查看: 3043|回复: 0
[NI软件产品] LabVIEW 2014 FPGA Module Xilinx Compilation Tools Win32Eng LV2014 FPGA编译工具(ISE 14.7)
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-8-20 01:31:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2014Xilinx14_7,4.4GB
    发布日期
    08-04-2014
    受支持的操作系统
    Windows 7; Windows Vista; Windows XP (SP3) 32-bit; Windows Server 2008 R2 64-bit; Windows Server 2003 R2 32-bit
    语言
    English
    校验和
    MD5: cb386fa6c7bf967d40ed0ca210aa1fcf
    SHA1: 6f8d0ebb8fa0ba8baf2f996b097ca2bb886bc5f5
    SHA256: c443ae1df002c79c11063f8f6532c0406750088aa50c1c106ac28ef262e757ed
    CRC32: fe432df7
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    FPGA-ISE14.7-CT2014.txt (276 Bytes, 下载次数: 1, 售价: 10 圆)
    To get started:
    Click the Download Link link above.
    Your browser will begin downloading the standalone installer for your software.
    Once the standalone installer has been downloaded, launch the executable and follow the onscreen prompts to complete the installation of your software.
    Filesize: 4455.09 MB
    Checksum (MD5): cb386fa6c7bf967d40ed0ca210aa1fcf
    Updates and Notifications:
    Critical Updates and Security Notifications are posted on ni.com. Before downloading, click here to review this information.
    Download Language: English
    Product Line: LabVIEW
    Version: 2014
    Release date: 08-04-2014
    Software type: Other
    Operating system: Windows 7; Windows Vista; Windows XP (SP3) 32-bit; Windows Server 2008 R2 64-bit; Windows Server 2003 R2 32-bit
    Description
    The NI LabVIEW 2014 FPGA Module Xilinx Tools 14.7 or Vivado 2013.4 Tools are required to compile for certain NI RIO devices that do not use a Virtex-II FPGA.
    Perform the following steps to install LabVIEW 2014 FPGA Module Xilinx Tools 14.7:
    Close all NI software.
    Follow the installation instructions in the NI LabVIEW 2014 FPGA Module Xilinx Compilation Tools for Windows DVD Readme
    Verify that the software installs correctly.
    Perform these steps for all development systems where you want to install.
    From a development system, reinstall all software to all deployed systems you wish to upgrade.
    (Note: Applies to deployed software only.)
    To conserve disk space you can delete your extracted files. It is recommended that you keep the extracted installation files in case you need to add features from this distribution in the future.
    Version 14.0.0
    June 2014
    This file contains important information about the LabVIEW 2014 FPGA Module Xilinx Compilation Tools for Windows DVD. Install these compilation tools if you want to compile your FPGA VIs on a Windows computer.
    NI LabVIEW FPGA Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    You can install the Xilinx compilation tools for Windows using the LabVIEW FPGA Module Xilinx Compilation Tools for Windows DVD. Install these compilation tools on the development computer to compile your LabVIEW FPGA VIs locally. You also must install these tools on the development computer if you plan to create simulation exports, configure the IP Integration Node, incorporate Xilinx IP, use third-party simulation, or use the Configure Component-Level IP wizard.
    The Xilinx compilation tools for Windows includes Vivado 2013.4 and ISE 14.7. Refer to the following sections and the support document at ni.com for more information about the NI hardware supported by each Xilinx compilation tool.
    Xilinx Compilation Tools for Vivado 2013.4
    Use the Xilinx compilation tools for Vivado 2013.4 to compile FPGA VIs for these NI-RIO devices:
    NI USB-785xR, NI PXIe-517xR, NI PXIe-5624R, NI PXIe-659xR, NI PXIe-782xR, NI PXIe-797xR, NI cRIO-9068, NI cRIO-903x, NI USRP-RIO 294x, NI USRP-RIO 295x.
    Xilinx Compilation Tools for ISE 14.7
    Use the Xilinx compilation tools for ISE 14.7 to compile FPGA VIs for these NI-RIO devices:
    NI PXI-784xR, NI PXI-785xR, NI PXI-795xR, NI PCIe-784xR, NI PCIe-785xR, NI PXIe-796xR, NI PXIe-564xR, NI cRIO-907x, NI cRIO-908x, NI cRIO-911x, NI sbRIO-960x, NI sbRIO-962x, NI sbRIO-963x, NI sbRIO-964x, NI 9144, NI 9146, NI 9148, NI 915x, NI sbRIO-961x.
    Install the Xilinx 10.1 compilation tools if your FPGA device contains a Xilinx Virtex II chip. To download the Xilinx 10.1 compilation tools, refer to ni.com/info and enter the Info Code FPGATool101.
    You can install the Xilinx compilation tools for Windows using the Xilinx Compilation Tools for Windows DVD. You can find installation instructions for the Xilinx compilation tools for Windows in the LabVIEW FPGA Module Release and Upgrade Notes, which are available online at ni.com/manuals and on the LabVIEW 2014 Platform media.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the FPGA Module.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the LabVIEW 2014 FPGA Module.
    The National Instruments LabVIEW FPGA Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the LabVIEW FPGA Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2012–2014 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \National Instruments\LabVIEW 2014\FPGA\Legal\
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Xilinx® is a registered trademark of Xilinx, Inc. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2025-10-30 02:20
