查看: 3446|回复: 0
[NI软件产品] NI DIAdem 2011SP1 Win32Eng NI数据管理软件DIADEM2011SP1基本高级专业版下载DIAdem11.3SP1
    3 小时前
  • 签到天数: 3745 天
    连续签到: 72 天
    发表于 2020-8-9 19:19:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    DIAdem11.3SP1-2011SP1.txt (258 Bytes, 下载次数: 1, 售价: 10 圆)
    DIAdem 2011 SP1 Release Notes
    Version 11.3 SP1
    November 2011
    This file contains information on DIAdem 2011 SP1:
    • System Requirements
    • Notes on DIAdem 2011
    • New Features in DIAdem 2011
    • Fixed Issues in DIAdem 2011 SP1
    For correct DIAdem performance, the following minimum requirements must be met:
    Hardware
    CPUx86 compatible processor, 1.6 GHz or more
    Amount of memory1 GB or more
    Hard disk memoryDepending on the operating system, up to 2.2 GB free storage space, of which at least 1.3 GB on the system partition
    Graphics boardColor depth at least 16 bit (High Color), recommended 24 or 32 bit (True Color)
    Screen resolutionAt least 1024x768
    Operating Systems
    • Windows XP Pro 32 Bit Service Pack 3 or later
    • Windows Vista 32 Bit with Service Pack 2
    • Windows Vista 64 Bit with Service Pack 2 (as 32-bit application)
    • Windows 7 32 bit
    • Windows 7 64 Bit (as 32-bit application)
    • Windows Server 2003 R2 32 Bit
    • Windows Server 2008 R2 64 Bit (as 32-bit application)
    Administration
    FirewallThe firewall displays warnings while DIAdem installs and while DIAdem launches, for the following reasons:
    The usireg component executes during the installation of DataPlugins. The DataFinder, which you use for searching and navigating in files, then starts. When DIAdem launches, a DNS query determines whether to license locally or whether to use a license server.
    If you want to be able to use all the DIAdem functions, National Instruments recommends that you select "Do not block" for all programs listed. This also applies when you want to evaluate DIAdem. Refer to ni.com/info under the info code winxpsp2.
    Windows User RightsDIAdem and its components are basically executable under the preconfigured Microsoft Windows user accounts from User onwards. DIAdem must be installed with complete administrator rights.
    If you operate various DIAdem versions on one computer, you only have the entire range of functions in each version if you have administrator rights.
    Miscellaneous
    • Internet Explorer Version 6.0 Service Pack 1 or later
    • Recommended:
      - Adobe Reader to display manual files
      - Adobe Flash Player for Microsoft Internet Explorer to display the tutorials
    • DIAdem Version 9.0 and LabVIEW Version 7.1, and later versions, use a shared software component that is updated when you install DIAdem. When you uninstall DIAdem, the current version of the shared component remains. This is intentional and has been tested extensively.
    • For the DataFinder in DIAdem 2011, any index files from earlier DIAdem versions must be regenerated. This occurs automatically when you launch DIAdem. Depending on how many files are to be indexed, this may take quite some time.
    • We strongly recommend that you install DIAdem in the suggested folders on Windows Vista and on Windows 7, or that you specify the folder exclusively in the path selection dialog box in the setup program. In particular, changing the suggested program path manually in the installation program can cause problems in DIAdem.
    • When executing DIAdem or DIAdem scripts under Windows Server 2003, runtime errors might occur due to an error in the runtime library of the system. As a workaround, Microsoft has provided a hotfix which you can download at http://support.microsoft.com/?scid=kb%3Ben-us%3B955536.
    • If you install an earlier DIAdem version after the installation of DIAdem 2011, the PDF export of this earlier version does not function. You can solve the problem in 10.1 to 11.1 if you copy the following files from the DIAdem 2011 program folder into the program folder of the earlier DIAdem version:
      • acfpdf.drv
      • acfpdf.txt
      • acfpdfu.dll
      • acfpdfuamd64.dll
      • acfpdfui.dll
      • acfpdfuiamd64.dll
      • cdintf.dll
    • DIAdem 2011 is the last version to support the execution of AUT scripts and COD dialog boxes. Any existing AUT scripts and COD dialog boxes to be used in future DIAdem versions must then be changed to VBS scripts and SUD dialog boxes. Refer to AUT/VBS Converter in the DIAdem online help for more information on this change.
    • DIAdem 2011 is the last version to support the loading of REPORT layouts in the old LPD format. To convert old LPD layouts into the current TDR format, load the LPD layout with DIAdem 2011 and save it in the standard TDR format.
    Compatibility of DIAdem 2011 and DIAdem 2010
    • The GPI-based ASCII and Excel import wizards were replaced by import wizards in DIAdem 2011 that can also generate a DataPlugin. These can also help you to load more files of the same format without going through the wizard to load them. If you want to execute scripts based on old import wizards, or if you want to continue using them for other reasons, you must first register the respective GPI extensions GfSExcel.dll and GfSASCII.dll (Settings»Options»Extensions»GPI Extensions).
    • To export data from DIAdem to Excel, you can save them in TDM format and in Excel using the TDM Excel Add-In.
    • In DIAdem REPORT the clipping parameters "Only hide axes" and "Hide axes and curves" are not available, even if you load an old LPD layout. Instead, you can specify a background color for each report object. In the object settings, select white as the background color if you want to show report objects on top of the axis system.
    • DIAdem 2011 supports various new processes for loading data. Depending on the process, the data is loaded into the memory as required. Depending on the application, this can result in increased speed when working with large amounts of data. The default is automatic loading on first write access. Should you experience problems with certain applications, you can restore the previous mode in the NAVIGATOR settings. Refer to the online help Basics> DIAdem NAVIGATOR > Loading Bulk Data - General for more information on this setting.
    Compatibility of DIAdem 2011 or DIAdem 2010 with Earlier Versions
    • In DIAdem 11.0 and later versions the default settings of the function groups are saved in a new format. The previous PAR files can no longer be read in. If you previously used user-defined settings of the function groups, you must recreate these settings.
    • The SUD file format is different in DIAdem 2010. You can load SUD files from earlier versions with DIAdem 2010, but you cannot load SUD files that you created in DIAdem 2010 with version 11.1 or earlier versions.
    • The font and color settings of the DIAdem editor and the SUD editor have been unified with the renewal of the SUD editor. The DIAdem SCRIPT settings are now valid for both editors. These settings are now saved in the registry and not in the workspace file.
    • The event procedure syntax in the SUD dialog editor has changed in DIAdem 2010. The definition of the variable this has been moved from the procedure body to the parameter list of the events. User dialog boxes that were created with earlier versions remain fully functional. When loading earlier SUD files into the dialog editor, DIAdem automatically converts these files into the new syntax. Refer to Converting User Dialog Boxes in the Help for further information.
    • The methods GetArgument and SetArgument for handling transfer parameters in user dialog boxes are no longer supported in the Dialog interface in DIAdem 2010 and later versions. These methods were already without a function before if the user dialog box was non-modal.
    • In earlier DIAdem versions the command Navigator.LoadData returned a Boolean value to indicate whether the loading operation was successful. From DIAdem 2010, a list with the loaded objects is returned instead. If you evaluated the previous return value in scripts, you can replace the earlier call Navigator.LoadData (...) with "CBool(Navigator.LoadData (...).count).
    • From DIAdem 2010, the CAN Converter directly creates a TDM file with an associated TDX file and no longer a TDM file with separate BIN files for every generated group. Now the BIN files are automatically deleted. You might have to remove the deletion of BIN files from your scripts.
    New Features in DIAdem 2011General
    • The path of the help tree in DIAdem help, which guides you to this help page, is in the top line.
    • The help pages for the DIAdem dialog boxes contain information about the software package you require for each respective function.
    DIAdem NAVIGATOR, DataFinder, Data Portal
    • Use the Excel DataPlugin Wizard to interactively create a new DataPlugin that DIAdem can use to read in or register similar spreadsheet files.
    • The loading behavior of DIAdem is more flexible now, which speeds up working with large files. If you load a file with very long channels using drag&drop, the Data Portal immediately displays all channels and their properties in the Data Portal. DIAdem only loads the associated mass data to the internal storage when you need it, for example if you want to edit data.
    • The ASAM ODS data browser has been enhanced:
      • Variable browse settings
      • Improved data preview
      • Improved working with submatrices
      • New API functions to set and read server parameters
      • Displays whether the server supports OR operators
    • The CAN converter supports PCAN-Trace logfiles (*.trc) and the Vector-CAN database format (*.dbc).
    • The CAN converter can read time stamps to start a trigger block in vector ASCII logfiles and stores these time stamps in the custom properties CANBeginTriggerBlock and CANEndTriggerBlock.
    • You can select several entries in the DataFinder and in ASAM-ODS data stores in the same way as in the data portal. Click the respective symbols one after the other to select several entries.
    • In the DataPlugins and in the DataPlugin wizard for text files, you can now select various character encodings (Automatic, ASCII, Unicode, Shift JIS).
    • The context menu object enables you to access the File browser, Data browser, DataFinder search results, Data store search results, and the channel preview from a user command.
    DIAdem VIEW
    • You can display the value pairs based on longitude and latitude as lines.
    • You can specify how DIAdem moves the map section when using cursor synchronization.
    • You can load TDV files to existing layouts.
    • The context menu object enables you to access the context menu of DIAdem VIEW from a user command.
    • A new event OnDblClick is available, which triggers when double-clicking an area.
    • There are new markers available.
    • You can use the TabBarVisible property for Settings to specify whether DIAdem shows or hides the tabs to manage worksheets in VIEW.
    DIAdem ANALYSIS
    • In the DRI Crash function it is now possible to specify the direction of the DRI calculation and the damping coefficient if the DRI calculation is free.
    • The ASI calculation conforms with the current changes in the EN 1317 norm. DIAdem now filters the data with the CFC filter with the limit frequency CFR = 13Hz.
    • It is now also possible to copy properties to the calculation manager using drag&drop.
    DIAdem REPORT
    • The presentation of reports has undergone fundamental changes. New drawing routines have improved the presentation of objects. Improved line rendering displays curves and axis systems without distracting jagged edges. Raster graphics such as PNG, GIF, and TIF support transparency and appear smoother at the edges thanks to antialiasing.
    • You can use the shortcut menu to copy worksheets. You can do this with the GraphSheetCopy command.
    • With the new character table dialog, you can insert symbols and special characters in many places in your text.
    • The dialog for managing worksheets has been revised and enhanced.
    • It is now simple and easy to add comments to curve points with one mouse click. DIAdem creates a comment with the x- and y-value of the curve point, to which you can add more text. If you move the axis system or change its size, the arrow of the comment will continue to point to the point on the curve.
    • You can now also transfer the properties of 3D objects.
    • You can change the value range of axis systems in REPORT using the mouse. It suffices to select the axis with the cursor and make manual adjustments to the value range by dragging it with the mouse or by rotating the mouse wheel.
    • In 2D tables you can truncate or wrap column texts at the column bound.
    • With the new column type Text list in 2D tables, you can save static or dynamic texts in the layout without referring to channels or scripts.
    • You can insert curve snippets into any kind of text.
    • You can determine the reference point of the legends.
    • In the characteristic diagram display you can specify additional isolines. Extended isolines allow you to highlight individual isolines.
    • In the characteristic diagram display you can specify whether DIAdem considers the isovalues when autoscaling the axes.
    DIAdem SCRIPT
    • You can use the ScriptCMDRegister command to activate CodeCompletion for encrypted user functions. DIAdem takes the information for CodeCompletion from the TLB file.
    • You can use the DIAdem commands FTPConnect, FTPDisConnect, and FTPDownload to receive files from the FTP server.
    • The DataFileLoadSel command for selective loading now also supports name-based access as well as index-based access.
    • The new GroupCopy command copies one or more channel groups to a new position inside the Data Portal.
    • The LoadChannelsByName method for Navigator loads calculated measurements from an ASAM server to the Data Portal by their name. The bulk data can be generated by an external formula interpreter or through DIAdem calculations.
    • You can switch the SmartInfo in SCRIPT and in the dialog editor on and off with the shortcut .
    • DIAdem automatically wraps long tool tips in the dialog editor.
    The following list contains the CAR IDs and the descriptions of the problems solved between DIAdem 2011 and DIAdem 2011 SP1. Use the CAR ID to check in the list whether the issue has been fixed. The DIAdem Knowledgebase contains a list of fixed issues from earlier DIAdem versions under the search term Fixed Issues.
    CAR IDDescription
    General
    325583Channel number strings with a separator at the end, for example "1-" or "1,2,3," lead to a program crash.
    DIAdem NAVIGATOR
    309054DataPlugins: ProcessedChannel type numeric channels return NoValues if one or more channels are not eR64 data type.
    309991In the main dialog box of the CAN converter, the Cancel button is not working properly because the CAN conververt does not reset changed settings.
    310449DataPlugins containing Japanese characters lead to script errors when importing.
    315000If DIAdem cannot load a subset when loading elements from a data store, DIAdem displays a wrong error message.
    315215The CAN converter does not display the original address for masked IDs in a property or in a part of the group name if the database file is a file with the J1939 mode.
    315434When converting NI NCL files, the CAN converter uses 01/01/1601 as a time basis, instead of displaying the time channels as relative time channels. As of DIAdem 2011 SP1, the starting time is located in the CANTimeStamp group property.
    315811After the interactive CAN conversion the result file is registered and cannot be saved.
    319652Expanding channels is significantly slower in DIAdem 2011 than in DIAdem 2010.
    320763If you load data with DataPlugins that use the ASCII file reader, the channels may be longer than specified.
    322331The CAN converter does not include the FE joker at the DestinationAddress of a J1939 ID.
    DIAdem VIEW
    308336When the measurement values do not increase monotonously, you cannot position the curve cursor on all points of the curve.
    308340You cannot zoom JPG files.
    309951In axis systems with the setting "n Y-Axes", DIAdem only prints the first y-axis.
    317974The map display does not work with the Microsoft MapPoint map type if only the North America map is installed.
    DIAdem REPORT
    306280You can select the color "Palette" as color for the background segments, although DIAdem does not support the color "Palette" here.
    307078When refreshing a master layout, DIAdem may change the worksheet orientation from portrait to landscape.
    307441In the "Filled area" display mode, if you select a filling color that uses filling effects, the "Curve related" filling mode may lead to an incorrect display.
    307808In a 2D axis system, if a curve lies outside the axis system, DIAdem does not display a filling pattern in the "Filled area" display mode.
    307810In 2D axis systems, DIAdem does not display a filling below a curve if the curve lies outside the axis system.
    308725Adding curve coordinates for "Local minimum" and "Next value" does not work properly.
    309248DIAdem may position coordinates incorrectly when the axis system is scaled manually.
    310126When you are using 2D axis systems in the expansion mode, DIAdem, under certain circumstances, may delete other 2D axis systems when you open a 2D axis definition dialog box.
    313525Black bars in an axis system with black axes lead to a program crash.
    314736When you are using 2D axis systems in the expansion mode, DIAdem, under certain circumstances, may delete channels.
    318530The "Expand curve" setting is not available for all display modes of a 2D axis system.
    319636Dragging and dropping a property from the data portal into the legend dialog box of a 2D axis system may lead to a program crash.
    319867The setting "Bound to axis system" for the color legend of a 3D axis system leads to an error.
    323319The WMF export does not include the specified page layout. In addition, a frame affects the proportions of the exported object.
    327659If a 2D table contains text lists, DIAdem consumes memory.
    DIAdem SCRIPT
    313503If you assign a text to a DataTypeDate property through the script interface for internal data, this leads to a program crash.
    313662You cannot use ElementList collections in the debug mode.
    315944The ColorChoose command incorrectly sets the status of the DlgState variable, so you are unable to see how the dialog box was closed.
    318326On writing a single value for the first time with the script interface for internal data, DIAdem changes the channel length of a previously loaded CSV file.
    Dialog editor
    306761Copying a control element or a user dialog box generates invalid user dialog boxes in the Japanese version.
    320771DIAdem displays user dialog boxes incorrectly when you scroll inside the user dialog box.
    The following list contains the CAR IDs and the descriptions of the problems solved between DIAdem 2010 and DIAdem 2011. Use the CAR ID to check in the list whether the issue has been fixed. The DIAdem Knowledgebase contains a list of fixed issues from earlier DIAdem versions under the search term Fixed Issues.
    CAR IDDescription
    General
    246030Under certain conditions (for example, under a Japanese operating system with the input help of MS Office 2010) the following error message might display when the program launches: "Microsoft Visual C++ Runtime Library: Runtime Error! Program: C... R6030 -CRT not initialized".
    254127If DIAdem launches with particularly long start parameters, it might happen that the write access to the variable L1 to L32 is corrupt.
    258414The format specification for a binary display leads to an empty result.
    291257DIAdem does not shut down completely if the introduction screen is active and the ApplicationExit command is called.
    292263DIAdem may not start because the DataFinder cannot be initialized or because initialization takes very long.
    Data portal
    251580If you drag a property from the Data Portal into the NAVIGATOR search area, the program might crash.
    255100The calculator and the calculation manager assign the "Entered" value instead of the "Calculated" value to the "Status" channel property.
    277681If you delete all values of a channel with the ChnAreaDel command, DIAdem also deletes all channel header information and the channel name.
    287051If the List view of the data portal is active and does not contain channels, DIAdem will crash when creating Root properties from a user dialog box or from a script containing the "UIAutoRefresh=True" statement.
    NAVIGATOR
    224112DIAdem cannot selectively load Access files with the *.accdb file extension and then open them as a data store.
    224402If an error occurs, the commands to open a DataFinder or a data store generate error messages that you cannot suppress with "On Error Resume Next".
    235383In the case of ASAM ODS data, DIAdem loads existing custom properties at SubTest and Test level with a loading configuration, even if these custom properties are not marked with in the loading configuration.
    235952When loading data from an ASAM data store with a loading configuration and with the "Type_Property" name pattern, DAIdem loads the custom properties at the first SubTest level above the measurement with the prefix "TypeName" to the root.
    236228When loading ASAM ODS data, DIAdem uses a loading configuration to overwrite the custom properties of a main level with the custom properties of a sub level if these have the same name and the setting Inheritance: "None" and name pattern: "Property" are selected.
    236532In the case of ASAM ODS data, DIAdem uses a loading configuration with the Inheritance settings: "None", and name pattern: "Type_Property", to create an eponymous application property with a post fix, instead of ignoring this property.
    240828If you drag and drop elements from the NAVIGATOR tree into the Data Portal, the selection of the respective elements in the NAVIGATOR tree disappear.
    243576In the "My Computer" area of the file browser, DIAdem does not display all file name extensions of files that DIAdem has loaded as GPI file filters.
    249381The CAN Converter does not calculate the characteristic channel values minimum and maximum during conversion.
    251388The CAN Converter does not support NI CAN log files with the Header version 1.1 specified for NI XNET.
    253159DIAdem formats the name of a multiplexer group from the CAN conversion incorrectly if the mode is larger than 9999.
    253351The CAN Converter shortens float values and integer values with more than 32 bit to 32 bit integer values.
    253629Integer values read-in with the CAN Converter from CAN log files with a set bit 53 can differ from the original values.
    254653Loading TDMS files with absolute time channels takes a long time.
    256568DIAdem shortens units of DIAdem channels to 16 characters when exporting in Excel.
    257387The CAN Converter might crash if the signal comments in a DBC file contain more than 1024 characters.
    257815Because DIAdem uses the Motorola byte order, DIAdem reads multiplexer data with more than 8 bit and Intel byte order incorrectly into the CAN Converter.
    278169DIAdem incorrectly displays implicit channels of an ASAM data store.
    282332DIAdem no longer recognizes waveform channels, saved with a channel length of 0, as waveform channels when they are reloaded.
    283169The CAN Converter cannot always correctly convert ASCII logfiles from the company Vector, which contain tab characters instead of blanks as separators, and whose DBC signal description files are in the J1939 format.
    283173The CAN Converter converts Vector LOG logfiles with relative time stamps into absolute times, making this data unusable.
    284643DIAdem is unable to map enumerations in application properties from other sources to custom properties, and ignores these when loading.
    290192A DataPlugin, which uses a VBS DataPlugin as file reader, returns the error message that the eStoreChannelGroup variable is not defined if the USI versions are not the same.
    292075DIAdem reads-in large number values incorrectly with the DataPlugin for CSV files.
    294299When the CAN converter converts Vector logfiles, the time channel may display a sawtooth waveform under certain circumstances.
    294852If the CAN Converter converts Vector logfiles in which the ID of a frame is larger than the value of MaxUnsignedLong, DIAdem can only generate the signal with the Integer data type, not with the Float data type.
    296066DIAdem cannot load columns from the search results if the content of the columns only contains time information without date.
    296543The DataFinder does not register files if entire folders were copied into a search area or were deleted from a search area.
    298504If the CAN Converter converts Vector ASCII logfiles that contain more "Begin TriggerBlock" rows than "End TriggerBlock" rows, DIAdem may crash.
    247296If you enter Japanese characters into the advanced search, the program might crash if you are using Microsoft IME 2010.
    VIEW
    210213If a map has the focus, keyboard shortcuts do not work, for example .
    258224Cursor synchronization is distorted because DIAdem does not always update videos fast enough.
    286405If Internet Explorer 8 is running on your system, error messages can occur when displaying maps.
    296327If the time channel increases monotonously, DIAdem does not synchronize a map with the cursor in the measurement mode.
    298703If you are running a contour display in the background (...Cursor.Play(FALSE)), the program will crash.
    301186Under certain circumstances, a corrupt WRL file will lead to a program crash.
    ANALYSIS
    249371The ChnFFT command uses up memory depending on the number of values of the input channels.
    254396The Rainflow classification (Command: ChnRainCalc) leads to a program crash with specific classification parameters.
    257049DIAdem does not filter the data for the ASI calculation in accordance with the new norm EN 1317-1:2010 using a CFC filter with the limit frequency CFR = 13 Hz.
    276235If you limit the evaluation of the 3D interpolation (Command: MatD3Interp) to grid points within a closed, convex polygon, DIAdem, in rare cases, also uses points outside the polygon.
    286498The ChnDurInjuryCalc command used to calculate the time-at-level does not specify the result channel for the load durations of the positive and negative amplitudes.
    287428The calculation manager suppresses letters from these names in the graphic display when input names are similar.
    288818In the linear display, DIAdem calculates the last value incorrectly under certain conditions.
    291341The SRS function determines wrong result units if the setting "Calculate quantity-based" is active.
    293021A surface, interpolated from triplet data with the SISPL process, "sags" in certain cases.
    300653In the compound classification, DIAdem does not count values above the greatest class, despite open boundary classes.
    301971Under certain circumstances, the graphic display of a calculation instruction in the calculation manager displays the parameters of user functions incorrectly.
    REPORT
    238156In some cases, if you set "solid" and "filled" in the manual scaling mode, DIAdem displays a 3D surface or a characteristic diagram also outside the axis system.
    239754DIAdem does not recognize that a layout has changed if you only change the worksheet name through the context menu. For this reason DIAdem does not ask whether you want to save changes to the layout.
    240113In the differential characteristic diagram, DIAdem outputs the z-values of the first characteristic diagram instead of the values of the differential characteristic diagram if the measurement points are also displayed.
    240323If you select an object with the key, DIAdem only displays the object name for a short time instead of waiting until the mouse pointer is on the next object to display the next object name.
    240332DIAdem ignores legend texts when outputting, for example, PDF files or PPT files if the "Word wrap" setting is active.
    243703The REPORT objects comment, rectangle, circle, and arrow cannot be selected through the menu in the Base version.
    244352If you transfer a layout from DIAdem REPORT to DIAdem VIEW with a textbox using the function "Transfer to VIEW", DIAdem does not display the textbox in DIAdem VIEW.
    246638If you set manual axis scaling in the 3D surface display, the surface might exceed the axis limits in the top view. This error does not occur in the characteristic diagram or the perspective view.
    247475If a worksheet is deleted in DIAdem REPORT and the process is then reversed with "Undo", only 2 worksheets remain.
    248422PowerPoint Export inserts EMF graphics into the generated PowerPoint files. When saving comprehensive reports with characteristic diagrams, DIAdem can save space by saving them in form of a PNG graphic.
    251299If the character set in the comment object is set incorrectly, errors and corrupt layouts occur.
    257012When performing a curve transformation for channels, the information about the channel group is incorrect.
    257382If you move, copy, or create REPORT pages, the GraphSheetCurrNo variable may contain incorrect page numbers.
    276872Fillings below curves with transparent colors require too much time if the channels are long.
    277039The alignment of subaxis ticks to the main axis grid is not always ideal for the scaling mode "Begin and end manual".
    285784DIAdem incorrectly displays legends with a symbol field width of 0%.
    285785DIAdem does not display legends with a width of 100% and an x-position of 0%.
    286344If, in a layout, you execute the command ScriptStart() before refreshing the layout, DIAdem only outputs the last page when exporting to PDF.
    286851Formula graphics do not support scaled display.
    287253In the Layout Parameters dialog box, you cannot choose between "Relative" and "Scaled" if the page size is fixed.
    288228If, in a characteristic diagram, several isolines are defined in the contour display and the first defined isoline does not lie within the displayed value range, DIAdem displays the remaining isolines in the incorrect color and in the incorrect line style.
    288230If you use the NoValue value as line interval, this will lead to a program crash with certain displays.
    292053You cannot use the name of a previously deleted curve to create a new curve.
    292245As of DIAdem 2011, a REPORT page can contain up to 1000 objects (Variable: ObjectNoMax).
    292752DIAdem incorrectly displays a characteristic diagram and its legend with a logarithmic scaling type for the z-axis.
    293197As of DIAdem 2011, DIAdem no longer supports the setting "Clip against axes and curves" and requires changeover to a display with background color.
    293773In certain cases, DIAdem additionally displays curve end labels at incorrect positions in 2D axis systems.
    298281You cannot change object properties if you copy the objects into new worksheets after previously deleting worksheets.
    302069When displaying the full load curve in a characteristic diagram, DIAdem does not consider the set partial load structure tolerance.
    302801The lower limit of the color legend of a characteristic diagram, whose color is defined in a contour table, is incorrect.
    303926In the 3D view of a characteristic diagram, DIAdem also draws points outside the boundaries of the z-axis.
    SCRIPT
    239974You cannot change properties that have enumeration terms, such as DisplayType, with the object-oriented script interface for internal data.
    240798The Count property for the ModelProperties collection and For Each loops with this collection do not consider properties whose application name is the same as the base name.
    242322You cannot use the IsKindOf method of the ValueWithUnit object with the documented parameter eTypeValueUnit.
    249379If you call commands that use temporary data channels several times in a script, DIAdem executes these commands increasingly slowly.
    249900You cannot access the coordinate of a 3D model in DIAdem VIEW via the object-oriented script interface.
    251060If you access the CurrColumn property in a channel table that displays all channels, DIAdem will crash.
    256143In rare cases, the CurrArea property for Sheet can lead to a program crash.
    277038Using bookmarks in DIAdem SCRIPT and in the script view of the dialog editor consumes memory space.
    277040You cannot check the result values of some functions for validity with the IsNull() function.
    277832When requesting the channel property "wf_samples" using the script interface for internal data, DIAdem reports that "The variable uses an automation type not supported in VBScript".
    288253The methods Navigator.RegisterDataProvider() and Navigator.RegisterDataPlugin() do not display an error message if the file does not exist and the "SilentMode" parameter is "True". The return value in case of an error is False.
    298074The GetValueList and GetValueLimits methods of the IndexedProperty object create problems in the DIAdem debugger when you transfer a Query object in the parameter list. DIAdem then displays this error message: "The object called is invalid".
    298707Under certain circumstances DIAdem does not display script errors.
    User dialog boxes
    197225The dialog editor truncates long variable names in the overview of DIAdem variables.
    230683Scripts in user dialogs ignore the WriteWithoutAsk variable.
    239568If you change between the normal view and the script view, DIAdem may not save changes.
    257042DIAdem does not display an error message if you register, but do not implement, an event in a user dialog box.
    258570Copying and pasting a text to a user dialog box generates a control without the ObjectCode property. This leads to a crash when loading the dialog box.
    277354Under certain circumstances, the user dialog box in DIAdem VIEW displays the error message "Unknown error" instead of the script error.
    © 2011 National Instruments Ireland Resources Limited. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2025-12-17 11:38
