查看: 3108|回复: 0
[NI软件产品] LabVIEW 2015SP1 FPGA Module Xilinx Compilation Tools Linux32Eng LV2015SP1 FPGA编译工具(ISE 14.7)
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-8-26 22:02:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2015sp1cw-linux-ise14_7,3.74GB
    发布日期
    16-3-8
    受支持的操作系统
    Red Hat Enterprise Linux 6.4 (32-bit)
    Red Hat Enterprise Linux 6.5 (32-bit)
    语言
    English
    校验和
    MD5: 3237ea648925c925f56f13bfdf66393f
    SHA1: 75f300d8ef19cfc003a1ebbd18fee82c60e2ab8b
    SHA256: 5e5ddb66710154ad2f2c169348f67b93ddadd29439df256538d1164389395bfd
    CRC32: 87be7477
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    FPGACT-Linux-ISE14.7-LV2015SP1.txt (287 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2015 SP1 FPGA Module Xilinx Compilation Tools for Linux Readme
    December 2015
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Linux, including system requirements and installation instructions.
    This media gives you access to Xilinx compilation tools for Vivado 2014.4 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile your FPGA VIs on a Linux computer.
    The Xilinx Compilation Tools for Linux have the following requirements:
    • Red Hat Enterprise Linux 6.4 or 6.5
    • 11 GB of disk space
    Note NI recommends a 64-bit OS for the computer on which you install the Xilinx compilation tools.
    The following sections contain the NI hardware supported by the Xilinx compilation tools on Linux.
    Xilinx Compilation Tools for Vivado 2014.4
    Use the Xilinx Compilation Tools for Vivado 2014.4 to compile FPGA VIs for the following devices:
    • IC-317x
    • NI 914x
    • NI cRIO-903x, NI cRIO-906x
    • NI PXIe-517xR, NI PXIe-5624R, NI PXIe-5820R, NI PXIe-5840R, NI PXIe-659xR, NI PXIe-782xR, NI PXIe-793xR, NI PXIe-797xR, NI PXIe-7902R
    • NI sbRIO-9651, NI sbRIO-9607, NI sbRIO-9627, NI sbRIO-9637
    • NI USB-785xR
    • NI USRP-RIO 294x, NI USRP-RIO 295x
    Xilinx Compilation Tools for ISE 14.7
    Use the Xilinx Compilation Tools for ISE 14.7 to compile FPGA VIs for the following devices:
    • NI PXI-784xR, NI PXI-785xR, NI PXI-795xR
    • NI PCIe-784xR, NI PCIe-785xR
    • NI PXIe-796xR, NI PXIe-564xR
    • NI cRIO-907x, NI cRIO-908x, NI cRIO-911x
    • NI sbRIO-960x, NI sbRIO-961x, NI sbRIO-962x, NI sbRIO-963x, NI sbRIO-964x
    • NI 9144, NI 9146, NI 9148, NI 915x
    Complete the following steps to install the Xilinx Compilation Tools for Linux:
    • Insert the Xilinx Compilation Tools for Linux installation media. Use mount /mnt/cdrom to mount the media. On some Linux systems, the media mounts automatically.
    • To change the current directory to the mounted media, enter cd /mnt/cdrom/CWXILINX14 or cd /mnt/cdrom/CWVIVADO2014.
    • To run the installation script, enter sh ./INSTALL.
    © 2012–2015 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \LabVIEW \FPGA\Legal
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    374740D-01
    GMT+8, 2025-10-30 02:18
