查看: 3066|回复: 0
[LV工具模块] LabVIEW Combustion Analysis System 2013 Win32Eng NI发动机燃烧分析系统软件CAS2013下载
    14 小时前
    发表于 2020-8-16 16:53:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI发动机控制和燃烧分析产品简介
    概览
    NI的发动机控制产品可直接与发动机子系统和激励器相连,例如压电直接喷油器、宽带O2传感器和电子节气门。您可以将具有下一和同一循环控制的燃烧分析系统与NI C系列模块结合,创建具有数据采集和信号处理功能的完整的发动机控制器。
    燃烧分析系统是一个独特的基于labview的VI工具包,使用户能够集成关于发动机的复杂燃烧分析和记录控制应用程序。
    文件大小: 1660744658 字节 (1.55 GB)
    修改日期: 2014-03-08 06:45
    MD5: 97f9592d05ac3bb962f6fdb522883207
    SHA1: 7bef02b117510648c7710b62550f9fc033a3d391
    SHA256: cc5e7a973134b210dd8daef5724fe7c09805e48c873b7a4a0b4fc7777e5d7e47
    CRC32: d7550920
    百度网盘下载地址和NI官方下载地址:
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    CAS2013.txt (470 Bytes, 下载次数: 1, 售价: 10 圆)
    NI Combustion Analysis System Readme
    The Combustion Analysis System is a unique LabVIEW-based VI tool enabling users to integrate sophisticated combustion analysis and logging with engine control applications.
    The following table contains a list of known issues in NI Combustion Analysis System 2013 and any available workarounds.
    IDKnown Issue
    The following table contains the IDs and titles of a subset of issues fixed in NI Combustion Analysis System 2013. This table is not an exhaustive list of issues fixed.
    You can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2013 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software.
    Important Information
    ©2013–2013 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-12-8 23:37
