrades any existing configurations created with previous versions of NI Switch Executive.
    • Licensing: At installation, NI Switch Executive defaults to use an evaluation license of the software. Activate the software at Start»All Programs»National Instruments»NI License Manager to enable a fully functional license. Refer to the NI Switch Executive Help for more information about activating your software.
    If you are using NI Switch Executive 2015 with NI switch modules you must install NI-SWITCH 2.4 or later.
    NI Switch Executive 2015 supports the following operating systems:
    • Windows 8.1/8.0 (32-bit and 64-bit)
    Note  NI Switch Executive 2015 and later does not support Windows Server non-R2 editions.
    Minimum System Requirements
    • Development
      • Processor—
        • Windows XP Service Pack 3 (SP3): Pentium III/Celeron 600 MHz or equivalent
        • Windows 8.1/8.0/7/Vista: 1 GHz or faster
      • RAM—
        • Windows XP Service Pack 3 (SP3): 128 MB
        • Windows 8.1/8.0/7/Vista: 512 MB
      • Windows 8.1/8.0/7/Vista/XP SP3, with all available critical updates and service packs
    • Deployment
      • Processor—
        • Windows XP Service Pack 3 (SP3): Pentium 200 MHz or equivalent
      • RAM—
      • A screen resolution of 800 x 600 or no screen
    • Debug Deployment
      • Processor—
      • RAM—
    Recommended System
    • Development
      • RAM—
        • Windows XP SP3: 256 MB
        • Windows 8.1/8.0/7/Vista: 1 GB (32-bit), 2 GB (64-bit)
    • Deployment
      • Processor—1 GHz or faster
      • RAM—
      • A screen resolution of 1,024 x 768 or no screen
    • Debug Deployment
      • RAM—
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI Switch Executive. To add support for ADEs installed after installing NI Switch Executive, modify your NI Switch Executive installation or launch the NI Switch Executive installer again.
    • NI LabVIEW 2012 SP1 (32-bit), 2012 SP1 (64-bit), 2013 SP1 (32-bit), 2013 SP1 (64-bit), 2014 SP1 (32-bit), 2014 SP1 (64-bit), 2015 (32-bit), or 2015 (64-bit)
    • LabWindows/CVI 2012 or later
    Installed Software, Documentation, and ExamplesInstalled Software is an alias for the following National Instruments file folder location:
    • Windows 8.1 (32-bit)/8.0 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: \Program Files\National Instruments
    • Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): \Program Files (x86)\National Instruments
    ItemInstalled Location on Windows 8.1/8.0/7/Vista/XP
    NI Switch Executive\SwitchExecutive\SwitchExecutive.exe
    NI Switch Executive Function Panel
    \Shared\CVI\bin\nise.lfp
    \Shared\CVI\bin\niseCfg.fp
    NI Switch Executive Examples\SwitchExecutive\Examples
    NI Switch Executive Header files\Switch Executive\API\C
    NI Switch Executive Import Library files (32-bit)\Switch Executive\API\C
    NI Switch Executive Import Library files (64-bit)\Switch Executive\API\C\Lib_x64
    NI Switch Executive DLL*\Windows\System32
    *Installed location on 32-bit operating systems only. Refer to the following table for installed locations on 64-bit operating systems.
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI Switch Executive DLL (32-bit)\Windows\SysWOW64
    NI Switch Executive DLL (64-bit)\Windows\System32
    Select Start»All Programs»National Instruments»Switch Executive»NI MAX with NI Switch Executive to launch NI Switch Executive.
    Documentation for NI Switch Executive is located at Start»All Programs»National Instruments»Switch Executive»Switch Executive Documentation. The documentation set is composed of the following documents:
    DocumentFormatDescription
    NI Switch Executive HelpHTML/Windows HelpContains primary help content for NI Switch Executive products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI Switch Executive
    • A complete reference for all NI Switch Executive programming functions and VIs
    NI Switch Executive Getting Started GuidePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    NI Switch Executive ReadmeHTML (this document)Contains information about supported operating systems, new features, fixed issues, and legal notices.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI Switch Executive examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Toolkits and Modules»NI Switch Executive.
    • Click the Search tab to search all installed examples by keyword. For example, search for "Switch Executive" to locate all NI Switch Executive examples.
    You can also access all the installed NI Switch Executive examples for LabVIEW at Start»All Programs»National Instruments»Switch Executive»Switch Executive Examples and online at ni.com/examples.
    • Click Change/Remove.
    • Select NI Switch Executive 2015 from the dialog box that appears.
    • Select Driver Runtime.
    • Click Remove to uninstall the product(s); click Modify to change the components that are installed.
    For Windows 8.x, complete the following steps:
    • Right-click the Start screen.
    • Select All apps and launch the Control Panel.
    • Click the Uninstall button.
    As part of the NI Switch Executive 2015 installation, the following software is installed. To completely remove the NI Switch Executive 2015 installation from your system, you must also remove all of the following packages:
    • NI IVI Compliance Package 15.0
    • NI Measurement & Automation Explorer 15.0
    • NI-VISA 15.0
    • NI I/O Trace 15.0
    You can access the software known issues list online. Refer to the NI Switch Executive 2015 Known Issues at ni.com/info and enter the Info Code exjxuq for an up-to-date list of known issues in NI Switch Executive.
    The following items are changes in NI Switch Executive 2015 from NI Switch Executive 3.6.
    326078Corrected an problem in which DPST and DPDT topologies displayed as independent topologies in the Schematic Configuration tab.
    371416Corrected a problem in which certain devices could not be operated in the Test Panel due to InitiallyConnectedChannelState channels.
    526810Corrected a problem in which NI Switch Executive configurations could not be imported in the .nce format.
    The following items are changes in NI Switch Executive 3.6 from NI Switch Executive 3.5.
    328878Fixed the Find Route error in NI Switch Executive (CVI Error -1074126840).
    345048Fixed an issue in which TestStand took up to 10 seconds to load the SE Virtual Device names and Route(s) to Connect.
    The following items are changes in NI Switch Executive 3.5 from NI Switch Executive 3.0.
    122555Fixed an issue in which multiple calls to the niSE Find Route VI yielded different results.
    171277NI Switch Executive now properly supports disconnected licenses.
    196256NI Switch Executive now checks out licenses based on context feature.
    The following items are changes in NI Switch Executive 3.0 from NI Switch Executive 2.1.1.
    109275In some cases involving exclusions and hardwires, NI Switch Executive was not detecting exclusion conflicts. This fix might cause a previously validated configuration to not validate until the exclusion conflict is resolved.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    NI Switch Executive Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Switch Executive will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI Switch Executive that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes.
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2002–2015 National Instruments. All rights reserved.
    375352A-01
    GMT+8, 2025-10-30 05:15
