LabVIEW 2015SP1 FPGA Module Xilinx Compilation Tools Win32Eng LV2015SP1 FPGA编译工具(ISE 14.7)
2015SP1Xilinx14_7,4.39GB
发布日期
16-3-8
受支持的操作系统
Windows XP 32-bit
Windows XP 64-bit
Windows Vista 32-bit
Windows Vista 64-bit
Windows 7 32-bit
Windows 7 64-bit
语言
English
校验和
MD5:f08fe2b9ceeb6c29b5a64b4fa26f16ed
百度网盘下载(限速,请开会员或使用工具下载):
请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
NI官方下载地址(可能无法下载完成或地址无效):
FPGA-ISE14.7-CT2015SP1.txt
(285 Bytes, 下载次数: 2, 售价: 10 圆)
LabVIEW 2015 SP1 FPGA Module Xilinx Compilation Tools for Windows ReadmeDecember 2015
This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Windows, including system requirements and installation instructions.
Overview System Requirements Supported Hardware Installation Instructions Product Security and Critical Updates Automating the Installation of NI Products NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 Legal Information OverviewThis media gives you access to Xilinx compilation tools for Vivado 2014.4 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Windows computer. You also must install these tools on the development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, use FPGA IP Builder, or use third-party simulation.
System RequirementsThe following table lists the system requirements for the Xilinx compilation tools. Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW.
Windows | Vivado 2014.4 | ISE 14.7 | | Operating System | Windows 7 Service Pack 1/Vista (32-bit and 64-bit) | Windows 7 Service Pack 1/Vista/XP Professional (32-bit and 64-bit) | | Disk Space | 11 GB | | Note NI recommends a 64-bit OS for the computer on which you install the Xilinx compilation tools. | Supported HardwareThe following sections contain the NI hardware supported by the Xilinx compilation tools on Windows.
Xilinx Compilation Tools for Vivado 2014.4Use the Xilinx Compilation Tools for Vivado 2014.4 to compile FPGA VIs for the following devices:
- IC-317x
- NI 914x
- NI cRIO-903x, NI cRIO-906x
- NI PXIe-517xR, NI PXIe-5624R, NI PXIe-5820R, NI PXIe-5840R, NI PXIe-659xR, NI PXIe-782xR, NI PXIe-793xR, NI PXIe-797xR, NI PXIe-7902R
- NI sbRIO-9651, NI sbRIO-9607, NI sbRIO-9627, NI sbRIO-9637
- NI USB-785xR
- NI USRP-RIO 294x, NI USRP-RIO 295x
Xilinx Compilation Tools for ISE 14.7Use the Xilinx Compilation Tools for ISE 14.7 to compile FPGA VIs for the following devices:
- NI PXI-784xR, NI PXI-785xR, NI PXI-795xR
- NI PCIe-784xR, NI PCIe-785xR
- NI PXIe-796xR, NI PXIe-564xR
- NI cRIO-907x, NI cRIO-908x, NI cRIO-911x
- NI sbRIO-960x, NI sbRIO-961x, NI sbRIO-962x, NI sbRIO-963x, NI sbRIO-964x
- NI 9144, NI 9146, NI 9148, NI 915x
Install the Xilinx Compilation Tools for ISE 10.1 if your FPGA device contains a Xilinx Virtex II chip. Visit ni.com/info and enter the Info Code FPGATool101 to download the Xilinx Compilation Tools for ISE 10.1.
Installation InstructionsYou can find installation instructions in the LabVIEW FPGA Module Release and Upgrade Notes, which are available online at ni.com/manuals and on the LabVIEW Platform media.
Note If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software.
- For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, How Can I Determine the Type and Version of My National Instruments Installer?.
NI LabVIEW FPGA Module Xilinx Compilation Tools for Windows Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016National Instruments LabVIEW FPGA Module Xilinx Compilation Tools for Windows will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW FPGA Module Xilinx Compilation Tools for Windows that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
Product | Info Code | | LabVIEW | lifecycle | | LabWindows™/CVI™ | cvi_lifecycle | | Measurement Studio | mstudiolifecycle | | TestStand | tslcp | | DIAdem | ddlcp | | SignalExpress | selcp | | VeriStand | nivslifecycle |
Legal InformationCopyright
© 2012–2015 National Instruments. All rights reserved.
Third-Party Copyright Notices
\LabVIEW \FPGA\Legal
The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
- Notices are located in the \_Legal Information and directories.
374738D-01
