查看: 4650|回复: 0
[NI软件产品] LabVIEW 2020 FPGA Module Xilinx Compilation Tools Win64Eng LV2020 FPGA编译工具(Vivado 2019.1)
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-8-23 00:42:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ni-vivado-2019.1-cg_20.0.0,7.62GB
    发布日期
    20-5-15
    受支持的操作系统
    Windows 7 64-bit
    Windows 10 64bit
    语言
    English
    校验和
    MD5: d9c8b686e3e09809950d23f242ec8511
    SHA1: 24aad156c4d84a77fbe128b2e62721c22c336b92
    SHA256: 8cdb36f3c359d0a5f0bc93f6ece644df6ca4ea632dfe7e919b6b4f17e9ba06fe
    CRC32: c8a52960
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    FPGA-Vivado2019.1CT-2020.txt (290 Bytes, 下载次数: 12, 售价: 10 圆)
    LabVIEW 2020 FPGA Module Xilinx Compilation Tools for Windows Readme
    March 2020
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Windows, including system requirements and installation instructions.
    FPGA Module Xilinx Compilation Tools Drop Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The Xilinx compilation tools include tools for Vivado 2019.1 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Windows computer. You must install these tools on the FPGA Module development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, or use third-party simulation.
    The Xilinx compilation tools also support Linux. Refer to the FPGA Module Xilinx Compilation Tools for Linux Readme for more information.
    The Xilinx compilation tool for Vivado 2019.1 has the following system requirements:
      • Windows 10 (version 1909) (64-bit)
      • Windows 7 SP11 (64-bit)
    • 15 GB of additional disk space
    • Memory—Refer to the Xilinx website at www.xilinx.com for memory requirements of different FPGA targets. Failure to meet the target-specific memory requirement may result in unpredictable compilation results.
      Note  The recommended memory size on the Xilinx website is for one compile job only. If you run multiple compile jobs at a time, the memory requirement increases by multiple times accordingly.
    The Xilinx compilation tool for ISE 14.7 has the following system requirements:
    • Windows 7 SP11
    1 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    • In 2016 the FPGA Module Xilinx Compilation Tools dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2020 FPGA Module Xilinx Compilation Tools will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2020 FPGA Module Xilinx Compilation Tools to an unsupported OS. Additionally, after installing the LabVIEW 2020 FPGA Module Xilinx Compilation Tools, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, visit ni.com/r/OSSupport2016.
    • Refer to FPGA Module Xilinx Compilation Tools Drop Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    • NI recommends a 64-bit OS for the computer on which you install the Xilinx compilation tools.
    The following sections contain the NI hardware supported by the Xilinx compilation tools on Windows. Devices that are compatible with the FPGA Module (64-bit) are in bold.
    Xilinx Compilation Tool for Vivado 2019.1
    Use the Xilinx Compilation Tool for Vivado 2019.1 to compile FPGA VIs for the following devices:
    • cRIO-903x/904x/905x/906x
    • IC-317x
    • myRIO-1900/1950
    • NI ELVIS III
    • NI ELVIS RIO Control Module
    • NI-9145/9147/9149
    • PCIe-576x/577x/5785/6593/782xR/7846/7856/7857/7858/798x
    • PXIe-5163R/5164R/517xR/5624R/5745/576x/577x/5785/5840R/659x/782xR/784x/785x/786x/786xR/7902R/791x/793xR/797xR/798x/799x
    • roboRIO
    • sbRIO-9603/9608/9609/9628/9629/9638/9651/96x7
    • USB-784xR/785xR
    • USRP-RIO devices
    Xilinx Compilation Tool for ISE 14.7
    Use the Xilinx Compilation Tool for ISE 14.7 to compile FPGA VIs for the following devices:
    • IC-312x
    • NI-915x
    • NI CVS-145x/145xRT
    • PCIe-7841R/7842R/7851R/7852R/1473R/8237R
    • PXIe-796xR/564xR
    • PXI-784xR/785xR/795xR
    Install the Xilinx Compilation Tool for ISE 10.1 if your FPGA device contains a Xilinx Virtex II chip. Visit ni.com/info and enter the Info Code FPGATool101 to download the Xilinx Compilation Tool for ISE 10.1.
    NI installs the Xilinx Compilation Tools for Windows using NI Package Manager. If you do not already have NI software installed, the Xilinx Compilation Tools installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can also install the Xilinx Compilation Tools for Windows using the installation media. Depending on the installation media type, you can install the Xilinx Compilation Tools for Windows in either of the following ways:
    (DVD) Insert the Xilinx compilation tools for Windows installation media and follow the instructions on the screen to complete the installation.
    (USB) Complete the following steps to install the Xilinx Compilation Tools for Windows:
    • Insert the Xilinx compilation tools installation media.
    • Depending on which tool you want to install, navigate to the Windows\Vivado2019_1 or Windows\ISE14_7 directory.
    • Double-click autorun.exe on the media to begin installation.
    • Follow the instructions on the screen to complete the installation.
    FPGA Module Xilinx compilation tools will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2012–2020 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \LabVIEW \FPGA\Legal
    374738L-01
    GMT+8, 2025-10-30 02:20
