查看: 2977|回复: 0
[NI软件产品] LabVIEW 2013SP1 FPGA Module Xilinx Compilation Tools and F1Patch Win32Eng LV2013SP1 FPGA编译工具(ISE 14.4)及补丁
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-8-19 01:23:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI官方网站上虽然写着是2013SP1版,但是实际上是2013版,未找到2013SP1版(后续如有找到更更新)。有2013SP1的补丁程序,但是需要先安装2013SP1版的ISE14.4。如果确实需要该版本,可以安装核心开发套件DS2014Spring,其中的DVD2中包含了ISE14.4的FPGA编译工具2013SP1:
    NI Developer Suite 2014 Spring Win32/64 Eng/Chn NI核心开发套件2014春季版 基于LabVIEW 2013SP1版
    http://visionbbs.com/thread-25060-1-1.html
    发布日期
    14-3-2
    受支持的操作系统
    Windows XP 32-bit
    Windows XP 64-bit
    Windows Vista 32-bit
    Windows Vista 64-bit
    Windows 7 32-bit
    Windows 7 64-bit
    语言
    English
    校验和
    补丁校验和:
    MD5:190BACA22D4E890AC18015658A090EA9
    百度网盘下载(限速,请开会员或使用工具下载):
    无资源
    NI官方下载地址(可能无法下载完成或地址无效):
    无资源
    2013SP1Patch(安装补丁之前请先安装LabVIEW 2013 SP1 FPGA Compilation Tool for ISE 14.4,但是从NI官方下载的只有2013版的FPGA CT ISE14.4,没有2013SP1的,所以这个补丁能不能安装,还有待验证)
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    FPGA-ISE14.4-CT2013SP1.txt (597 Bytes, 下载次数: 1, 售价: 2 圆)
    LabVIEW 2013 SP1 FPGA Module Xilinx Tools 14.4 f1 Patch
    Issues FixedPatch OverviewSystem RequirementsPatched LabVIEW FilesInstallation Instructions
    Issues Fixed
    National Instruments tested this patch to verify the intended fix. However, National Instruments performed only a limited amount of testing to detect problems that this patch may introduce. National Instruments strongly recommends that you test the changes before using this patch in a production environment. This patch includes the following changes:
    • CAR #463172—After upgrading to LabVIEW 2013 SP1, some systems are unable to compile FPGA VIs. On systems that do not have Microsoft .NET 4.5 or later installed, the FPGA compile worker cannot be reached by LabVIEW because the worker fails to start.
    Following is a list of patched files and folders. [NI DIR] is the location on your computer where you installed your National Instruments software. For most users, this is the C:\Program Files\National Instruments directory.
    • [NIDIR]\FPGA\CompileWorker\CompileWorker.exe
    • Before beginning installation, close all National Instruments software.
    • Run setup.exe and follow the instructions in the installer.
    • Repeat these steps for all machines used for FPGA compilation you want to patch.
    © 2003-2014 National Instruments Corporation. All rights reserved.
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Xilinx is the registered trademark of Xilinx, Inc.
    GMT+8, 2025-10-30 02:18
