查看: 3291|回复: 0
[NI软件产品] LabVIEW 2017 FPGA Module Xilinx Compilation Tools Linux32Eng LV2017 FPGA编译工具(ISE 14.7)
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-8-26 22:17:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2017FPGA-LinuxISE,3.74GB
    发布日期
    17-12-6
    受支持的操作系统
    Red Hat Enterprise Linux 6.5
    语言
    English
    校验和
    MD5: 14b6887a1f179a51d8260e9563a71e76
    SHA1: f583cd755d565649fb841dfcd85503474aece804
    SHA256: 618c32cc76c80043dd61503c72ee5df8fbdece583bb65924128ac20503eef1f9
    CRC32: 0167fc3b
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    FPGACT-Linux-ISE14.7-LV2017.txt (278 Bytes, 下载次数: 8, 售价: 10 圆)
    LabVIEW 2017 FPGA Module Xilinx Compilation Tools for Linux Readme
    March 2017
    This file contains important information about the LabVIEW FPGA Module Xilinx
    Compilation Tools for Linux, including system requirements and installation
    instructions.
    The Xilinx compilation tools include tools for Vivado 2015.4 and ISE 14.7,
    which are supported by the LabVIEW FPGA Module. Install these compilation tools
    if you want to compile FPGA VIs on a Linux computer.
    The Xilinx compilation tools also support Windows. Refer to the
    FPGA Module Xilinx Compilation Tools for Windows Readme for more information.
    The Xilinx Compilation Tool for Vivado 2015.4 has the following system
    requirements:
    One of the following operating systems:
    * Red Hat Enterprise Linux 6.5 (64-bit)
    * Red Hat Enterprise Linux 7.0 (64-bit)
    * CentOS 7.0 (64-bit)
    11 GB of additional disk space
    The Xilinx Compilation Tool for ISE 14.7 has the following system requirements:
    The following sections contain the NI hardware supported by the
    FPGA Module Xilinx Compilation Tools on Linux:
    Use the Xilinx Compilation Tool for Vivado 2015.4 to
    compile FPGA VIs for the following devices:
    IC-317x
    myRIO-1900, myRIO-1950
    NI 9145, NI 9147, NI 9149
    NI cRIO-903x, NI cRIO-906x
    NI ELVIS RIO Control Module
    NI PCIe-782xR
    NI PXIe-517xR, NI PXIe-5624R, NI PXIe-5840R, NI PXIe-659xR,
    NI PXIe-782xR, NI PXIe-784x, NI PXIe-785x, NI PXIe-786xR,
    NI PXIe-793xR, NI PXIe-797xR, NI PXIe-7902R
    NI sbRIO-9651, NI sbRIO-9607, NI sbRIO-9627, NI sbRIO-9637
    NI USB-784xR, NI USB-785xR
    NI USRP-RIO 294x, NI USRP-RIO 295x
    roboRIO
    Use the Xilinx Compilation Tool for ISE 14.7
    to compile FPGA VIs for the following devices:
    NI 9144, NI 9146, NI 9148, NI 915x
    NI cRIO-907x, NI cRIO-908x, NI cRIO-911x
    NI PCIe-784xR, NI PCIe-785xR, NI PCIe-1473R
    NI PXI-784xR, NI PXI-785xR, NI PXI-795xR
    NI PXIe-796xR, NI PXIe-564xR
    NI sbRIO-9605, NI sbRIO-9606, NI sbRIO-961x,
    NI sbRIO-962x (excluding NI sbRIO-9627),
    NI sbRIO-963x (excluding NI sbRIO-9637), NI sbRIO-964x
    Visit ni.com/info and enter the Info Code XilinxCompileTools for more
    information about the NI hardware supported by each Xilinx compilation tool.
    Complete the following steps to install the
    FPGA Module Xilinx Compilation Tools for Linux:
    1. Log into the system as root.
    2. Use mount to mount the compilation tools installer.
    3. If the media type is DVD, change the current directory to the mount point.
    If the media type is USB, change the current directory to
    mount point/Linux/Vivado2015_4 or mount point/Linux/ISE14_7,
    depending on which tool you want to install.
    4. To run the installation script, enter the following command:
    sh ./INSTALL
    Visit ni.com/security for security information about NI products.
    Visit ni.com/critical-updates for information about critical updates from NI.
    (C) 2012-2017 National Instruments. All rights reserved.
    Under the copyright laws, this publication may not be reproduced or transmitted
    in any form, electronic or mechanical, including photocopying, recording,
    storing in an information retrieval system, or translating, in whole or in
    part, without the prior written consent of National Instruments Corporation.
    National Instruments respects the intellectual property of others, and we ask
    our users to do the same. NI software is protected by copyright and other
    intellectual property laws. Where NI software may be used to reproduce software
    or other materials belonging to others, you may use NI software only to
    reproduce materials that you may reproduce in accordance with the terms of any
    applicable license or other legal restriction.
    Third-Party Copyright Notices
    The SharpZipLib_Notice.pdf file contains a third-party copyright notice for
    third-party components used by certain FPGA Module features. The following
    directory is the default installation location for the file, but the location
    might vary depending on the configuration of the local computer:
    /usr/local/natinst/nifpgacompileworker/doc
    You can find end-user license agreements (EULAs) and third-party legal notices
    in the following locations after installation:
    If you are an agency, department, or other entity of the United States
    Government ("Government"), the use, duplication, reproduction, release,
    modification, disclosure or transfer of the technical data included in this
    manual is governed by the Restricted Rights provisions under Federal
    Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal
    Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015
    for military agencies.
    Content from the IVI specifications reproduced with permission from the IVI
    Foundation.
    The IVI Foundation and its member companies make no warranty of any kind with
    regard to this material, including, but not limited to, the implied warranties
    of merchantability and fitness for a particular purpose. The IVI Foundation and
    its member companies shall not be liable for errors contained herein or for
    incidental or consequential damages in connection with the furnishing,
    performance, or use of this material.
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for
    information on National Instruments trademarks. Xilinx® is a registered
    trademark of Xilinx, Inc. Other product and company names mentioned herein
    are trademarks or trade names of their respective companies.
    For patents covering the National Instruments products/technology, refer to
    the appropriate location: Help» Patents in your software, the patents.txt file
    on your media, or the National Instruments Patent Notice at ni.com/patents.
    374740G-01
    GMT+8, 2025-10-30 02:18
