查看: 3415|回复: 0
[NI软件产品] LabVIEW 2018 FPGA Module Xilinx Compilation Tools Win32Eng LV2018 FPGA编译工具(ISE 10.1)
    1 小时前
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-8-18 22:00:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2018Xilinx10
    发布日期
    18-5-21
    受支持的操作系统
    Windows 7 32-bit
    Windows 7 64-bit
    语言
    English
    校验和
    (MD5)
    87e9317aa5a644a36a27ee83f96711e0
    LV-FPGA-CT-2018.txt (276 Bytes, 下载次数: 4, 售价: 10 圆)
    LabVIEW 2018 FPGA Module Xilinx Compilation Tools for Windows Readme
    March 2018
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Windows, including system requirements and installation instructions.
    The Xilinx compilation tools include tools for Vivado 2017.2 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Windows computer. You must install these tools on the FPGA Module development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, use the FPGA IP Builder, or use third-party simulation.
    The Xilinx compilation tools also support Linux. Refer to the FPGA Module Xilinx Compilation Tools for Linux Readme for more information.
    The Xilinx compilation tool for Vivado 2017.2 has the following system requirements:
      • Windows 10 (version 1709) (64-bit)
      • Windows 7 SP11 (64-bit)
      • Windows Server 2008 R2 SP11
    • 15 GB of additional disk space
    • Memory—Refer to the Xilinx website at www.xilinx.com for memory requirements of different FPGA targets. Failure to meet the target-specific memory requirement may result in unpredictable compilation results.
      Note  The recommended memory size on the Xilinx website is for one compile job only. If you run multiple compile jobs at a time, the memory requirement increases by multiple times accordingly.
    The Xilinx compilation tool for ISE 14.7 has the following system requirements:
    • Windows 7 SP11
    1 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    • In 2016 the FPGA Module Xilinx Compilation Tools dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2018 FPGA Module Xilinx Compilation Tools will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2018 FPGA Module Xilinx Compilation Tools to an unsupported OS. Additionally, after installing the LabVIEW 2018 FPGA Module Xilinx Compilation Tools, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    • NI recommends a 64-bit OS for the computer on which you install the Xilinx compilation tools.
    The following sections contain the NI hardware supported by the Xilinx compilation tools on Windows. Devices that are compatible with the FPGA Module (64-bit) are in bold.
    Xilinx Compilation Tool for Vivado 2017.2
    Use the Xilinx Compilation Tool for Vivado 2017.2 to compile FPGA VIs for the following devices:
    • cRIO-903x/904x/906x
    • IC-317x
    • myRIO-1900/1950
    • NI ELVIS III
    • NI ELVIS RIO Control Module
    • NI-9145/9147/9149
    • PCIe-782xR
    • PXIe-5163R/5164R/517xR/5624R/576x/5840R/659xR/782xR/784x/785x/786xR/7902R/791x/793xR/797xR/798x
    • roboRIO
    • sbRIO-9651/9607/9627/9637
    • USB-784xR/785xR
    • USRP-RIO devices
    Xilinx Compilation Tool for ISE 14.7
    Use the Xilinx Compilation Tool for ISE 14.7 to compile FPGA VIs for the following devices:
    • cRIO-907x/908x/911x
    • IC-312x
    • NI-9144/9146/9148/915x
    • NI CVS-145x/145xRT
    • PCIe-784xR/785xR/1473R/8237R
    • PXIe-796xR/564xR
    • PXI-784xR/785xR/795xR
    • sbRIO-9605/9606/961x/962x (excluding 9627)/963x (excluding 9637)/964x
    Install the Xilinx Compilation Tool for ISE 10.1 if your FPGA device contains a Xilinx Virtex II chip. Visit ni.com/info and enter the Info Code FPGATool101 to download the Xilinx Compilation Tool for ISE 10.1.
    Depending on the installation media type, you can install the Xilinx Compilation Tools for Windows in either of the following ways:
    (DVD) Insert the Xilinx compilation tools for Windows installation media and follow the instructions on the screen to complete the installation.
    (USB) Complete the following steps to install the Xilinx Compilation Tools for Windows:
    • Insert the Xilinx compilation tools installation media.
    • Depending on which tool you want to install, navigate to the Windows\Vivado2017_2 or Windows\ISE14_7 directory.
    • Double-click autorun.exe on the media to begin installation.
    • Follow the instructions on the screen to complete the installation.
    © 2012–2018 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \LabVIEW \FPGA\Legal
    374738J-01
    GMT+8, 2025-10-30 02:05
