查看: 2806|回复: 0
[NI软件产品] LabVIEW 2016 FPGA Module Xilinx Compilation Tools Win32Eng LV2016 FPGA编译工具(ISE 10.1)
    1 小时前
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-8-18 21:54:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2016Xilinx10
    发布日期
    16-8-1
    受支持的操作系统
    Windows 7 32-bit
    Windows 7 64-bit
    语言
    English
    校验和
    (MD5)
    ef3f3029d1386daffd81e514267ab0b7
    LV-FPGA-CT-2016.txt (276 Bytes, 下载次数: 6, 售价: 10 圆)
    LabVIEW 2016 FPGA Module Xilinx Compilation Tools for Windows Readme
    June 2016
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Windows, including system requirements and installation instructions.
    The Xilinx compilation tools include tools for Vivado 2015.4 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Windows computer. You must install these tools on the FPGA Module development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, use the FPGA IP Builder, or use third-party simulation.
    The Xilinx compilation tools also support Linux. Visit ni.com and enter the Info Code XilinxLinux to download the installers for Linux.
    The Xilinx compilation tools for Windows have the following system requirements:
    • Windows 7 SP1
    • 10 GB of additional disk space for Vivado 2015.4
    • 11 GB of additional disk space for ISE 14.7
    • NI recommends a 64-bit OS for the computer on which you install the Xilinx compilation tools.
    • NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    The following sections contain the NI hardware supported by the Xilinx compilation tools on Windows.
    Xilinx Compilation Tool for Vivado 2015.4
    Use the Xilinx Compilation Tool for Vivado 2015.4 to compile FPGA VIs for the following devices:
    • IC-317x
    • NI 9147, NI 9149
    • NI cRIO-903x, NI cRIO-906x
    • NI PXIe-517xR, NI PXIe-5624R, NI PXIe-5820R, NI PXIe-5840R, NI PXIe-659xR, NI PXIe-782xR, NI PXIe-793xR, NI PXIe-797xR, NI PXIe-7902R
    • NI sbRIO-9651, NI sbRIO-9607, NI sbRIO-9627, NI sbRIO-9637
    • NI USB-784xR, NI USB-785xR
    • NI USRP-RIO 294x, NI USRP-RIO 295x
    Xilinx Compilation Tool for ISE 14.7
    Use the Xilinx Compilation Tool for ISE 14.7 to compile FPGA VIs for the following devices:
    • NI 9144, NI 9146, NI 9148, NI 915x
    • NI cRIO-907x, NI cRIO-908x, NI cRIO-911x
    • NI PCIe-784xR, NI PCIe-785xR, NI PCIe-1473R
    • NI PXI-784xR, NI PXI-785xR, NI PXI-795xR
    • NI PXIe-796xR, NI PXIe-564xR
    • NI sbRIO-9605, NI sbRIO-9606, NI sbRIO-961x, NI sbRIO-962x, NI sbRIO-963x, NI sbRIO-964x
    Install the Xilinx Compilation Tool for ISE 10.1 if your FPGA device contains a Xilinx Virtex II chip. Visit ni.com/info and enter the Info Code FPGATool101 to download the Xilinx Compilation Tool for ISE 10.1.
    Insert the Xilinx compilation tools for Windows installation media and follow the instructions on the screen to complete the installation.
    LabVIEW FPGA Module Xilinx Compilation Tools for Windows Drop Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, the LabVIEW FPGA Module Xilinx Compilation Tools for Windows drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. The LabVIEW 2016 FPGA Module Xilinx Compilation Tools for Windows and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2016 FPGA Module Xilinx Compilation Tools for Windows to an unsupported OS. Additionally, after installing the LabVIEW 2016 FPGA Module Xilinx Compilation Tools for Windows, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    © 2012–2016 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \LabVIEW \FPGA\Legal
    374738F-01
    GMT+8, 2025-10-30 02:07
