查看: 2532|回复: 0
[NI驱动程序] NI System Driver Suite July 2020 Win X86/X64 Eng/Fre/Ger/Jpn/Kor/Chn 美国国家仪器系统驱动套件SDS JULY2020
    6 小时前
  • 签到天数: 3719 天
    连续签到: 46 天
    发表于 2020-8-18 16:54:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI System Driver Suite July 2020 Download Windows X86/X64 Eng/Fre/Ger/Jpn/Kor/Chn 美国国家仪器系统驱动套件SDS JULY2020
    System Driver Suite,2020年7月
    System Driver Suite提供了一系列经验证可兼容的NI驱动程序软件集,可用于配置PXI、CompactRIO或CompactDAQ系统。这些驱动程序集可帮助您在整个应用程序生命周期中保持确保对于的驱动程序软件的标准化。使用System Driver Suite,您可以安装一些常见的驱动程序,例如NI-FlexRIO、NI-Motion、NI-DAQmx、NI-VISA、NI-CAN、NI-IMAQ、NI-DMM、NI-SCOPE和NI-VXI等。
    百度网盘下载(限速,请开会员或使用工具下载)待下载上传
    NI官方下载地址(可能无法下载完成或地址无效):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    SDS2020.07.txt (377 Bytes, 下载次数: 2, 售价: 30 圆)
    因为文件比较大,下载完成后,请核对校验和。
    (MD5) f15afc723006dd746b894e81e80c1ae6
    (SHA256) 97aec7cd9bd62d5c38f09e37b86eaab9f5d1345f2468f648ea52fc047408ce9b
    大小:
    22.37GB
    版本号:
    20.7.0
    日期:
    20-8-7
    语言:
    English
    French
    German
    Japanese
    Korean
    Simplified Chinese
    系统:
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bi
    NI System Driver Suite July 2020 Readme
    July 2020
    This file contains important information about NI System Driver Suite, including supported operating systems, installation instructions, and a list of included drivers.
    Drivers Included in the NI System Driver Suite
    NI installs the NI System Driver Suite using NI Package Manager. If you do not already have NI software installed, NI System Driver Suite installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note  If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
    You can also install products using the NI System Driver Suite USB drive. To do so, complete the following steps:
    • Insert the NI System Driver Suite media.
    • Launch Install.exe from the root directory of the installation media.
    Note  If you want to install NI System Driver Suite from a network location, copy the entire contents of the NI System Driver Suite media to a single folder, and launch Install.exe from that location.
    Back to Top
    The following drivers are included on the NI System Driver Suite media. Refer to the readme of each product for information including system requirements, application software support, installation, activation, known issues, and bug fixes.
    Version
    NI-569019.0
    FlexRIO with Modular I/O19.5
    FlexRIO with Integrated I/O19.6
    IVI Compliance Package19.5
    NI CompactRIO Device Drivers19.5
    NI-Digital Pattern Driver19.0
    NI PXI Platform Services19.5
    NI R Series Multifunction RIO19.1
    NI-488.219.5
    NI-DAQmx19.5
    NI-DCPower19.5
    NI-DMM19.5
    NI-FGEN19.5
    NI-HSDIO19.5
    NI-IMAQ19.5
    NI-IMAQdx19.5
    NI-Industrial Communications for EtherCAT19.0
    NI-Industrial Communications for CANopen19.0
    NI-Industrial Communications for DeviceNet19.0
    NI-RFSA19.1
    NI-RFSG19.1
    NI-SCOPE19.5
    NI-Serial19.5
    NI-SWITCH19.5
    NI-Sync19.5
    NI-VISA19.5
    NI-XNET19.5
    Back to Top
    Back to Top
    Back to Top
    Back to Top
    © 2020 National Instruments. All rights reserved.
    378346A-01
    Back to Top
    GMT+8, 2025-11-21 14:42
